Question about Dyson DC28 Animal Bagless Upright Vacuum
Rota blade not turning
Brushes not turning when engaged
  • Official Brand Answer
  • 2,572 Answers
Hi Craig,
I'm sorry to hear you're having difficulties with your DC28. Your machine is equipped with a safety device which shuts off the brushbar if something jams it. Once you've checked the cleaner head for obstructions, and removed any threads or hair from the brushbar, you should be able to reset the machine. The easiest way to do this is to follow the steps shown in the video below.
This should resolve the issue, but for any further assistance with your machine, please call us free on 1-866-693-9766 - or if you email us at askdysonUS@dyson.com, someone will be in touch as soon as possible to help.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Posted on Feb 13, 2012
No suction or brushes turning after auto shutoff
Make sure that there are no clogs in any of the hoses. Also, check any belts. Make sure that they are in place and they are spinning.
Nov 12, 2013 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover steam cleaner spin scrub brushes wont turn cant find belt
Two checks:
(1) Remove the brushes by pulling down on the two ends. Is the squaare drive pin present on top of one brush? It should be about 1/4 inch square, and two inches long. That connects the brush to the drive mechanism.
(2) Remove and clean the inlet filter. It is in a red panel, behind the brushes, under the cleaner. Squeeze the two panel tabs together, and pull down to extend from the base. Cleane the hair/debris from the filter screen.
Sep 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissel pro heat unit brushes will not engage
keep in mind they only turn when the handle is down. if that is not the problem, it is usually the belt.
David
May 24, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Brushes won't engage
sounds like the brush belt is broke
Feb 08, 2009 | Dyson DC15 All Floors - The Ball Bagless...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Brushes stopped
Most likely the turbine is bad, it may just be clogged up, you can take it apart and clean it out real good. That may work, but it may not. Sometimes it is best to replace the turbine.
Jul 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Hoover F7220900 Brushes don't turn
First off make sure that the filter inside the dirty water tank has a gap from the top of the cover to the top of the filter. The must comment problem when the brushes dom't turn is either the brush block, the shaft that goes into the turbinge broke off. If brush block is ok, then the turbine is bad and will have to be replaced.
Dec 16, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Dyson DC28 Animal Bagless Upright Vacuum Logo
154 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
