Total Power Failure When Using the AC Adapter
  • 5,660 Answers
1) Check the AC adapter. Use a multimeter set to DC Voltage, (Symbol is a dotted line over a solid line)
You aren't checking for voltage output, so much, as you are checking for an intermittent break.
AC adapter plugged into power, and probe leads of the multimeter touching the plug of the AC adapter going to the laptop, have an assistant gently wiggle;
1) First the power cord going to the AC adapter.
2) Then the cable from the AC adapter TO the laptop.
If you get an intermittent reading on the multimeter, you have a broken wire in the AC adapter cable, or power cord.
2) If the AC adapter shows VERY close, to the voltage it's supposed to be putting out, AND there is no intermittent break, go to the DC Power Jack.
[ A economical multimeter can be purchased for around $8 to $12.
Available in a multitude of stores. An auto parts store is but one example.
Analog, (Meter with needle), or digital is fine.
Multimeter's vary in style.
It will have a Function knob in the center. This is turned to DC Voltage.
As stated, if just a symbol, it is a dotted line over a solid line.
IF, there is more than one DC Voltage scale, set it to the 0 - 50 Volt scale.
The red probe lead is the Positive lead.
The black probe lead is the Negative probe lead.
You are testing DC Voltage. There is a Positive, and a Negative.
The plug of the AC adapter, that plugs into the DC Power Jack on the laptop, will have a Positive connection, and a Negative connection.
Plugs vary. The most common is a plug with a center hole, and a surrounding metal cylindrical shell.
The Center hole is Positive.
The outer cylindrical metal shell is Negative.
Need more advice post in a Comment ]
Depending on what laptop we are discussing here, the DC Power Jack can be soldered directly to the motherboard, OR it has a cable attached to it, and the cable plugs into the motherboard.
(DC Power Harness)
IF, it is the solder to the motherboard type, it has prongs, or pins, that come out of the bottom of the DC Power Jack, and goes through the motherboard. Then the prongs, or pins, are soldered to the motherboard.
With this style, if the DC Power Jack is bumped, the solder joints of those pins, may be cracked. Makes a bad contact.
Could also be bad enough to make a Short. (Laptop turns off when AC adapter is plugged in)
The DC Power Jack itself may be in bad repair.
Using as an example of the style that has a Center hole, and a surrounding cylindrical metal shell, (Inside), if the two parts touch, you can have a Short.
The diagnoses is to start with removing ALL power, AC adapter ('Natch), and Battery.
See with a small wooden object, if you can gently wiggle the DC Power Jack.
ANY perceptible movement means a bad DC Power Jack.
You will also have to partially disassemble the laptop, to check the DC Power Jack solder connections, to the motherboard.
3) DC Power Jack checks out, the problem has gone serious.
Mounted to the laptop motherboard is a power controller chipset.
It is a power MOSFET,
[ Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_Circuit
The power MOSFET is a type of I.C.,
http://en.wikipedia.org/wiki/Power_MOSFET ]
If you open the laptop, and view the motherboard, this problem will be readily apparent. This chipset usually burns, and turns blackish.
Problem is when it does, the manufacturer's ID numbers are hard to read, in order to obtain a replacement ]
This is one power controller chipset that is used in a LOT of laptops,
https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
This is another one,
http://html.alldatasheet.com/html-pdf/85156/VISHAY/SI4925BDY/183/1/SI4925BDY.html
Both of these chipsets uses a D2PAK surface mount.
The leads are bent into a J shape. ( J Lead)
The 'foot' of the J lead is soldered to a copper pad on the motherboard.
(Copper Pad has a thin gold plating on it)
Simple de-soldering/soldering techniques, are used to Remove the chipset.
HOWEVER, use a Heatsink on EACH J lead, when soldering the new chipset in.
http://www.radioshack.com/product/index.jsp?productId=2103242
(The power MOSFET has transistor/s inside )
OR, replace the motherboard.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Feb 12, 2012
3 Suggested Answers
jonb3838
  • 237 Answers
SOURCE: laptop wont power up on batter but will on adapter
It sounds like you dc jack is not functioning if you are could with solder and disassemble you can do that yourself . Otherwise you can get it repaired for around 75-100 dollars
Posted on Feb 13, 2009
SOURCE: dell c640 laptop when not power on when using ac
Yes, you should replace you battery, go http://www.feevoo.com , you can find many cheap laptop battery, laptop accessories there.
Posted on Jun 25, 2010
Toshiba laptop will not turn on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
http://www.chargerbuy.com/laptop-ac-adapter/toshiba-ac-adapters.html
Mar 01, 2013 | Computers & Internet
Asus laptop won't power on
Possible causes:
Dec 21, 2012 | Computers & Internet
Why won't my gateway MD78 power on?
Possible causes:
Replacement Gateway MD78 AC Adapter 65Watt 19V 3.42A Option
Replacement Gateway MD78 MD7800 AC Adapter 90Watt 19V 4.74A
Nov 29, 2012 | Gateway Computers & Internet
My hp netbook wont turn on, what shoud i do?..
Possible causes:
Replacement HP Mini 210 AC Adapter Cord 30Watt 19V 1.58A
Nov 05, 2012 | HP Mini 210-1030NR Netbook
Nikon D1X, Total Failure after attempt firewire to USB convert to PC. How to reset?
Hi Lynn,
I'm also facing the same problem with my D1x and I wanted to know if you were able to find a solution. I'd be grateful for any help.
fred.
Apr 25, 2012 | Nikon D1X Digital Camera
Dell inspiron 1525 - plugged in not charging shown on battery icon. Battery power light blinks 4 times amber then once blue.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See
Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for
instructions.)
Feb 13, 2011 | Dell Inspiron 1525 Notebook
Dell 6000 power problem?
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Mar 24, 2010 | Dell Inspiron 6000 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
111 people viewed this question
David Payne
David Payne
