Question about Hotpoint Dryers
Hotpoint cdt40g How do you remove the side cover from a hotpoint CDT40G dryer
2 Suggested Answers
SOURCE: Not Pumping water to reservoir
Fixed this problem by removing the back and side panel and simply clearing a build up of fluff from the channel that feeds the water from the condensor unit to the reservoir. To do this I had to open the plastic unit that houses the pump by simply unclicking the top section and clear this and also clear the entire base section. Dryer now not leaking and drying much quicker.
Posted on May 21, 2009
Hotpoint TCM570P Why is dryer squeaking ?
Its probably the tentioner pulley. Remove the panel on the right side (facing the machine)lift off the fan cover ,slide off the fan and remove the pulley (small black wheel at bottom) a little grease should do the trick.scoptrepair1@outlook.com
Feb 24, 2015 | Hotpoint tcm570p Aquarius Condensor Dryer...
Hi. Can anyone tell me how you take the top off a Hotpoint CDT40G dryer?
there is two screws at the back top each side remove them then lft slightly and with the heel of your hand hit it forward you will find it will move forward and lift off.
Sep 17, 2014 | Hotpoint Dryers
Hoptoint CDT40G condenser tumble dryer pump running no heat or movement
hi i have a ctd40 mine wouldent go a few years ago on the heater i had three stats on one of them there is a tiny hole i pushed a sewing needle in hole it reset the stat you can see if you look at bottom of stat it might be concave so pushing it out set it again dryer then worked pull plug first
Apr 29, 2013 | Hotpoint Dryers
Hotpoint TDL 14 Dryer. Motor is working but drum not turning?
Remove the top cover and check to see if the belt is o/k, or could be collapsed rear bearing, remove the rear cover and check the drum bearing.
Nov 22, 2010 | Hotpoint Dryers
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
How do i tighten the drum weights on my hotpoint
Remove rear cover, and you will see the concrete weight at the bottom, sometimes the securing nuts work loose, or break off.
There is also a concete weight in the top of the washer as well,so check this as well
Feb 04, 2010 | Hotpoint Aquarius WD640 Front Load...
How do I replace the belt on a hotpoint autima auto dryer
Remove the top cover, and front right hand side panel.
This will give you access to the drive belt.
Hope this helps.
Dec 12, 2009 | Hotpoint Dryers
Main drum drive belt has broken. How to open the back or side to be able to replace the belt?
If it is a full size dryer, then you need to remove the top cover\ and right hand side panel, this will give you access to the belt.
If it is a small compact dryer, then you have to remove the rear panel, and then remove the whole cabinet.
Hope this helps you.
Dec 07, 2009 | Hotpoint Dryers
May 16, 2009 | Hotpoint Dryers
Taking cover off dryer
open door and look for screws going up into top
Jan 04, 2008 | Dryers
Dryers Logo
26 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
