Question about NAD T753 Receiver
Nad t753 headphones
When i connect my headphones, it is saying headphones on the display, but there is no sound in them, and my speakers are still playing somekind of downmixed soundtrack. It is happening with stereo too. My setup is as follows: Source (SPDIF) -> t753 -> NAD t214 -> speakers. I Hope you can help
  • 518 Answers
SOURCE: NAD T753 5.1 Channels Receiver Problem
It could be a heat issue, is the receiver able to get air to cool itself? Also, a bad speaker or mismatched speaker may cause this. Sometimes hooking up extra speakers may cause this. Other than that, it would be a service issue.
Geno
Posted on Mar 05, 2008
SOURCE: NAD 775 will not play surround sound from XBOX
try to calibrate the speakers from audessy rom menu,i did it and it lokes like it just needed to register all the channels,hope it helps.
Posted on Mar 09, 2009
SOURCE: My NAD T753 goes into protection mode as soon as I turn it on.
ALso do the same thing, but also cuts out my left rear speaker. This will make a dull hiss sound during use.
If I disconnect this speaker it works for a while.
It all started with my sub shorting out it's fuse, I had it repaired four times already and is costing me more than the system. I changed all my speakers and is costing me another R 12 000-00, problm still the same.
P.S. I had my amp taken to the specialists too, but they couldn't find any fault. If i touch the side of the amp I can feel a tingling on my skin, like getting an electric shock.....
Can this also be a ground loop / earth problem?
De Villiers
Posted on Jun 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: color plug came out. red color which position do
Not sure what this cable is for but YOU should be able to follow it to the component at the other end and determine its fucntion.
Here's the manual. Page 12 shows the rear.
http://www.retrevo.com/s/NAD-T753-Receivers-review-manual/id/8043bh641/t/1-2/
Posted on Jun 09, 2010
  • 4 Answers
SOURCE: Hello. i cant turn on my nad t753,the power lamp
Hi! In my T753 is simmilar situation: the alpituner won't turn on - only orange LED is lighting. One of the two ALi's microprocessors (the directly soldered one) is dead. Anyone have it or know who could have it got?
Posted on Mar 15, 2011
Hello I'm looking for a NAD T753 Service
Hi DERAIN Francois,
First of all, thank you for purchasing the service manual of NAD T753.
Please email me at mjsvillanueva23@yahoo.com I will send to you the copy. It is a PDF file format and can't be upload here.
Again, thank you so much!
Take care and have a great day!
Rating and feedback are highly appreciated.
mjsazon
Feb 06, 2012 | NAD 712
My nad t753 reciever went into protect mode. i switched it off and was able to get it back into standby mode. The receiver switches back on but no sound comes out of the monitors. I can even switch between...
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Aug 31, 2011 | NAD T753 Receiver
Nad t753 av reciever, mains power off then back on think had power surge have i blown a fuse in system. amp turns on but then 2 sec later turns off . can i take the casing off to replace fuses?.... dan
Blown fuses don't self-heal. If power comes back there is no blown fuse.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
May 29, 2011 | NAD T753 Receiver
Color plug came out. red color which position do I plug it into need diagram of back of unit for the NAD T753
Jun 08, 2010 | NAD T753 Receiver
Jan 29, 2009 | NAD T753 Receiver
The unit grounding screws have come loose. All the ground screws should be tightened.
Jan 22, 2009 | NAD T753 Receiver
NAD T753 s-video in, component video out problem
I have the same amp. You have to have the same input as you do output for video...ie: s-video in/s-video out, composite video in/composite video out. I know it sucks but thats how NAD designed it.
Dec 01, 2008 | NAD T753 Receiver
Geno
Mar 05, 2008 | NAD T753 Receiver
NAD T753 Receiver Logo
44 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
