Question about Nintendo Video Game Consoles & Games
Wii fit balance board not being recognised by console.
Had the same problem at first. We bought lithium batteries to replace originals and then re-synced. Hope this helps.
Posted on Oct 24, 2008
How to connect wii fit board to the wii
Important Note!
Do Not use "One-Time Mode" sync.
Syncing can be completed only if a compatible game disc is running in the console.The Wii Balance Board may need to be synced to each compatible game individually.Some games may require you to go into a specific screen to sync the Wii Balance Board.These sync settings will be saved even after the console is turned off.
1. Insert a Wii Balance Board compatible game disc in the Wii console.
2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game.3. Open the SD Card slot cover on the front of the Wii console.4. Remove the Battery Cover on the bottom of the Wii Balance Board.
5. Press and release the SYNC button on the Wii Balance Board. The Power LED on the board will start blinking.
6. Press and release the SYNC button on the console while the Power LED on the board is still blinking.
7. The Power LED will stop blinking and light steadily once the synchronization is complete.8. Replace the battery cover and return the board to the normal operating position.
Nov 16, 2011 | Nintendo Wii Fit for Wii
My wii fit was working perfectly fine when i purchased it, then about a month or so later the wi fit game didnt recognise the balance board, so when it said please turn the power button on and i did, it no...
When you power on the wii fit board, does the light flash continuously? If so, you will need to sync your board with your wii again. You can get instructions on how to do so here: http://www.nintendo.com/consumer/systems/wii/en_na/ts/balanceBoard.jsp
Mar 22, 2011 | Nintendo Wii Fit - Balance Board + Game...
How can i re connect the wii fit balance board to my wii ?
Synching can be completed only if a compatible game disc is running in the console. Compatible game discs (such as Wii Fit) will display the Wii Balance Board icon on their packaging.
The Wii Balance Board must be synced to each compatible game individually.
Follow these directions to sync the Wii Balance Board (so that it is recognized by the Wii console):
Insert a Wii Balance Board compatible game disc (such as Wii Fit) in the Wii console.
Mar 16, 2011 | Nintendo Wii Console
How do you sync the wii console and wii fit board
Put the Wii Fit game disc in the Wii and start the game. Then open the small SD Card slot cover on the front of the Wii console then remove the battery cover on the bottom of the Wii Balance Board. Press and release the SYNC button on the Wii Balance Board. The light on the board should start blinking. Afterwards press and release the red SYNC button on the Wii console while the light on the board is still blinking. The light on the balance board will stop blinking and stay on steady once the syncronization is successful.
Mar 03, 2011 | Nintendo Wii Console
How do you sync the wii fit board and wii console
  • Put four AA batteries into the battery housing located on the underside of the Wii Balance Board.
  • Insert a Wii Balance Board compatible game into the Wii system.
  • Select the "Disc Channel" on the screen with the Wii remote, and choose "Start."
  • Open the SD card slot to reveal a sync button on the Wii system. This is located behind a cover under the power and eject buttons.
  • Turn the Wii Balance Board upside down.
  • Remove the battery cover under the balance board to reveal another sync button.
  • Pres the sync button on the balance board, then press the sync button on the Wii. Do not hold down the buttons. You know it is synchronized when the blue light on the Wii Balance Board stays steady
  • Place the board on a flat surface directly in front of the TV. Face the power button away from the TV.
  • Mar 03, 2011 | Nintendo Wii Console
    Blance board asks you to step of and press A when no one os on the board
    Its supposed to do that to setup and recognise it properly theres nothing wrong with it.
    Jan 04, 2011 | Nintendo Wii Fit - Balance Board + Game...
    Wii FIt Battery Problem
    The places are not the batteries in the wiifit balance board. Rather they indicate the power left in the batteries in each peripheral. The Balance Board automatically sets to port 4 and the port 1 is for your controller, if you hook up additional controllers they will be in port 2 & 3.
    Jan 02, 2009 | Nintendo Wii Console
    Power led light
    If there is no reason for the Wii Balance Board to be on, it will automatically turn off. Start up a game that uses the Balance (Wii Fit) and it will tell you when to turn on the Wii Balance Board. If you still have problems, try to sync the Balance Board again.
    Aug 29, 2008 | Nintendo Wii Console
    Video Game Consoles & Games Logo
    96 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
