Question about Hobby Products International Hpi Savage X 46 Rtr 18 Scale Nitro Monster Truck
Hi i have a hpi savage x 4.6 big block and having problems with throttle servo
I have a hpi savage xs flux and when I shut off my controller before the truck it goes backwards how do i fix this ?
I have had an HPI drift car that would do the same thing. I tried recalibrating the ESC and it didn't help for me. I would start by trying that first.
Jul 12, 2015 | Goes Motorcycles
Savage xl 5.9 clutchbell keeps striping and or the teeth bend any solutions
Replace BOTH gears and make sure there is a little play in tooth contact!
Jan 31, 2014 | Savage Xl 5. Rtr Nitro Monster Truck With...
Transmitter on the savage x does not respond, truck goes out of control on it own
Well first thing to try is always batteries... get some good alkaline ones where needed and charge the rechargeable ones as needed.
There may be interference in the area - like a baby monitor, a wireless door bell... even though they shouldn't - a cheap neighbours Wifi security camera can send out all kinds of signals -
try again in a different location - fairly far away.
Also possible you were shipped a transmitter with the wrong frequency band for the truck - usually they come in several frequencies so you can run two or more together - see if there is a setting on the transmitter and truck to switch both to same frequency.
Dec 14, 2013 | HPI Racing 1/8 Savage X 4.6 RTR Truck with...
I have an HPI Savage 25 nitro truck and it won't
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 14, 2012 | Cars & Trucks
I repaced all the arms and now i am having problems getting the toe in correct
make sure its lines up with rode to tire with groove from inside tire to the arm.
Feb 18, 2011 | Hobby Products International Hpi Savage X...
Hi i have a 09 r1 code 12 and 60 showing i have tried everything check all points from service manual .... Please i need help
Error code 12: CRANKSHAFT Position Sensor >>> It could be the sensor itself, but I'd check all the wires and associated connectors that run from it to the ECU and check any that pass very close to the fan blades as it has been known for them to catch on them and become damaged.
Fault code No.: 60 Symptom: Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system). Probable cause of malfunction: •Open or short circuit in wire harness. •Defective throttle servo motor (potentiometer circuit). •Stuck throttle servo motor (mechanism). •Stuck throttle servo motor (motor). •Malfunction in ECU. Diagnostic code No.: 01
FIRST thing to do is CHECK the ETV Fuse - 7.5A I think - This might NOT be in the main fuse box.
Hope this helps
Jul 13, 2010 | 2007 Yamaha YZF-R1
What does code 60 mean on my r1 the battery died and a 60 showed up on guages and now it wont start with a new battery
This is from the service manual.
Fault code No.: 60
Feb 17, 2010 | 2007 Yamaha YZF-R1
My 2008 yamaha r6 will not start fault code 60 is coming up on dash how can i fix this problem
Fault code No.: 60
Feb 17, 2010 | 2008 Yamaha YZF-R6
4sp - 5sp interchangeable gearbox internals?
Hi, Gregoryian my full name is Gregoravitch for this situation I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Suzuki LS650 Savage Service Repair Maintenance
OEM parts for Suzuki
http://www.savageriders.com/verslagen/transfer/2002_LS650P_Owners_Manual.pdf
Suzuki LS 650 Savage 1997
Suzuki LS650 Savage model history
Apr 10, 2017 | 1997 Suzuki LS 650 Savage
Hobby Products International Hpi Savage X 46 Rtr 18 Scale Nitro Monster Truck Logo
37 people viewed this question
Top Hobby Products International Toys Experts
ray gallant
Are you a Hobby Products International Toy Expert? Answer questions, earn points and help others
