Question about HP 2009M Monitor
What does dvi mean - HP 2009M Monitor
    President:
  • 846 Answers
Hello figment_of_u,
DVI stands for Digital Video Interface. They are used for direct digital connections between source video (namely, video cards) and LCD monitors. This provides a faster, higher-quality image than with analog, due to the nature of the digital format. All video cards initially produce a digital video signal, which is converted into analog at the VGA output. The analog signal travels to the monitor and is re-converted to a digital signal. DVI-D eliminates the analog conversion process and improves the connection between source and display.
Hope this helps you understand what DVI is for. Thank you for choosing Fixya.
Posted on Feb 13, 2012
How do i solve problem of power save mode?
that typically means there is no signal coming in to the monitor. You could have a defective dvi cable or dvi port. Try another PC with DVI output and see if it works. If SO, you have a bad dvi port on the pc. If NOT, try another cable. If you tried another cable and it still fails, you could have a bad screen. Check your warranty coverage if it is bad to see if you can get it replaced.
Oct 09, 2014 | Dell E2011H Monitor
Does my 42pfl796 have a vga connector
Do you mean Philips 42pfl7962?
just look behind your tv if theres a VGA or DVI slot, if DVI you might need to use a DVI to VGA converter plug.
Hope that gives you an idea...
Jul 20, 2011 | Televison & Video
Hi there, I'd like to connect the Acer S202HLBD 20"" LED Monitor with a Mac Mini which cabling would I need?
It all depends on what kind of PORT connection you have on your MAC either VGA or DVI. If your Mac has VGA port then you need to use the blue cable that comes with your Monitor when you bought if you have DVI then you need to connect the white cable.
How to know if you have VGA or DVI or BOTH.
1. Check the sides of you mac and see if you have a blue port. Blue port means you have VGA port
2. IF you have white then that means you have DVI
3. IF you have both then you just need to use 1 connection. I prefer DVI since its digital.
Your feedback is greatly appreciated. Thank you for using FIXYA.
Apr 23, 2011 | Computers & Internet
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
My viewsonic mo9nitor says analog not digital on
To clarify, you know that analog is referring to the VGA 15 pin video input, and digital is referring to the DVI video input, right? You can't have the digital video unless you use the DVI input, which requires a DVI output from your computer (and a DVI cord of course).
If you already knew this and you mean that it won't switch over to your DVI, then there could be several problems. Most of them being with your DVI signal source (computer). Try booting the PC with ONLY the DVI cord attached between the PC and the monitor. If you have a VGA cord plugged into either, UNPLUG IT FROM BOTH ENDS.
Dec 05, 2009 | ViewSonic Computers & Internet
What is the exact mane of the DVI to VGA adapter needed for dell optiplex GX 240?
Sorry, but what do you mean with mane (can't find a correct translation to dutch)
Do you mean advantage, or do you mean what you can do with it?
Normally a DVI to VGA adapter can be used to connect a display with a VGA connector to a DVI port. If you have 2 ports VGA and DVI, maybe you can connect 2 displays to your pc. It's great working with multiple displays, making your desktop twice the size. For example: you can open your mail program in one display and your web browser in the other.
Jul 22, 2009 | Dell Computers & Internet
I have a new graphics card and the connections dont match
the motherboard might be VGA, and the card PCIE, the connectors will not match, more info is required, better still check motherboard specifications, and look for the right type of graphics card.
Jan 25, 2009 | Computers & Internet
2232bw samsung DVI in problem
There is nothing broken, but you must become aware of the different standards in DVI connectors.
1)DVI-D which you have, does not have the 4 analog control pins around the alpha bar meaning it only works on digital devices.
2)DVI-A only has the 4 control pins and no bar, as well as a total of only 9-10 pins altogether. This is designed for analog only, and rarely see it anymore.
3)DVI-I stands for Interlaced, meaning it can work both ways, but will not fit in monitors that are set up for DVI-D because the analog pin sockets do not exist.
You can get more detailed by counting the pins in the rectangular area, if you use all 24 pins you have what is called a Dual-Link cable, so it can support resolutions over 1920x1280 if you have about 9 pins missing it is single-link and is limited resolution.
Jun 08, 2008 | Samsung 226BW Monitor
Flat Panel Insignia 19
Lets see the cableing..
So you have a mac with a mini-dvi slot, you have a mini-dvi to dvi adapter, and then Dvi to vga adapter which connects to the tv?
The mini-dvi to dvi adapter doesn't have the analog VGA signal your tv needs. If I understood right.
Apple's mini-DVI to DVI-D cable does not carry the analog signal coming from the mini-DVI port on the Apple computer. This means that instead of buying a single mini-DVI cable from Apple and using a cheap DVI-to-VGA adaptor when you need VGA output, you must purchase another mini-DVI cable from Apple.
May 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Hooking up a HP L1755 17
What is the way to get the very best picture quality when hooking up my new HP L 1755 Flat Screen Monitor to my E-Machine W3052 which is about 3 years old.First would it be compatible or the best idea to hook up VGA to VGA.DVI to DVI which means buying a new Video card for my Computer so the DVI could be hooked up to my computer, or hook up the DVI to VGA Connector ? Would a DVI Video card be worth the extra costs if I went that route ?This HP L 1755 only has a response time of 25 ms, is that good enough to watch Music Videos or not ? I do not do any gaming.Can you tell me the best detailed step by step way to hook up this monitor to my E-Machine W3052 Computer and which Connector to use ? If I need a DVI Card what would be the Part number or Card I would need to get ? Sorry about all the questions.Any guidance and input would be greatly appreciated since I have a disability and need some help and to be honest I do not have 50.00 for a DVI Video card. Sincerely & God Bless ! Thanks,Diehard16
Feb 18, 2008 | Computers & Internet
HP 2009M Monitor Logo
112 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
