Question about Microsoft Windows XP Professional
RUN DLL ERROR
RUNDLL ERROR
Error loading C:\Windows\System32\qefoqowx.dll
the specified module could not found
how solve this problem
  • brharishkuma Jan 20, 2009
    when i loged on secssfully next i got rundll error
    Problem Solver:
  • 5 Answers
IF YOU HAVE ANOTHER COMPUTER IT WOULD BE EASIER, IF NOT YOU WILL HAVE TO PRINT OUT THE INSTALLMENT DIRECTIONS FOR ELIMINATION OF THE ERROR PROMPT. IT'S TIME CONSUMING SO IF YOU ARE IN A RUSH, FORGET IT.(UNLESS YOU ARE A COMPUTER GEEK) :) YOU WON'T BE ABLE TO ACCESS WINDOWS FROM THE COMPUTER WITH THE ERROR, GO TO ANOTHER COMPUTER, PULL UP WINDOWS SUPPORT, THERE'S A SECTION THERE FOR ERRORS, IF YOU DON'T SEE IT RIGHT OFF, JUST DO SEARCH ON THE LEFT HAND SIDE BAR, "DLL" OR "ERRORS" ANY OF THESE WILL PULL UP YOUR FIX. PRINT 'EM, APPLY, AND YOU'RE UP N RUNNING!!!
Posted on Oct 24, 2008
It gives messsage for dll missing.
From what i have read, this is malware, a trojan.
You need to get rid of it.
Run a program like Malwarebytes in safe mode (F8 on boot, choose safe mode with networking) also run with system restore OFF, lots of malware and viruses hide there.
Follow this guide....
http://www.fixya.com/support/r5272277-secure_clean_computers
Jul 27, 2010 | Microsoft Windows Vista Ultimate with SP1...
When I start up Windows XP I get three error boxes each of them say: Rundll Error Loading C:windowssystem3whnoherd.dll Rundll Error Loading C:windowssystem32cryakfuvzxugjh.dll Rundll Error Loading...
Rundll.exe files are systems process directly related to your computer's Windows Registry All Dll files are a part of vast library that contains code and data that is shared by many programs. This helps to produce speed and memory efficiency in your operating system by reusing the same code or file to run many functions by various programs. An error occurs when program aren't allowed to access this code.
Now, if you able to access the XP in safe mode, You could go to :-
Start > Programs > Accessories > System Tools > Restore.
Select a restore point and it's all done.
Unless, the only User Fixable option is to Repair the Windows. Put the XP disk in tray and run Repair. Once repaired, it would fix the problem.
Let me know, if needed assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 08, 2009 | Microsoft Windows XP Home Edition
RUNDLL
The first thing you must do is to identify the specific rundll process. This is not a difficult task; there is a vast online process library in which you can evaluate the validity of the process that is running. When the error dialog box opens make not of the process name. For example if the dialog pops up and shows you the dll error:
Error loading C:WINDOWS\ system32\ usvdgpo.dll
Visit www.processlibrary.com. Copy and Paste the dll or simply type it into the search box. The results will indicate that the program is a part of trojan spyware.
STEP 2: STOP THE PROCESS
Often you can locate the Run Dll in the exe services. You can open up your services configuration by following instructions below:
1. Open your Start menu.
2. Click Run
3. In the command screen type:services.msc
4. This will bring up the Services Management window. If you drag the mouse to one of the services. It will give you a detailed explanation of the service in question. By right clicking the individual service.
5.Stop the "dll"service immediately.
STEP 3: LOCATE AND DELETE
You will have to open your Windows Registry File System. This is an extremely delicate process. You may want to use a good registry cleanerThis will often fix the dll error in question, eliminate other errors and also speed up your computer. The registry key: HKEY_LOCAL_MACHINE> SOFTWARE\ Microsoft\ Windows\ CurrentVersion\ RUN
This action will help you speed up your applications load times considerable. Here is how:
1. Click Start
2. Click Run
3. Type regedit
4. Find this registry key:
5. In the right section click:"rusvdgpo" = "%System%undll32.exe %System%usvdgpo.dll, [RANDOM LETTERS]"
6. Delete the value and Restart.
May 01, 2009 | Computers & Internet
I get pop up blockers on my computer every time i turn it on.
you have virus (melware) on your machine. do you have any type of anti-virus program on the machine/ if so, please run it. if not, go to vga.com and download the antivirus software, and run it.
Apr 08, 2009 | HP DeskJet 3000 Printer
RUNDLL
It appears that a program has been removed (not uninstalled) from the computer and XP can no longer locate the removed files while references to the files still exist. So, we need to find what is referring to this file. The easiest way would be to download, install and run a registry cleaner such as CCleaner (from www.download.com), but this can also cause more problems than it solves. The other way is to use the msconfig utility to disable all of the extras that are loading and then enable them one by one and rebooting each time until the problem appears again. Then just disable the last one enabled (that caused the problem to reappear), and continue on until all other programs and processes have been reenabled.
Apr 07, 2009 | Microsoft Windows XP Professional With...
Error message rundll on startup
Looks to be a left over file. Probably not needed - this happens when you delete a program, but other files remain. Go to start button - click on search - click on all files and folders type lumejeji.dll in the top box - hit the search button
it will find the file - you can either drag it to the recycle bin or right click on the file and go down to delete and left click that.
Should fix your problem
HOWEVER
I just looked this .dll file up - Here is what I found - you may want to delete the file and run a virus scan as well
hope this helps
UMEJEJI.DLLFraudulent Security Program Your PC is infected. The file called LUMEJEJI.DLL is considered unsafe and there may be other infections on your PC.
You should urgently check your PC and remove any malicious software including LUMEJEJI.DLL as soon as possible.
Dec 30, 2008 | Dell Dimension 4600 PC Desktop
M3plugin.dll
When I start My PC the RUNDLL error occursError loading C:\program~1\Mywebs~1\bar\1.bin\m3plugin.dll The specified module could not be found.  Solve my this problem as soon as possible.
Aug 26, 2008 | Computers & Internet
RUN DLL ERROR LOADING C:/windows/system32/OVTFboot.dll The specified module could not be found
Most times DLL errors arise from a file being corrupted on your hard drive and there's a relatively easy fix for it.
the best solution is to re-install the drivers for your specific printer either from the disc provided by the manufacturer or from a downloaded file from the manufacturer's website.
Jul 01, 2008 | Office Equipment & Supplies
Microsoft Windows XP Professional Logo
152 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
