Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
1f79-111 thermostat adjusts itself back to 62 degrees when set on 70 to heat
liteswink
  • 99 Answers
SOURCE: My white-rogers 1F81-261 model thermostat keeps
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: I have the thermostat set for 70 degrees on the
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
liteswink
  • 99 Answers
SOURCE: Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
liteswink
  • 99 Answers
SOURCE: thermostat resets itself to 85 degrees a couple
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Posted on Jul 23, 2010
reddawgesq
  • 134 Answers
SOURCE: How do I program my
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 03, 2011
The thermostat will not stay at the degree I set it at
What make and model of the Thermostat (what you have is a setback) and you can manually set then it defaults back to what you programmed it for. It's that way because you or someone programmed it to do that.
Jan 21, 2018 | Heating & Cooling
My furnace runs to operating temp on thermostat shuts down then within 30 seconds try's to cycle back on three to four times. What would cause this.
Some thermostats have a swing setting that can be adjusted. A swing is the setting when you want the furnace to stop or start from the desired set point. For example, you set your thermostat at 70 and the swing is set at 10 degrees. Then the furnace will turn on 5 degrees below 70 and shut off 5 degrees above 70. Check you thermostats manual if it has this option.
Mar 15, 2016 | Heating & Cooling
Why is my furnace blowing cold air?
I depends on if you have gas or electric heat. If electric, you could have blown a fuse. If gas, your pilot light may be out.
Feb 26, 2015 | Heating & Cooling
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
program operation.
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My honeywell t87n is adjusting the heat setting by
This sometimes happens over time with some digital thermostats. The easiest solution is get a toothpick and hit the reset button. From there just set it as you normally would. That should solve your problem.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Honeywell Heat/Cool Thermostat
My heat pump runs most all the time i will set the thermostat on 70 when it gets to 70 it still runs I can kick it back down to 69 and it kicks off.I can put it on 72 when it gets to 72 it still runs, I...
therostats have what is known as off-set deflection , or simplely put the plus or minus of the temp range which the heat turns on or off this setting is adjustable on many thermostats i usually set for 3 degrees if it is set for 1 or 2 it will run all the time refer to owners manual to see how to set this in program
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
My Honeywell thermostat does not heat the house to the selected temperature. It will come on but not long enough to heat the house to the temp I selected.
Verify that you have heat coming from the vents.
Also do you use a heat pump system with electric emergency heat?
It may be that if it is to cold outside that the heat pump can not handle the load due to the cold outside and you will need to turn on the emergency heat.
Keep me posted.
FlaTech.
Thank you for using FixYa!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Nov 17, 2009 | Honeywell Heating & Cooling
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Thermostat temperatures not reaching preset Energy Star settings
Well with a boiler system like you have it will cost you more money to heat your house that way than if you leave it like it is. With a boiler system it takes a lot longer to heat an area than with a furnace. The best thing you can do is find a happy medium and leave it there at all times. If you read the paper work on your new thermostats they have a set procedure which tells the thermostat if you have forced air or boiler system. Do you have baseboard or in-floor heat how many zones do you have.
Jan 07, 2009 | Honeywell Electronic Programmable...
Cooling limit on th320u
the cooling setting will not go below the heating setting. lower the heating setting so you can lower the cooling
Jan 16, 2018 | Honeywell Electronic Programmable...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
74 people viewed this question
Top White Rodgers Home Security Experts
Tom Chichester
Heatmeister99
Level 1 Expert
A Hoffman
A Hoffman
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
