Question about Breville Irons
My new Breville VIN245 steam iron will not fill from the big tank, I have to keep filling the iron. Why?
oscarn
  • 110 Answers
SOURCE: Water drips out of steam holes
I suspect that by placing it on its heel rest the water from the tank is not allowed to enter into the steam chamber and when you go into ironing mode there is a rush of water that is cooling down the sole plate to below steaming temperature. Try keeping it in the horizontal position on a heat proof pad and press the steam button just before going into ironing mode.
Posted on Sep 21, 2007
SOURCE: Breville steam glide 2200w iron
Hello, dont know if you still have no instruction book for this iron, i have the same iron and found the instruction booklet on there website. go to breville website, and irons and download.
Posted on Jan 16, 2008
DiYerTech
  • 70 Answers
SOURCE: no steam comes out of iron
Hi, there is probably a something broken in the moulded plastic trigger assembly (there is a plastic broken finger that actuates a micro-switch under the rubber handle cover). If you are so inclined, use an orange stick and gently pry up the rubber handle cover on either side from the front to the rear cord end to access, inspect and troubleshoot. I am in SoCal and use the California Electric website to obtain parts or go to the Rowenta home website to locate useful manual information, PDF reader and dealer near you.
Posted on Jul 21, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
SOURCE: Hinari steam vapor iron Model HIN001
More complete answer...
If you are having steam problems then the cartridge needs changing.
I phoned them (0161 652 1211) and they do sell the cartridge for £5.99 including delivery but are out of stock for a couple of weeks. You have to send them a cheque or postal orders. Good luck.
Send Cheque for £5.99 for each cartridge with note of model etc.
Pulse Home Products Ltd.
Middleton Road
Royton
Oldham
OL2 5LN
Posted on Oct 07, 2008
I need a new water tank for breville steam generator iron
You should be able to find one on eBay. .. good luck!
Apr 01, 2015 | Breville Irons
Digital settings flashing
Breville VIN170 Extreme Steam Digital Steam Generator Iron, unplug the iron from the mains , keep both the power and keep the steam release button on the iron depressed and then plug in and switch on.
Below is a link to the user manual for the Iron
http://www.breville.co.uk/downloads/dl/file/id/378/steam_generator_iron_vin170_instruction_book.pdf
Hope this helps, if you require any further assistance please contact me.
Oct 18, 2014 | Breville Vin170 Extreme Steam Digital...
What could be stopping the water in the holding tank not going in the steam tank on my Perfect Care Iron ?
most likely is mineral build up. drain out the water and replace with white vinegar, warm up the iron and allow it to sit until you see steam (several minutes to half an hour) if no steam, replace the iron.
Jun 18, 2014 | Irons
Filter light flashing what do I need to do no manual available
Aug 07, 2013 | Breville Vin170 Extreme Steam Digital...
How do i descale it
Fill the tank with regular malt vinegar and leave it overnight, Was out in the morning and should have removed most of the scale. Then mix two parts vinegar and one part water and fill the tank again. Heat the iron up to max setting and steam through to remove any small deposits in the steam holes. Repeat if needed.
Feb 27, 2011 | Philips HI-296 Iron
How do you reset the water filter light when you put in new filter on Breville Steam Generator please
Ok, had this too. Done some research and it looks like you have to unplug the iron from the mains , keep both the power and steam level buttons depressed and then plug in and switch on.
Chris.
Feb 12, 2011 | Breville Irons
How to put water in the Tefal pro 2500
This type of iron is called a steam station iron.
The box is the water tank and it is this that you need to fill with water. You should be able to find a small spout on the water tank in order to fill it. These irons produce a huge amount of steam and should make the ironing a breeze once you get used to it.
Feb 07, 2009 | Tefal Irons
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Irons Logo
54 people viewed this question
Top Breville Irons Experts
Tom Chichester
Rani wadia
Rani wadia
Are you a Breville Iron Expert? Answer questions, earn points and help others
