Question about Water Pik Home
I have a Triton amber 2 electric shower with no hot water
  • Will Feb 13, 2012
    All fixed now. It was due to low pressure in the area (broken pipe)
    Top Expert:
  • Water Pik Master
  • 76,109 Answers
Great to hear.
Posted on Feb 13, 2012
  • 44 Answers
SOURCE: Triton T80si shower will not switch off
its the water solenoid valve stuck in the open position so when the shower is turned off the shower stays running
Posted on Dec 15, 2008
meBNme
  • 334 Answers
SOURCE: electric shower is not getting hot
Locate your electrical panel box, find the breaker for the water heater, turn it off then back on, locate the water heater. Fins the powere disconect. Sometimes they are a simple pull disconect or switch, sometimes they are another breaker or fuse.
Check the fuses or flip the breaker if aplicable.
Do you have a volt/ohm meter?
Posted on Dec 06, 2008
  • 44 Answers
SOURCE: triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
  • 44 Answers
SOURCE: triton electric shower runs cold
hi it sounds as though the thermostat has gone on top of the can assembly, or moreover it has scaled up & the element needs replacing, if thats the case your better off buying a new unit as the cost of the can assembly & the fitting it will be nearly as much, plus witha new unit you'll be getting a 2 yr guarantee?
Just a thought!
SOURCE: my new triton shower keeps dripping when switched off
The actual cause of this will depend on what type of shower unit this relates to - ie Mixer Valve, Electric Shower etc.
Generally though if the unit is new and therefore under the manufacturers warranty period the best course of action would be to contact Triton Service Dept direct - Tel 0844 980 0750 where a in warranty service visit may be arranged for you.
Posted on Jul 28, 2010
Testimonial: "thanks will do !!!!"
Triton cara shower has power and water to it but nothing comes out
CHECK YOUR POWER SUPPLY BOX MAKE CERTAIN THAT IT IS INDEED ON IF SO IT MAY BE A BAD CIRCUIT BRAKER MAY NEED TO REPLACE IT.
Apr 15, 2014 | Camp Chef Triton Hot Water Shower Heater
Triton showers after runs hot then after a while goes cold
Is it possible that you don't have enough water pressure, electric shower heater elements will cut out if the water pressure gets too low, try increasing the water flow.
Apr 13, 2014 | Kitchen Appliances - Others
The water flow from my triton electric shower does not stop even after unit is switched off
28487001 is not an electronic shower head made by Hansgrohe. It is an overhead shower head that has no electronic parts. Triton is a completely different company. If you have an electronic shower system by Triton you will need to contact Triton. If you have a Hansgrohe product feel free to contact Hansgrohe at 1-800-334-0455.
Apr 13, 2013 | Hansgrohe Showerhead Shower Power ...
My triton shower won't turn off and has no hot water
Your supply pressure is too high for the unit, it is too much for the solenoid to shut off, you need to put a pressure limiting valve inline.
Mar 10, 2012 | Home
My Triton (Jade) electric shower has abruptly stopped supplying hot water. The pressure appears unchanged and altering the temperature control dial has no effect on the heat. Is it likely that, if needed,...
I have a Triton Ivory 111 shower, twice this week the water as just stopped flowing mid flow, presure ok and power still on what could be the trouble??
Stew.
Apr 05, 2010 | Home
Triton electric shower runs cold
Just a thought!
Dec 01, 2008 | Home
TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Mar 27, 2008 | Dishwashers
Home Logo
377 people viewed this question
Top Water Pik Home Experts
Donni Steen
Are you a Water Pik Home Expert? Answer questions, earn points and help others
