Question about Cooktops
I have a Sarena SK900CS. Can anyone suggest where I can replace a gas hob knob?
I have broken one of the gas hob knobs on my cooker. I can't find a replacement. Any suggestions?
  • 1462 Answers
SOURCE: Smeg SE64 Gas cook top
problem with hob is probably water ingress in area of ignition unit - will probably cure itself oven is a completely separate unit from hob. problem with it is that you have to re-set the clock - you have it on automatic. after power outage, oven clock always has to be reset
Posted on Apr 04, 2007
  • 222 Answers
SOURCE: injectors for hobs convert from LPG to natural gas
try to call wat brand u have to buy a injector for convertion,big different the injector for LPG and the natural gas,the LPG injector is small hole & the natural is have big hole.
Posted on Dec 02, 2008
  • 222 Answers
SOURCE: Ignitor will not stop sparking on AEG Electrolux Cooker Hob
gud day,try to clean the bottom of knob control by removing of knob then clean if by using a vacciumm,if u want to use manually ur cooktop unplug the unit to stop the cliking,then use macthes every time to on the gas cooktop.
Posted on Jan 11, 2009
  • 42 Answers
SOURCE: The oven on my gas cooker will light but wont stay lit
Thermo coupling needs changing, unless you are Gas Safe, let someone else repair for you, its a common problem, shouldn't cost much, good luck , the Yeti
Posted on May 20, 2009
SOURCE: Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
Posted on Jul 05, 2010
Took hob selecter knobs off to clean them but when I put them back one of them is protruding .Can you help.
ALL KNOB HAD A CLIP MAY BE ONE LEFT ON GAS VALVE .JUST TAKE IT OF & INSTALL IN SIDE THE KNOB THAN PUT IT BACK
Feb 17, 2015 | Cooktops
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
Aug 19, 2009 | GE Cooktops
Gas hob is permanently igniting
hi gud day,try to clean the area of knobs by using vacium,remove all the knobs firts then clean it,unplug the unit before u clean.
tnx gerbee
May 19, 2009 | De Dietrich DTG775X Gas Hob 22 in. Cooktop
Neff gas hob burner won't turn off
yes it is sad to say
Aug 23, 2017 | Cooktops
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
Jan 09, 2009 | Cooktops
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Apr 04, 2007 | Smeg 23 in. SE64 Gas Cooktop
Cooktops Logo
55 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
