MY COPIER MASHINE AS AN ERROR CODE E00000007-0001
SO WHAT IM I SUPPOSE TO DO
tutopian
  • 57 Answers
SOURCE: e602-0001
Error Code
E602-0001, 0002
Indicates the presence of an error in write/read operation.
Posted on Nov 28, 2007
Cogz
  • 1326 Answers
SOURCE: copier problems
What model gestetner is it? There are different ways to rest it. What generation are you talking about? 10 years old or two days old model?? Need some more info. The problem may just needs to be rest, it most likely a fuser code to cold or to hot.
Posted on Mar 11, 2008
checkitright
  • 1362 Answers
SOURCE: canon ir6000 error codes E000061-0001..
E061 Specific potential is not required or the limiter is activated as the potential is controlled.
I beleive it is the Potential of the "drum sensor"
there is a sensor that reads the drum and adjust the machine, this may need to be adjusted, cleaned or replaced. Has to be done by a tech.
Posted on Aug 25, 2008
SOURCE: IR 5570 Error code
home position error the fuser shutter.could be a cracked fuser roller.if not will need an upper fuser assy
Posted on Sep 24, 2008
randula7
  • 78 Answers
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Posted on Sep 08, 2009
How do I fix the error code SC400?
I don't know what is your printer model, but I am sure, that this mashine needs cleaning. The main problem should be that the ID sensors of image transfer belt are dirty. You need technical skills to do that.
Apr 08, 2015 | Ricoh Aficio Office Equipment & Supplies
We are facing error code e004 Scanners in Konica Minolta c224, please help us if you have any solution.
Try to upgrade the firmware of the mashine to c224e. Remember to use USB device max 2gb volume
Jan 11, 2015 | Konica Minolta Office Equipment & Supplies
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Sir canon ir2830 error code E743
sir meri mashin me ir2830 me error code E000-0743 aa raha he kriapya esaka solution batao
Jul 25, 2012 | Canon Ir 2830 Digital Copier
The machine did not working
What does the from mashin happened and what the type of mashine
Mar 14, 2010 | Office Equipment & Supplies
MY TOSHIBA E STUDIO 4511 HAS AN ERROR F100 CODE. WHAT DOES IT MEAN?
format hard by power on+0+8 then 690 then start then2 then set then report the mashin or revision the logic may be there is a problem in it
Sep 21, 2009 | Toshiba E-Studio 3511 Color Copier
Copier problems
Mar 10, 2008 | Office Equipment & Supplies
29 people viewed this question
k24674
jasbo
jasbo
