Question about Philips 37PFL5332D 37 in. LCD Television
Philips 37PFL7662D/37 I have a blue power light but no picture. If i change tv to anologue i get sound but still no picture, changing channels gets different sound but still no picture
Problem happened when watching recording on a camcorder via the tv through the connection on side of tv. Is this a costly fix to repair?
ctf1800
  • 4402 Answers
SOURCE: philips lcd 37pf9431d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Posted on Dec 06, 2007
D_LLAMA
  • 6 Answers
SOURCE: NO POWER ON PHILIPS 42PF9966/37
I had the same problem with a philips 42FD9932 and fixed with a great online tutorial. Just replace 3 capacitors available at Radioshack onthe the board. 2662, 2663, 2664 1 is a 1000uf the others are 100uf. Max Volts need to be over 25. It worked great, check http://dynamicorange.com/2008/06/25/fixing-a-plasma-tv/
for more detail.
Posted on Mar 03, 2009
SOURCE: I Have a Philips LCD TV model#30PF9946D/37.
Oh yeah, you can most certainly change the power supply by yourself.
It's easy to locate - just follow the power cable - and easy to replace.
Only make sure to let it discharge before you operate it. 10-15 minutes disconnected from power should do.
However, there's no guarantee that the problem is in the power board.
There is a very good chance it is, in fact, not there.
There's another board which commonly fails on many plasma TVs and the effect is exactly as you describe. It's called Y-Sustain board and you can tell which one it is by looking at the side of your TV and seeing which large board has manny plastic connections that enter the display on the side.
That board often has one or two fuses on it - I'd check those first.
Posted on Nov 03, 2009
SOURCE: philips 50pf9631d/37 no picture sound. Red light flashing
hey crs246, I have the same exact problem with my philips tv same model. Have you gotten any help that you can share with me. Any help would be appreciated.
Posted on Mar 06, 2010
mace1mace
  • 1138 Answers
SOURCE: my philips lcd tv has sound but no picture what is
change the backlight (cold cathode light) on your monitor.. If you are able to open the back of your lcd monitor carefully, the backlights are located at the upper and the lower part of the edge .. replace it with conventional cold cathode lights(protective tube was removed)... there are also instances that backlight was good but the ballast transformer is burnt. Replace the ballast. Its very cheap to replace that.
Posted on May 18, 2010
My Philips 37PFL5332D 37 has a black screen when
ur problem is the inverter board , or bad capacitor on power supply
Apr 14, 2010 | Philips 37PFL5332D 37 in. LCD Television
Philips Model 50PL9126D\37 Turn TV on and after a
Ur LCD inverter board is dead,must change to get ur picture back.It usally a long board.
Jan 21, 2010 | Televison & Video
Philips 50pf9631d/37 no picture sound. Red light flashing
Dec 15, 2009 | Philips 50PFP5332D 50 in. Plasma...
17" Philips LCD TV has sound, faint blue flashes and blinking pwr
GP151001, Typically these cable/wire connectors fall into a catagory called HIGH DENSITY INTERCONNECT connectors or similar type. I should think that the whole assembly should be available somewhere ****!!! It's just this kind of thing that really gets me P.O.ed louie12fix
Apr 15, 2009 | Philips Epic 17PF9936-37 17" Flat Panel...
Finding Recording/Playing Channel on TV
Make sure there is a yellow video cable (or one of the other types of video cable) running from the Philips to your Panasonic. Make note of how the TV labels that source - Video 1, Video 2, Component 1, etc. Use the TV/Video button on your Panasonic to change the TV to the appropriate input channel - Video 1 or 2 if you used a yellow video cable, Component 1 or 2 if you used a red/green/blue cable, etc. Now, make sure that the Philips is in Disc mode by pressing the Disc button on the Philips remote. You should now have picture.
-Tha Mp3 Doctor
Oct 22, 2008 | Philips HTS-6500/37 System
42 plasma tv model42mf230a/37 blue light on no picture no sound
with solid blue led set could be still powering on but would need to verify by checking power supply voltages. if up and signal is present with no menu or audio would be ssb as audio amplifier, micro processor and eeprom are on that board. if voltages are not present you need to offload x and y sustain boards one at a time from power supply and check voltages and if vs comes up with either board disconnected replace that board
Jul 25, 2008 | Philips Magnavox 42MF521D/37 Television
60pp9100d/37 60" phillips
try to check the fuse,if its broken replace with the same value.
Mar 10, 2008 | Philips 60PP9352 60" Rear Projection...
Philips 17PF9936/37 17'' Flat HDTV slow to start working
mi tv turns on but only in color blue,next tv turn off red light apear one time and second time flash twice,whit mi remote control power on tv turs on ,then whit mi remote control send change chanes or any other funcion the tv turns off,letme now if you solve yor problem ,and i apreciate if you have some tips for me,thank.
Jan 09, 2008 | Philips Epic 17PF9936-37 17" Flat Panel...
Philips 37PFL5332D 37 in. LCD Television Logo
124 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
