Whirlpool AWO 3761 not draining
My machine is not draining. The fault FP came up an the "Clean Filter" light is on. Any suggestions?
  • 1294 Answers
SOURCE: washing machine will not drain
You shd check out your pump, refer
to manual. There shd be some block there.
Posted on May 09, 2008
IFIXALL
  • 868 Answers
SOURCE: whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
Posted on Jun 05, 2008
canbruce75
  • 1776 Answers
SOURCE: After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Posted on Aug 02, 2009
canbruce75
  • 1776 Answers
SOURCE: Problem with Whirlpool washing machine - AWO/D 4705
The first thing to check is the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the opening on the water inlet valve and make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Test for continuity. A lack of continuity will mean a bad solenoid and the valve will need replaced.
If the inlet valve checks out alright, then the next place to look would be a malfunctioning water level/pressure switch. It is a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. Make sure there are no obstructions in or damage to the plastic tube. The switch can be tested for continuity in the same manner as the water inlet valve solenoids. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 15, 2009
SOURCE: Have a Whirlpool AWO/D 6042 front loading washing
Hey did you find out the answer as im having the same problem?
Posted on May 04, 2010
AWO 3551 have a FP fault . help
thanks for your advice. I have an AWO 3551 Whirlpool front-loading washing machine. It works but I think it's highly likely that the filter needs a clean and is long overdue. I've opened the front plate and unscrewed the plastic cover but the filter doesn't come out at the same time. It seems pretty stuck and there is nothing to get a purchase on (unless I get pliers and turn counter clockwise - but slightly concerned that might break it...?) Any suggestions of how to make it 'come out to play'?!
Feb 21, 2012 | Whirlpool Washing Machines
Ive got a whirlpool awo 3761/s washing machine it goes through the whole cycle but it stays on number 1 forever it doesnt spin off properly and it doesnt drain off what could this be as this is the only...
(try this!)
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 24, 2011 | Washing Machines
I have a whirlpool AWO 3761 and it says " clean
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
Hope the filter is the problem!
BTW manual-
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 12, 2011 | Whirlpool AWOE8748 Front Load Washer
The clean pump light comes on 10 mins into a cycle on my whirlpool awo 3761 5 what does this mean? it has recently been moved and re plumbed in
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter ('Clean pump'). So many 'faults' are caused by blocked filters.
John C
Mar 09, 2011 | Washing Machines
I hav a whirlpool awo 3761/5/s and when i try to put it on a cycle it trips the electric
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that you only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Mar 05, 2011 | Whirlpool Washing Machines
Hi i hv AWO 3761/S Washing machine. After washing the clean pump light turns red and there is water left in the machine. What should i do.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
John C
Feb 17, 2011 | Whirlpool Washing Machines
I have a awo 3761/5/s model and it keeps coming up on the display fh and the lights flash what does this mean
Unfortunately there are so many abriviations that one cant keep up.(not standardised). Best thing to do is do a manual check. Switch water off and check the filter. Clean it. Next, do a check and confirm that the drain pump is free of obstruction and free to turn.(loose). Get motor to spin by selecting spin and see if it does. If all those checks work out, it should function.
Jun 05, 2010 | Whirlpool Washing Machines
Whirlpool AWO 3761/S
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
Top Washing Machines Experts
