Question about Ricoh Office Equipment & Supplies
What ius e11 in ricoh ft 3013 copier? - Ricoh Office Equipment & Supplies
NALDZ
  • 38 Answers
SOURCE: User manual for Ricoh FT 4427
I WILL GIVE YOU A MANUAL RICOH FT 4427 BUT YOU NEED TO PAY 100 US DOLLAR. EMAIL panlaqui08@yahoo.com.ph
Posted on May 07, 2008
fotobean
  • 103 Answers
SOURCE: On a Ricoh FT 4415 copier, what does error ''E2'' mean?
Hello,Check out this site and see if any of these error codes can help you: http://www.copier-help.com/copier-help/
Have you checked the power fuse? Or have you looked at the incoming power circuit board. Could there be any burnt resistors, blown capacitors, or bad voltage transformers?
Check things out because many times when a machine doesn't even power on (no lights, no life) - it's usually a sign of something blown - fuses, circuit board, lamps, etc. Hope this helps.
Posted on Dec 11, 2008
SOURCE: Error code E5 41 on Ricoh copier model 4527, or FT 4527
It is a fuser error (low warm up temp), often caused by fluctuating voltage.You have a blown fuse, lamp, or thermistor. Can only be reset in service mode after the problem is solved.
Posted on Mar 12, 2009
SOURCE: how to reset passcode, copier given to the church. Ricoh Ft 5535
This will require a tech familiar with this machine to reset. The user code option is enabled by both a setting within service mode, and a jumper being disconnected on the motherboard of the copier. This jumper will need to be reconnected and the settings changed within service mode.
Posted on May 26, 2009
goodgold
  • 389 Answers
SOURCE: I have a RICOH FT 4022 Copier and when I switch it displays U 6
Ricoh 4022, 4027 Код ошибки Описание C1 Front door open C2 Exit door C3 Cassette cover C4 LCT cover C5 Sorter open or not latched to machine, or fuse 304 on DC power board C6 ADF cover C7 Right side cover E101 Exposure lamp too long E103 Frequency problem E120, 121 Scan home problem E124 Scan drive problem E140 Lens home, or fuse 303 on DC board E141-143 Lens home sensor, fuse 303 on DC board E144, 145 Mirror sensor, fuse 303 on DC board E191 Image density sensor error E302 Charge roller problem or HVT problem E346 Bias loss E351 Image density sensor problem E352 TD sensor error E353 Vsp problem. Dirty or bad image density sensor E354 Vsg problem. Same as E353 E355 Toner density sensor problem E356 Same as 355 E405 Transfer belt or charge roller drive E440 Main drive E442 Drum charge thermistor E501 Upper lift motor E502 Lower lift motor E503 1st tray motor E504 2nd tray motor E505 3rd tray motor E506 Tray main motor drive problem E507 LCTl lift motor E522-525 Jogger sensor E541 Fuser thermistor E542 Fuser temperature too low E543 Fuser temperature too high E544 Fuser temperature too high E547 Fuser lamp won't shut off E548 Fuser temperature too high or too low E620 Communication problem between main board and ARDF E621 Communication problem between main board and sorter E623 Communication problem between main board and paper trays E720 Sorter stapler timing roller sensor E721 Sorter stapler bin lift sensor E722 Sorter stapler jogger sensor E723 Sorter stapler grip sensor E724 Sorter stapler error E900, 901 Copy counter U2 Key counter U6 Fuser unit not installed properly U7 Duplex unit
Posted on Sep 13, 2009
Error sc995-01 on ricoh mp c2800
spmode
5801 #
execute
then turn the machine off and on
sp mode
2111-3 # execute
2111-2# execute
2111-1#execute
3013#execute
watch video to fixing
https://youtu.be/-DGnULMHtD4
Nov 11, 2016 | Ricoh Aficio MP C2800 Copier
Ricoh ft4615 e11
Damaged Exposition lamp, thermofuse open, lamp contacts dirty or oxidized , lamp power supply faulty or loosen /broken cables. This are the most probable causes.
Add a Video
Apr 28, 2014 | Office Equipment & Supplies
I have 3713s and has e11 error. i have already reseted but still the e11 is coming out. i need help
e 11 is the lamp error. check if the scanner lamp comes on or not when the machine is on.
Oct 23, 2010 | Ricoh FT3713 Copier
HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN RICOH 4018 AND E11 ERROR MESSAGE IN RICOH 4622 PHOTOCOPIER
e 5** fuser related temperature over/under
e1** optics related
both need service engineer
Oct 04, 2010 | Ricoh Office Equipment & Supplies
Ricoh copier 3813 - error e
E codes are displayed in the copy counter.To display both digits of the E code press the enter key.
E11 exposure lamp error.Possible causes exposure lamp open thermofuse open.
E12 exposure lamp error Ac drive board defective or main board defective.
Oct 26, 2009 | Ricoh Aficio 450 Copier
Ricoh FT 3013 error code E 21? how can it be fix
· Scanner home position sensor failure
· Defective scanner motor
· Defective main board
· Defective dc power supply board
· Incorrect scanner drive wire position
· FU202 on the dc power supply board open (blown fuse).
- Action -
Turn the main switch off and on.
Check the position of the 1st scanner sensor actuator.
Actuated De-actuated
Does the scanner motor rotate when the main switch is turned on?
No Yes
Correct the scanner drive wire position.
Check the voltage at CN106-2 on the main board.
24 volts 0 volts
Check FU202 on the dc power supply board.
Good No Good
Replace FU202
Replace the dc power supply board.
Check the voltage at CN105-1 and 6 on the main board.
24 volts 0 volts
Replace the main board.
Jun 26, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
I need a ricoh ft 4220 manual. Can you email to vaughan@vkeal.orangehome.co.uk
Yes, I have Ricoh FT Ops manual and service manuals wich do you need?
Jun 05, 2009 | Ricoh FT3713 Copier
Error code E11
hello sir; E-11 means the exposure lamp open ,need to replace. the item# is AX520023, if you need it , you may contact with me.
Feb 10, 2009 | Ricoh FT3713 Copier
Mar 20, 2008 | Office Equipment & Supplies
66 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
