Question about Electrolux Washing Machines
Ewg 14440 w washer not spinning properly
Is washing ok though
jsrock516
  • 5911 Answers
SOURCE: Spin Cycle on Wash Machine does not work
The problem is your lid switch. This is a common problem with this model washer, and a very simple & inexpensive problem to fix. Click on the following link for advice on how to replace:
http://www.fixya.com/support/r385198-replacing_lid_switch
You can find a replacment switch at searspartsdirect.com. Just type in your model number and look under the "Cabinet Parts" heading on the next page. I believe thats the heading the part is listed under. Sears has excellent part locator drawings to assist you in identifying the part. Once you have the part number identified, you can do some comparative shopping at other online websites too. Use the part number that Sears provides, however. A new switch usually runs about $25 to $35. In addition, make sure you check the lid strike. This is a small plastic piece on the lid that is used to activate the lid switch through a small slot. If the lid strike is broken off, it will give the same symptoms of a defective lid switch. I hope this information helps you. Please post back if you have any questions.
Posted on Aug 04, 2008
  • 117 Answers
SOURCE: will not spin
If the motor is not running, it could be a faulty timer. If the motor runs, it could be the transmission. Check to make sure the pump belt is ok and the pump pulley is not seized by tilting the machine back and checking.
Posted on Feb 26, 2009
  • 88 Answers
SOURCE: Trouble getting spin cycle to work properly
computor module
Posted on Jun 05, 2009
JULIANFIX
  • 975 Answers
SOURCE: Washer stops after wash cyle
need to check out the DRAIN MOTOR PUMP located at the bottom side , the motor with the propellers , it could be clogged , get some rags and remove PUMP to remove any lint or debris , replace and give it another try , hope it helps AJ
Posted on Sep 18, 2009
SOURCE: Electrolux EWX 14440 W Washer will not start
This sounds like what I am having. Machine tumbles but does not rinse. Some postings say this is the door lock problem. Google "Fridigdaire washer will not Spin" and page down to read solutions.
Posted on Oct 26, 2009
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
Mar 14, 2014 | Kenmore HE3T Washer
I have a 5.5kg Simpson Ezi Sensor SWT552 Washing Machine. The lid locked light keeps flashing and the machine keeps beeping during the spin cycle - even though the lid it down properly. Could you please...
yes the safty door latch switch is eather loose or going bad. somewhere on your door there is a small sensor or switch that tells the washer the door is closed and its ok to spin, these washers put out alot of force when spinning and thats why the sensor is there it would be dangerous without them. when the washer goes in spin cycle there is more vibration than any other cycle. and thats whats making the sensor or switch wiggle and its getting an intermedate signal. it probily needs replaced these can commonly go bad due to wear buy slamming the door on the washer.. i hope this helps
Sep 09, 2011 | Washing Machines
WASHER WILLNOT SPINOUT
Usually when this occurs the lid switch has failed, even though it may seem ok
The lid switch is a safety device for the spin cycle. When it breaks the washer will
still agitate and not spin out. Hope this helps.
Jun 26, 2011 | Frigidaire CWS3600AS Top Load Washer
Oct 24, 2009 | Frigidaire ATF6000ES Front Load Washer
Sometimes my washer does not do a full spin but every time i get the man out it works ok and he says there is nothing wrong
you may just be overloading the machine when you wash. it's based on time, so if you have too much in there for it to spin out properly, it'll appear as though it hasn't completely spun out
Aug 26, 2009 | Washing Machines
Drum not turning
Problem sorted, motor is brushless and tested ok. Traced problem to statup capacitor, no circuit across terminals, will be relatively cheap fix
Jan 21, 2009 | Hoover AAA160 Front Load Washer
Washer go though all cycles but no spin
the motor operates off the timer cams inside the timer. in the wash mode the agitator turns in one direction. when it calls for tub empty the motor reverses direction and actuates the pump. at this stage the tub should spin. sounds like the timer is bad for this one function. timers cost around $120. (mechanical timers)
Aug 22, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
88 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
