Question about Fujitsu Siemens Stylistic ST5022 Tablet PC
External vga display doesn't work
My TV monitor displays my laptop's (display) output fine, but when I connect the same VGA cable to my Fujitsu ST5022's VGA out port, it simply doesn't work/doesn't show anything. It has Win XP Tablet addition installed on it (perhaps updated with MS patches etc). As far as I know, there is no driver pending to be installed. In other words, there is no component showing un-working in the device manager.
    Top Expert:
  • Fujitsu Siemens Master
  • 12,962 Answers
Check external monitor settings on Fijitsu.
Posted on Jul 03, 2017
2 Suggested Answers
  • 114 Answers
SOURCE: Do I need a battery to run the PC Tablet?
THe manual for your specific model can be found here: Documents for othe models and languages can be found here:
Posted on Sep 25, 2006
I have an asus x202e notebook that does not display even the power is on and the wifi is lighted but still no display and the fan is not running also, why is my laptop does not display ?
Have you consulted any troubleshooting sections in the documentation for your notebook ? Do so.
Next you could try connecting an external monitor to your computer, using the port on the side of your computer Its a VGA port I believe so you will need a VGA monitor and suitable cable or another type of VDU and cable/adapter. There should be a button on your keyboard to switch displays (built in screen/eternal monitor/both cycling between the combinations on my HP it's the f4 button). If you cannot get this to work it is a problem either with your m/b or less likely software. If your external monitor works then maybe the small cable connecting your computer to its display has become unplugged, or else the screen has failed, most likely the inverter, which can be relatively easily be replaced. If the service manual does not describe these procedures search the internet, most likely there is a video on how to carry out this procedure on youtube.
You might need to carry out a lot of research and reading to diagnose and solve a problem.
Mar 26, 2015 | ASUS Vivobook X202E
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
Dear Sir/Madam, I have an Acer Aspire 5735-642G25Mn laptop and I don't know how to connect it to my TV (Sony KDL55NX810). Could you please advise me on how to do this. Thank you. Regards, Erik
The video output on your laptop uses a VGA port, and the video in on the tv uses HDMI. You cannot plug one directly into the other, you will need to buy a special VGA to HDMI converter (NOT just a plain VGA to HDMI cable, you need a converter to change the analogue VGA signal to a digital HDMI one). Something like this:
Naturally you will also need a VGA and an HDMI cable to connect everything up.
Jun 01, 2011 | Acer Tablets & eReaders
What you need:
This is hard to define initially as there are so many ways to achieve this depending on what type of television you have and what video outputs your computer offers. You may also find that you only want to attach the stereo, and leave the TV disconnected, or vice versa.
.HDMI - High Definition Multimedia Interface: Ideally we will all have an HDMI connection on both our television and video card, but most likely don’t have it on either. Many new LCD screen and Plasma displays offer this mother of connections. They are also becoming a little more popular on Video cards. This will give you the highest quality signal. This format can also carry audio. This is very easy to connect from one device to another. It offers the same video quality as a DVI.
here are some tips that will help
Computer has HDMI and TV has HDMI – Use HDMI
Computer has DVI and TV has DVI – Use DVI
Computer has DVI and TV has VGA – Use VGA + Adaptor
Computer has VGA and TV has VGA – Use VGA
Computer has S-Video and TV has S-Video – Use S-Video
Computer has RCA and TV has RCA – Use RCA
Computer has S-Video and TV has RCA – Use RCA with adaptor
Computer has RCA and TV has S-Video – Use RCA with adaptor
Sep 10, 2009 | Gateway CX200S Tablet PC
Trying to connect laptop to 46 in sony bravia, will show desktop but will not show the internet or anything else. please help
When you have the laptop connected to the telivision are you running both displays? In other words is the screen on for the laptop and the telivision at the same time? Sometimes if both displays are on you cannot run programs on both. When you use the FN key and press the display button(usually F5) it should cycle thru each time you press it. Try pressing it until you only have the display showing on the televison only. Doing this should make the telivision the main display.
Sep 08, 2009 | IBM ThinkPad X41 Tablet PC
Connecting to data projector
Jul 03, 2009 | Fujitsu Stylistic ST4110 Tablet PC
HP Compaq 2710p: External monitor does not display anything
The display properties indicate the hardware is working, so it's likely just a setting.
On HP/Compaq models you will see a picture, usually on the F4 key that looks like a screen with two lines beside it.
You need to hold down the Fn key(bottom left) and then push the F4 key at the same time to cycle between LCD, external or both.
If it is a newer model, a menu will pop up when you do this asking if you want to duplicate the LCD on the external, switch to the external or extend the desktop onto the external. Select the appropriate setting or continue holding down Fn while pressing F4 to cycle between the settings to the one you want.
If you have re-installed the computer at some point with anything other than the factory recovery set this may not work and I will have to give you a longer set of instructions.
If this works please rate this as fixed, if not reply back and indicate what version of windows you're using and I will post the instructions for the "long" way.
May 26, 2009 | Compaq 2710p Tablet PC
Screen problems on Toshiba Portege R100
Right click on the computer's destop and view the display properties. Under the tab where you can alter resolution you can manage multiple monitors, It sounds like your laptop is setup to display through it's external VGA by default. Click on the two squares it shows and try to set your main screen as default.
May 30, 2008 | Toshiba Portege R100 Tablet PC
Hp tc4400 s-video not working
well cuse u nee dto use vga output to a vga pc ready tv only ok s video looks horbaily dontw ork well wont show all icons ok
Feb 09, 2008 | Compaq tc4400 Tablet PC
Fujitsu Siemens Stylistic ST5022 Tablet PC Logo
276 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Martin Murray
Jason Morris
Lakshman P
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
