Question about Sony BDVE280 Theater System
How to adjust bass and treble
According to the user's manual, there is no way to adjust bass and treble in this equipment. Perhaps in the service manual there is a way ... Can anyone help?
2 Suggested Answers
  • 3287 Answers
SOURCE: How to change treble & Bass
As crazy as it seems, I couldn't find any references to bass or treble in the manual (linked below for your convenience). You might want to contact Sony for more help with this.
https://docs.sony.com/release/DAVC700.PDF
Posted on Apr 12, 2014
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
I have a jvc kdhdr50......and I'm wondering how to adjust the bass and treble also how to turn the loudness on
This is discussed on page 26 of manual. Press and hold MENU and select USER for EQ. Under EQ you will have options to adjust SUB BASS, BASS, MID BASS, ULTRA HIGH, HIGH, MID HIGH, AND MID
Aug 10, 2014 | Car Audio & Video
Apr 11, 2014 | Sony DAV-C700 System
I cant figure out how to set the sound, bass, treble, etc..
hi Rob, here is the user manual, http://www.clarion.com/us/en/MungoBlobs/779/346/DXZ665MP-ENG.pdf page 13 and 14(of the manual) tell you how to manual adjust bass, treble, fading, balance etcHope this helpsShona
Apr 10, 2012 | Clarion DXZ665MP CD Player
How to adjust tone settings manually for my LG LHT743 DVD receiver? I have several preset settings but no Bass, trebal control
I did some research on this, but was unable to find out how to adjust bass and treble control individually. this is a link to the users manual (not sure if you have or not). You can download it if you like. I did, read through it, and didn't find anything to solve your issue. Unfortunately, this is a common setup for a lot of newer sound systems. Since they are digital, to achieve superior performance, they keep the settings digital and dont allow for fine tuning of the lower and upper frequencies (bass and treble).
http://www.retrevo.com/support/LG-LHT734-Home-Theater-Systems-manual/id/3126dj199/t/2/
I hope this helps.
JD
Mar 24, 2011 | LG LHT734 System
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
I need to find out what buttons control the bass and treble
Press in on the volume control repeatedly to step through the menu of audio functions. The
first option is Volume, followed by subwoofer (only if the subwoofer feature is currently
activated), Bass, Treble, Balance, Fader and back to Volume. When adjusting audio functions,
the unit will automatically exit audio control mode after five seconds of inactivity
If you need the user's guide, click her to download.
Feb 21, 2009 | Jensen MP7610 CD Player
Cinemate bose how do I adjust base and trebble
If the system doesn't have controls labeled "bass" and "treble" - or if there are no clever presets like "Hall", "Theater", etc., then you'll have to adjust these parameters before the signal reaches the speakers. One way is to purchase a graphic equalizer to hook between the speakers and the signal source. A graphic equalizer a basically a tone control, with the spectrum divided into 10 or more "slices" instead of 2 (bass and treble). Consider the sliders on the left as "bass", and the ones on the right as "treble". If you're using these speakers for a computer, some sound card software has these controls buried beneath a few menus - but sometimes not. The easiest solution is to buy an equalizer and hook it between the signal source and speakers. Bose is typically "audiophile" equipment, and many audiophiles don't want tone controls (thus the extra electronic processing required) to contaminate the signal. Obviously, most systems do need to offer some control to the user, as you've discovered!
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
New car, no manual
There is no straigt forward bass and treble adjustment. You must adjust in either the (x-over) or (users EQ) function. It is a bit tedious but performs the bass and treble adjustments at multiple frequencies.
Aug 24, 2008 | Alpine CDA-9833 CD Player
Cannot Set the Treble & Bass
I have an Alpine 9887 you have a different eq than just trebel and bass the only way to get you bass an trebel setings are to install the imprint stoftware now if thats the route you go it tunes your radio to what it thinks it should sound like it's for sound quality not for alot of bass been there done that I have the software but you need to take it to a good alpine dealer to have it installed good luck
Jan 05, 2008 | Alpine CDA-9887 CD Player
Sony BDVE280 Theater System Logo
120 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
