Question about Dell LATITUDE Computers & Internet
Dell latitude d 610 will not charge or turn on battery flashes green to amber
  • Dell Master
  • 32,281 Answers
4 orange and 1 green flashing means temporary battery failure.
Try charging the battery overnight and the battery may get to 100%
If not the the battery is faulty/worn out and needs replacing.
Posted on Feb 12, 2012
SOURCE: Dell latitude D600 battery charge light flashing
I removed my battery while the computer was running and it fixed it
Posted on Feb 14, 2008
Kegtapper
  • 94 Answers
You have a ground fault issue in the DC JACK.
There are escentially 4 circuits in the jack and one is not making contact.
1: Negative Charge circuit (outter ring)
2: Negative Run circuit (outter ring)
3 Positive (Inner Ring)
4: Signal (center pin)
I believe the negative charge circuit (outter ring) is not making contact internally. Typically what happens on that model DC Jack is the tension contact metal becomes fatigued, and does not touch the outter ring.
This could come from Heat causing early fatigue of the metal.
Or normal wear, the metal has simply worn out from regular insert/removal.
Don't forget to rate suggestions
Posted on Apr 01, 2008
  • 998 Answers
That usually indicates battery is beginning to go bad. Eventually it will not hold a charge and will need to be replaced.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Posted on Nov 09, 2008
  • 629 Answers
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Posted on Mar 16, 2009
  • 3940 Answers
SOURCE: dell latitude d810 battery light flashes 4 orange
This indicates an internal failure in the battery. While the battery may hold a charge and function, the system has determined an internal failure (Cell with low or no voltage etc) and the only way to resolve the failure is to replace the battery
Posted on Dec 19, 2009
I purchased a new battery for my Dell Latitude 810 and it still won't hold a charge. The battery indicator light is green for a brief period, turns amber and then shuts off.
If you installed a new battery in your Dell computer and still can't get it to charge, there is a strong possibility that there is something wrong with the charging system
Mar 07, 2013 | Dell Latitude D810 Notebook
Dell c640 battery not charging
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Mar 02, 2013 | Dell Latitude C640 Notebook
Battery light flashes green once then amber 3 times dell c840
Usually that means there's a problem with the charging of your battery. Remove the battery and see if you get the same results. If not then either your battery has to be replaced on your circuit that charges it is defective.
Mar 18, 2011 | Dell Latitude D600 Notebook
Hi my Dell Latitude LS laptop isnt starting up or turning on and when i want to charge my battery the charger wont charge the battery and the green light only flash on and off every time i put the cable in...
Easy your battery is shot. Go to ebay and find a new one around $30. just enter all your info of ur laptop like Dell Latitude and should be a # with latitude.
Nov 02, 2010 | Computers & Internet
Dell latitude 100L power light flashes green as if
It sounds like you have a bad AC adapter . When you plug it in to the outlet in the wall and into your computer , do you see a charge indicator light on the computer? I'm asking you this because even with a bad battery your computer should operate without any problems with the AC adapter plugged in.
May 13, 2010 | Dell Latitude 100L Notebook
Dell Latitude D620 isn't getting power to the mainboard.
diagnostic procedures as follows:
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. get a new battery replacement.
No. Call Dell for technical assistance.
if you need Dell latitude d620 Battery you can go to online shop
http://www.global-battery.co.uk
http://www.sales-batteries.com
here you can perchase high quality battery easily
good luck!
Feb 04, 2010 | Dell Latitude D620 Notebook
Latitude D600 not Charging batteries
Seems need to get another Battery.
Jul 23, 2009 | Dell Latitude D600 Notebook
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
flashing amber?
computer.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Dell 610 - battery will not charge and adapter goes "blink"
http://support.dell.com/support/edocs/systems/ins6400/en/index.htm
aneesnv@msn.com
Dec 18, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
71 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
