Question about Siemens Microwave Ovens
Siemens microwave oven HB86K.70B COMES UP WITH E10
KEEPS FLASHING A E10 AND THEN I HAVE TO PRESS STOP
4 Suggested Answers
  • 132 Answers
SOURCE: Microwave clock and duration won't set
Good Morning,
Unplug the oven and wait 3 minutes then plugit back in and check to see that it operates normally. Do not run the oven empty - place a cup of water in it. Let me know if this helps and thank you for using FixYa!
Posted on Mar 30, 2009
asnowman
  • 788 Answers
SOURCE: Set clock time on microwave oven
I have consulted the Owners Manual and there is no mention of the demo mode. I would suggest that you unplug the unit or disconnect power if it is hard wired in, and try to set the clock then.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Jul 04, 2009
j2easy
  • 152 Answers
SOURCE: microwave oven fmv145 press clock please flashing
You need a new control board. not hard to repair but it be about even to get a
new unit... take it to a repair shop and will be more than a new microwave and use a a small surge protector for the microwave. cheaper than a new ckt, board next time.
Posted on Oct 17, 2011
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
Does not turn on all the numbers on panel are zero's and blinking, did try unplugging still nothing
Flashing zeros are a sign of a momentary power loss. Usually you also get a Pf error also. Not always....
Try this and if it does not work let me know.
Press Stop / cancel
Press clock
Set time
Press clock
Attempt normal use.
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Sharp R-209HK Microwave Oven
Siemens microwave child lock model number hf25c530. We cannot unlock the mocrowave
Unless there is a fault with your microwave, simply press SETTINGS, then 5 then 2 to switch the child lock OFF. To switch it back ON press SETTINGS then 5 then 1.
Feb 09, 2011 | Siemens HB77L55GB 900 Watts Convection /...
Flashing dispaly of 4 eights, with no response from keypad
First check all door switches are properly working. If they are ok , the defect may be in the key pad. You need to replace the key pad.
May 26, 2009 | Sharp R-510HW Microwave Oven
Good Morning,
Mar 30, 2009 | LG Microwave Ovens
GE Spacemaker oven keeps flashing "message - hit button for messa
If you have an "options" pad, press that and you should be able to get to the message sub-menu. If not, you may have gotten too much moisture in the key pad when you cleaned it and it will either need to be replaced or might possibly return to normal after drying out completely for a few days
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Start button
I have a related problem, my Siemens microwave/oven as soon as I press the start button brings down the fuse. I put up the fuse again, the clock is working, the light inside as well, but as soon as I set the microwave on and press the start button, it brings the fuse down again. Is this a problem with the siemens microwave or with my electrical installation?
Jan 09, 2008 | Microwave Ovens
Microwave Ovens Logo
154 people viewed this question
Top Siemens Microwave Ovens Experts
William Miller
William Miller
Steve
Gerry Harvey
Gerry Harvey
Are you a Siemens Microwave Oven Expert? Answer questions, earn points and help others
