Question about Hoover Vacuums
Hi my Henry vacuum cleaner power button won't stay
  • 389 Answers
SOURCE: Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor.  Highly likely that you need new carbon brushes.  The smell is caused by excessive sparking between the worn brushes and the copper commutator segments.  Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed.   The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later.  When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course).  Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag.  This is false economy!  You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
Posted on Mar 01, 2009
wiringlunati
  • 576 Answers
SOURCE: bissell 5770 vacuum power won't stay on
It sounds like the power switch went bad mechanically (won't lock on)
Posted on Feb 28, 2010
  • 12650 Answers
SOURCE: Miele Vacuum Cleaner - burning smell / motor won't stay on
check brush the belt may have popped off and is binding or brush is binding clean brush of any debris thread/hair wrapped binding brush and check and or replace belt
Posted on Mar 24, 2010
VacuumRepair
  • 438 Answers
SOURCE: power switch does not work
Greetings,
Most likely your switch has gone bad, and you'll need to replace the on/off switch on your Dyson DC07. If you have to hold down the switch in order to keep the vacuum on, this is indicative of needing a new switch. Unfortunately this is very common problem on the Dyson vacuums. The switch that Dyson uses for their vacuums is one of the cheapest quality switches on any vacuum on the market today. The good news though is that this is not a extremely difficult repair to fix.
I took pictures of replacing the switch assembly on one of our customers repairs they brought in. It was having the same exact problem that yours is, it just wouldn't stay on. Here's how you can fix the switch on your Dyson:
- T15 Torx Bit Screw Driver
- Genuine Dyson DC07 & DC14 Replacement On/Off Switch Part 901181
- Needle Nose Plyers
- Patience (haha)
The switch above is actually a link back to our site if you have yet to purchase the switch yet. We carry most every Dyson part.
IMPORTANT: MAKE SURE YOUR VACUUM CLEANER IS UNPLUGGED BEFORE DOING ANYTHING ELSE!
Step 1. First thing you'll want to do is to unwrap the cord from the machine, and remove the handle from the upright part, then slide the hose all the way down the wand, and remove the hose from the handle assembly completely and set it aside. Also remove the dust bin assembly completely from the machine as well.
Step 2. Once you've remove the handle from the machine I find it easier to work on if you lay vacuum on it's back, with the switch button facing upwards. Now remove the T15 Torx bit screw that is directly below the switch actuator. I have circled the location of this screw in the picture below:
Step 3: After you have taken off the screw, you're doing to need to remove the switch box housing from the vacuum that the screw was securing. Simply use your flat head screw driver, and pry the two small arms upwards. Be careful when prying, the plastic components on Dyson vacuums are really cheap quality plastic, and I can't tell you how many times I have seen these plastic parts break when customers bring in repairs to us here at govacuum headquarters. Here's a picture of the location of where you should pry the switching off:
Here's what the vacuum should look like after the switch housing has been removed:
Step 4. Use your needle nose plyers to remove the terminals from both of the switch poles.
Step 5. Take out the new switch assembly. I find it the easiest to use my needle nose plyers to reattach the wires to the new switch, but it also can be done with just your hands. Connect both wires to your switch. If the cords have come loose while you have been working on the vacuum, you'll need to put the wires back into their proper places as well. This is how the switch and the wires should look like when you're done:
Step 6. Once the switch and cords are back to their normal places, simply put the switch housing cover back on, and screw in the one screw.
I hope that this repair was helpful to you, if you have any questions or have any problems, please feel free to use the clarification request form here on Fixya. If this repair was helpful to you, please be sure to rate the repair helpful by clicking the thumbs up icon in the top right hand coner. This is a nice gesture that will ensure that professionals will continue to post free repair solutions here on Fixya.
If you ever need any supplies for your Dyson, we do carry most parts and accessories on our site under our Dyson Parts Section .
Thanks again,
Chris J.
GoVacuum
Posted on Apr 03, 2010
aquaman987
  • 927 Answers
SOURCE: We all of the sudden have to hold the power button
It sounds like the actual switch in the unit has failed. The switch has a spring in it that keeps it in the on position then pushes it to the off position when it is hit again. If you can get to it, you'll be able to check it out yourself and Bissell will probably send you one to replace it.
Gary
Posted on Jan 25, 2011
Testimonial: "You're correct! I took apart the handle assembly, emailed Bissell describing the part I needed, & they are sending me the replacement part for free."
HENRY VACUUM CLEANER HI LO SWITCH BROKEN CAN I DISABLE IT TO STAY IN HI MODE?
It can be disabled to stay in high mode, but you need to know what you are doing. It basically involves removing the small PCB and connecting the motor wires directly to the on/off switch. The hi/lo switch can be left in place (although not connected) or removed and a blanking plate put in it's place. You can leave a hole as this is a potential hazard and against government regulations.
Feb 28, 2015 | Numatic Henry Bagged Canister Vacuum
Hi, I've got an Henry Hoover. I've got electric
TRY RUBBER GLOVE / IT WILL STOP ELECTRIC SHOCKS ,I AM A CLEANER AND IT WORKS FOR ME
Apr 09, 2013 | Vacuums
Vacuum won't stay powered without holding the button down.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Jan 26, 2013 | Dyson Vacuums
The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Nov 18, 2011 | Dyson Vacuums
My on off button won't stay pressed down so the vacuum won't stay running.
Hi Melissa,
I'm sorry to hear you're having difficulties with your DC17. If the on/off switch doesn't seem to be working correctly, it's best if you get in touch with us directly so we can help. You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 13, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
When i push the power button and let go it turns off and won't stay on. what might be the problem.
Sorry to hear you're having difficulties with your DC27. In case you haven't already tried this, make sure you press down firmly on the power switch when turning the cleaner on. If the switch still won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Aug 20, 2011 | Dyson DC27 Bagless Upright Vacuum
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
Vacuums Logo
602 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
