Question about Maytag EPICz 3.7 cu. ft. Washer
My maytag epic z front load washer won't work. Control panel lights up, I can choose a cycle but when I press start there is a click the door locks and the washer does nothing - no spinning - wat
  • nicole deleon Sep 28, 2013
    I have the same problem but it will not do anything after the door locks,Then i try to turn it off and it will not turn off, door will stay lock, and the add a garment light blinks?I try to uplug it but the same thing happens all over again.
  • jdixon91182
    jdixon91182 Feb 22, 2014
    I have a Maytag Epic Z front loading washing machine that stops prior to the spin cycle and does not drain the water. I have replaced the entire pump and drain mechanism and verified the the hoses are clear. It still does the same thing. It stops and completely powers off but leaves the door locked light on (red). Is there a sensor that needs to be replaced?
3 Suggested Answers
michiganfan9
  • 179 Answers
SOURCE: my new Epic Z is only one month old
sounds to me like there is a short in the wiring or control board i would call the warranty company to come fix it
Posted on Dec 30, 2008
Macmarkus
  • 2605 Answers
SOURCE: my Maytag Epic Z front load washer stops working
Hello, welcome to FixYa.
Based on your information posted I understand you have the Maytag Epic washer, correct ? The F21 error on these built by Whirlpool means an excessive drain time or excessive suds was detected as you may or may not already know.
If you follow the link to my solution to this error designed specifically for "do-it-yourselfers" you should be fixed up in no time. (It's much quicker for me than pasting or retyping the complete solution several hundred times, that's how common this is).
This will also instruct how to unlock the unit...though once the water is gone it likely will unlock without issue, if it is at all an issue. Many times it is, but it's just a by-product of not draining correctly.
http://www.fixya.com/support/r9090359-whirlpool_frontload_f2_f21_sd_suds
Thank you for choosing FixYa. Please take a moment to rate the info provided here and a testimony on your experience here at FixYa today is appreciated.
Let me know if anything isn't clear or you need further assistance, Good luck.
Regards,
Macmarkus :)
Posted on Sep 26, 2011
How much it cost to fix maytag washer epic z After I push Power, My Maytag epic z front load washer is turning itself off as soon as I press the Start button!
Press the button on the far right next to the Off button and hold for 3 seconds. I think it's the "Cycle End Signal" button.
Dec 02, 2011 | Washing Machines
Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
CONTROL PANEL LOCKED LIGHT ON, WASHER WONT WORK.TRIED UNPLUGGING TO RESET.
Press END OF CYCLE button and hold it for 10 seconds.. It will turn of the control lock feature..
Oct 06, 2010 | Maytag EPIC MFW9700S Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Epic z front load washer will not start
Maytag service came out and told me it is control panel Part# W10217425. I washed 4 loads 1 day and came back 4 days later and got 1 load done. Then it wouldn't start and they won't replace. I got mine at Home Depot but, Maytag won't replace. They say it has to break 3 times before they will replace. After Maytag sent someone to fix and they said they had to order part and didn't know when they would be back. I called Home Depot and they overnight sent me part. Now Maytags service says they cant come back for a week and if I put in myself I lose my waranty. If you don't have waranty anymore, I found at Sears parts for $12.45 for board.
Feb 01, 2009 | Maytag EPIC MFW9700S Front Load Washer
My new Epic Z is only one month old
Dec 30, 2008 | Maytag EPIC MFW9700S Front Load Washer
Machine stops mid cycle
Replace your control button(Start button).
Jul 22, 2008 | Maytag EPIC MFW9700S Front Load Washer
Control locked light on
The button on my Epic version is called the "Cycle End Signal" button.  I pressed it for 3 seconds and the "control locked" light went off and the washer started.  This button is on the far right, just like premm said, near the "Off" button.
May 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic
the control board has loose solder connections around the relays.
see this
diff model same issue with new boards as they make them all.
http://www.fixya.com/support/t364216-whirlpool_duet_ht_ghw9400pl0
being it is in warranty its too early for you to fix it yourself.
you will have to wait for them to come out and say the parts are on backorder.
Feb 04, 2008 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPICz 3.7 cu. ft. Washer Logo
1,030 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
