Need to see location of cmos battery on a toshiba satellite l505d
  • 1 more comment
  • Coyotte Jul 19, 2012
    @joecoolvette: The solution you provide is for a L500, but the L505 looks different. I can't find the B500 solder pads. Do you know where they are? Thanks.
  • joecoolvette
    joecoolvette Jul 19, 2012
    No. This is how a bad solution follows you around like a used diaper, ha! (Okay. Half bad. I did give the location of the CMOS battery, as asked) There may not be any pads to short out, francisra. However perhaps this info will help,http://www.tech-faq.com/reset-bios-passw... {Short the correct pins on the BIOS chipset?} Regards, joecoolvette
  • Coyotte Jul 22, 2012
    Thanks for the link, I will continue my investigations...
  • Computers & ... Master
  • 5,660 Answers
It's soldered to the bottom of the motherboard,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L505-L505D/remove-laptop-motherboard-3.htm
Scroll down to Step 23 , and click on the photo.
Main article,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L505-L505D/remove-laptop-motherboard-1.htm
NOTE*
You will be unsoldering a solder connection on a BATTERY.
Need to be good, or the battery could bl-ow up.
Make SURE you have no Static on your body, OR use an ESD wrist strap, and connect the alligator clip to a Good ground source. (Average cost is around $3 to $6)
I hope this is because the laptop will not keep the time, and date.
You CANNOT reset a BIOS password this way.
Toshiba's have a small capacitor in line, that stores a small residual amount of power. Enough to keep that BIOS password set, even if the CMOS battery is taken out for days, weeks, or months.
There are two SMALL copper pads that are shorted out BRIEFLY, with a jumper wire.
http://www.fixya.com/support/t6645137-toshiba_l500_clear_cmos
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Feb 12, 2012
aayushik
  • 59 Answers
SOURCE: How to reset BIOS password - Toshiba Satellite 1605 CDS
you dont have to take the battery off, just unplug the cmos connector which looks like a stereo wiring harness.
Posted on Nov 14, 2008
rtrahan
  • 741 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
www.michaelstevenstech.com/bios_manufacturer.htm
Check out the above website it has the correct keys to get into BIOS for all the major brands including Toshiba Satellite is F1. You have to open your computer and get to your motherboard to change the CMOS battery. It looks like a small watch battery on your motherboard and is easily identifiable.
Don't forget to vote on this thread before you log out.
Posted on Jan 25, 2009
SOURCE: Trying to locate the cmos battery for Toshiba Satellite L25-S121 laptop?
I've been working on a Satellite 1415-S115, and found the CMOS battery. You will have to open up the 'clam shell' and remove all of the B25 and F6 screws from the bottom, as well as the B16 and B6 screws under the keyboard. To remove the keyboard, I had to pry up the trim piece that holds the power button and remove three screws. Be careful of the wireless wire leads, as you'll be tempted rip them out!
The CMOS battery will be under the right side of the hand rest, next to the mouse. It has two leads and the battery is in a blue 'bag'.
Posted on Nov 28, 2007
SOURCE: ReplaceToshiba Satellite Pro 6100 laptop CMOS battery
the cmos batt is located near the cpu, is a quarter look alike batt. disconect it fron the two cable connector to the mb and replac e with a new one.
Posted on Jul 16, 2009
  • 58 Answers
SOURCE: Toshiba Satellite A100 755 battery CMOS
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
50
Posted on Jul 26, 2009
HOW DO I RESET MY TOSHIBA SATELLITES BIOS PASSWORD AFTER I FORGOT IT?
take out the internal cmos battery for a while. or there are jumpers close to it or by memory u can short. failing that but up from cd if poss and use cmos reset software
Jan 02, 2016 | Toshiba Satellite L505D-S5983,...
How do I do the factory reset on the Toshiba laptop Satellite L505D-GS6000
press and hold f8 and press power button. hold f8 key till you see the recovery menu. select factory reset.
Mar 04, 2015 | Toshiba Satellite PSLV6U-01F009...
My battery won't charge
There's not much that can be done except return the adapter for replacement. But first, are you sure your car's cigarette lighter works ?
Mar 28, 2011 | Toshiba Satellite L505D-S5983,...
Toshiba satellite l505d
unplug laptop and remove battery. Take out both memory sticks and locate on the motherboard under sticks two points marked with ***. Replace one memory stick, plug ac adapter back up and while jumping the two points at the *** (use paperclip, flathead screwdriver or other metal object to connect the points) power up computer. This, if done properly, will reset bios, removing password.
Jul 21, 2010 | Toshiba Satellite L505D Notebook
Toshiba Satellite A55-s1066 need help Loacting Bios Chip.
you need to remove all at same time and memory modules too, and after remove the cmos battery, try to find a passw clear switch on the motherboard nearby cmos battery.
Feb 14, 2010 | Toshiba Satellite A55-S1066 Notebook
Where is the cmos battery located?
It is located on the mother board, under the keyboard.... It is the size of a quarter.... and may be soldered in on your Satellite M35x series machine.
Oct 23, 2009 | Toshiba Satellite M35X-S149 Notebook
Jul 16, 2009 | Toshiba Satellite 5005-S504 Notebook
Computers & Internet Logo
2,475 people viewed this question
David Payne
David Payne
