Question about Canon MP640 All-In-One InkJet Printer
Printer canon pixma ip4870 error c000 how do you do
SOURCE: canon printer displays error
CANON
PIXMA MP450
Discharge of the code of the error of the overcrowding of sump - "pampersa"
1. You will turn off printer.
2. retaining button Resume/Cancel (red triangle in the circle) press button POWER - indicator it will catch fire by green color.
3. you will let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which you will let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times!
6. you will turn off printer by button POWER.
Posted on Dec 06, 2007
SOURCE: Canon PIXMA MP140 error code E 2
error E 2 => The machine is out of paper. / Paper does not feed.
Reload paper in the Auto Sheet Feeder and press the Black or Color button.
Posted on Mar 02, 2008
SOURCE: Service error 5100 on my canon Pixma mp110
Had the same problem, i just replaced the black ink cartridge which was finishing at that time and resetted the counters. No problems after that. Not sure whether this will help though.
Posted on Aug 31, 2008
  • 412 Answers
SOURCE: Canon Pixma MP830 error 5100
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
pineworks
  • 4041 Answers
SOURCE: canon printer MP980 error code c000 what does it
HiHi this code is.
C000 indicates to remove the packing material.
Remove packing material so that the print head holder can move. Confirm that the printer
is powered off.
Disconnect the power cord from the printer or at the wall outlet or both
spacer.gif mp620_removepowercord.gif spacer.gif spacer.gif spacer.gifOpen the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray
Pull the orange protective tape (A) in the direction of the arrow and remove the white plastic (protective material) (C).
    spacer.gif mp980_packingbeingremoved.gif spacer.gif spacer.gif spacer.gif After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1. Close the scanning unit cover.Reconnect the power cord and then power on the printer.
    Found this code on the net hope it helps you.
    All The Best: Pineworks
Posted on Jan 31, 2010
Canon MX922 printer displaying code C000
Try switching printer off then unplugging the power for 15 or so minutes. If that doesn't work and same error pops up when you turn printer back on, contact Canon.
good luck
Feb 28, 2015 | Canon PIXMA MX922 Wireless InkJet MFC /...
Canon PIXMA MX920 error code C000
After market units do not send the proper signal as factory cartridges so put the AfterMarket ReMan back in, Un-Plug the unit for 3 minutes . plug it back in and maybe the computer will accept the reman, just will not show "quantity".
Oct 03, 2014 | Canon Pixma MX922
Canon mx860 - had an error code C000 and now a day later 306A
Error code C000. Cancel printing, and turn off the machine. Then clear the paper jam or foreign object that is preventing the Print Head Holder from moving.
For more information about the error code C000, can be read here Canon Support and Downloads
You read, the bottom of the page
Sep 23, 2011 | Canon PIXMA MX860 All-In-One InkJet...
I have a Canon MP980 and Im having trouble with it because when I try setting it up an error code apears that says C000.
It looks like you incorrectly inserted an ink tank
http://canoncanada.custhelp.com/app/answers/detail/a_id/11015/~/lcd-error:-error-c000
Feb 28, 2011 | Canon PIXMA MP980 All-In-One InkJet...
Canon MP640 All-In-One InkJet Printer Logo
162 people viewed this question
old marine
old marine
