How do i fix error code c d251 for Bizhub c300
  • MIRONDO FRED Feb 12, 2012
    what might have caused that problem?
taminol
  • 62 Answers
SOURCE: error code C-D251
Hi, the definition of CD251 is
• JPEG board (Scan accelerator kit) is not mounted when the JPEG board mounting is set ON at
Service Mode.
Has this mode been turned on even though no Scan Accelerator board has been fitted?
It's an unusual code to get. Has anyone been playing with the settings ?
Posted on Feb 07, 2009
taminol
  • 62 Answers
SOURCE: when I turn on the machine (bizhub c300) error
This is a fuser related code.
To reset the code, please do the following
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch Trouble Reset.
4. Check to make sure that OK is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
Good luck
Posted on Jan 29, 2010
  • 19 Answers
SOURCE: imaging units for Bizhub C300
There is no setting you can extend the life, however, in the service mode ( utility->meter count-> stop, 0, 0, stop, 0, 1) then press stop, 0, c. There should be a setting in there that you can disable the "image unit life end stop" setting. You will get a message every 5 minutes telling you to change the unit, but your machine won't stop working. Otherwise you can just change the chip in the image unit.
Posted on Jul 28, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: We have an error message
C5102 means that your main drive motor is not turning when it should. This could be as simple as a loose power connection on the motor but that would be very un-likely. Most often this code is caused by something in the machine that is turned by the main drive motor has beccome stuck or has "frozen". This causes the motor to not be able to turn as it should. If turning the machine off then back on does not reset the code and restore the machine to operating condition then you will need a service technician to come out and determine was part has locked up.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 12, 2010
  • 60 Answers
SOURCE: Bizhub C300 error C8103
To improve paper-feeding in the paper take-up section of the document feeder some adjustments have been newly made. Please ask a technician for this updates, but the error code suggest binding in the lift motor (may need to be replaced) or the lift plate is not producing enough pressure.
Posted on Feb 25, 2011
Error code c-d251
Machine is being told it has a scan option but it does not have it or vice versa. did you get a scan option with the machine and or it was remove and that person did not reset the machine to reflect that.
Jul 11, 2015 | Konica Minolta Bizhub C253 With Document...
How to rest a C3452 error code on a minolta C300
try a trouble reset turn the machine off hold utility/counter power machine on select trouble reset reboot machine
Aug 17, 2014 | Konica Minolta Bizhub C300 All-In-One...
Trouble code C-D251
JPEG Board is not installed but the machine believes it has one due to being set in service mode as having one. Have Technician look at it. Power on off to clear. Scanning issue.
Mar 15, 2014 | Konica Minolta Bizhub C550
Error s-d251/s-d366/s-d370/bishup c351
NVRAM kind like computers BIOS. Data multiple errors. Need a tech to come out and re-flash the copier firmware not the drivers. the firmware is only available thru a secure Konica Minolta server. or the NVRAM CHIP is bad worse case so is the board. And it is C-D370, C-D366, and C-D251 which deals with Image control board. it to mite require its firmware re-flashed.
Jan 30, 2014 | Konica Minolta bizhub C351 All-In-One...
S-d366/s-d370/s-d251 error
Sir,
Jan 30, 2014 | Konica Minolta bizhub C450P Laser Printer
C- d251 error
In konica minolta copier not exist d251 error code.Read correct the error code and specify the copier model.
Mar 05, 2013 | Konica Minolta Bizhub C550
How do i fix error C-D251 for Konica Minolta Bizhub 3 in one Printer?
Check option setting in service mode (system 1 or 2 I not sure) turn off jpeg option, reboot.. maybe a failed jpeg board if installed or some other glitch.
Mar 19, 2012 | Konica Minolta bizhub 200 Printer
Jan 15, 2011 | Konica Minolta Bizhub C300 All-In-One...
When I turn on the machine (bizhub c300) error code c3452 appears, within 20 secs, How do I reset this code
Good luck
Jan 21, 2010 | Konica Minolta Bizhub C300 All-In-One...
Error code C-D251
Service Mode.
Feb 04, 2009 | Konica Minolta bizhub C250 All-In-One...
46 people viewed this question
k24674
jasbo
jasbo
