Question about Crossfire Car Audio & Video
Looking for support manual for a Crossfire CT2120 Power Amplifier
Infinity modulus problems with car radio for 2005 Chrysler Crossfire. No sound
If the radio works the two fuses for it must be OK. 15A fuse 23 is the source of amplifier power. The amplifier is probably tucked away near the radio
Oct 10, 2012 | Cars & Trucks
When i turn up the volume my amp shuts down i turn it down and it comes back on. I have a crossfire vr1000d what am i doing wrong?
Is the protect light in your amplifier turns on when it shuts down? If yes, then your amplifier lacks voltage. The reason why it goes on protect mode is, the amplifier is needing an amount of voltage from your car, since your car cannot provide that amount of voltage your amplifier is not getting anything, instead of getting voltage to produce watts its getting minimum voltage & producing heat, to save itself it goes on protect mode so the incoming power shuts off & cools the amplifier.
Example:
Your on vol 40, amplifier is working fine, when you turn it up to vol 50 your amplifier shuts of, then you put it back to vol 40 & your amplifier turns back on.
At vol 40 your voltage is 12v or above. but in vol 50 your voltage drops to 11 & below.
Check your battery or alternator if they are giving enough voltage
Hope this helps your inquiry. Have a blessed weekend.
Apr 24, 2011 | Crossfire Car Audio & Video
Do you know anything about the 1400 series crossfire amp
Unfortunately I can only get the PDF version of the VRA series on these amps. Here is a link to the manual. They all basically have the same connections. Hope this helps. http://www.crossfirecaraudio.com/download/vra%20menual/vra_m_web.pdf
May 20, 2010 | Crossfire VR1202 Car Audio Amplifier
Won't turn on & don't know how to hook up to a 1963 pickup.
Don't get confused, it's very simple. +12v----direct supply from battery.
REM---also 12+ supplied from igntion switch. (when the key is turned on, this supply should have 12+ to on the amplifier.
GND--12- minus (negative)
Try it you will be able to set this up. REM can also be used with a single switch which can break the 12+ when amplifer is not in use, or else this will take all ur power battery. You can place a fuse on 12+. Thanks
May 15, 2010 | Crossfire VR302 Car Audio Amplifier
Ok . i have a pair of crossfire subwoofers, @
Your amplifier is 4 channel... and only 2 ohm stereo capable.
You will get the most power putting 1 subwoofer wired in parallel on each BRIDGED channel.
This will give you a 2 ohm stereo load.
Both + on 1 subwoofer to + terminal on amplifier bridged channel 1
Both - on 1 subwoofer to - terminal on amplifier bridged channel 1
Both + on 1 subwoofer to + terminal on amplifier bridged channel 2
Both - on 1 subwoofer to - terminal on amplifier bridged channel 2
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | DHD NTX-3102 Car Audio Amplifier
Need owners manual/operating instruction manual for crossfire car amp. model: CFA-404S
need owners manual/operating instruction manual for FUSION FE-1002 Amplifier
Nov 26, 2008 | Car Audio & Video
Car Audio & Video Logo
116 people viewed this question
Top Crossfire Car Audio & Video Experts
xxxxxx xxx
Electro Med Services...
Are you a Crossfire Car Audio and Video Expert? Answer questions, earn points and help others
