Question about Cycling
Just bought a used mongoose menace and the front fork is rusted in so can't remove it to repaint the frame. Any tips on how to get it out?
    Problem Solver:
  • 10 Answers
There are two opposing wedges that are holding your forks in the front tube. Picture you have a bolt with no head on it the diameter of the fron tube with a hole drilled through the tip piece and the bottom one is threaded. when you tighten the bolt that comes up thru the main tube, that holds the handlebars on, the bottom wedge is pulled up and the bolt just spins thru the upper one. it pulls the bottom one up until the two wedges make contact, as they do they try to bypass each other forcing them outward and biting the inside of the tube. Sooo...shoot some WD-40 or better yet liquid wrench down the tube, thread the bolt back in all the way (not tite) back it out about an inch, put a block of wood on top of the bolt and smack it with a hammer, the bolt will slide thru the first wedge cuz it has a big hole. the second will be driven down seperating the two. if it totally doesn't let all the way, loosen it a little more and whack it again. You want as much thread in the bottom wedge as possible and the bolt stick up the least so it doesnt get bent. there you go Bud.
Posted on Feb 12, 2012
  • 31 Answers
SOURCE: how to adjust the fork suspension on Mongoose Iboc Style# R4654TG
there is an alan key nut usually underneath the "lowers". this takes the lowers off and thats all i know. aslo there is twist things at the top. this adjusts the rebound
Posted on Jul 24, 2009
  • 9 Answers
SOURCE: The fork on my Strike Mongoose will not fit over
Go to local bike shop and grt replacement fork!!!
Posted on Aug 25, 2009
  • 484 Answers
SOURCE: forks
There are a wealth of online stores; search bike stores on Google.
Posted on Sep 15, 2009
dunnbiker
  • 8546 Answers
SOURCE: I just bought a Schwinn
If you bouht it from a Bike Shop, make them do it. And complain.
If you bought it at a box store don't bother, they're incompetent.
http://www.parktool.com/blog/repair-help/threadless-headset-service
Scroll down to Headset Assembly
Remember, the side bolts on the stem loosen it so adjustment can be made with the top cap bolt. You tighten the side bolts to lock in that adjustment. The top cap bolt is only for MAKING the adjustment, not KEEPING it.
Posted on Mar 21, 2011
martin-r
  • 151 Answers
SOURCE: Specialised rockhopper bike. Loose front
I believe this bike has a sealed cartridge bearing and cannot be tightened. a replacement should probably be bought.
Hope this helps.
Posted on Apr 05, 2011
Need to know what kind of bike i bought the serial number is SNFS09G41987
Absolutely no way to ID a bike by serial number alone. The brand of bike is on the head tube (where the fork goes through the frame) and the model is on a decal on the frame. If those are missing it DOES NOT MATTER what the bike is, and it's possible it is stolen. Parts are universal and a (cheaply) repainted bike has little value.
Jun 13, 2017 | Cycling
Mongoose Canaan - Crack in frame
If I were you,and the frame is cracked...I would not ride that bicycle!
Jul 13, 2013 | Mongoose Canaan Team
Tighten front suspention on a Mongoose 26
Look for knobs on the tops of the suspension fork legs that will probably have a + and - sign on them. Turn them in the direction of the + (usually to the right) until you are satisfied.
If you have already tried this or it doesn't give you adequate results; you may be stuck. You can occasionally find stiffer springs to put inside; but this is sometimes more costly than is desirable and a little more mechanically difficult to do on your own if you're not comfortable with disassembling and reassembling the fork.
Just a guide though: ideal suspension firmness allows for some movement when you get on the bike and will use all of it's travel on the biggest bump you encounter.
Oct 08, 2012 | Mongoose 26" Ledge 2.1 Mens Mountain Bike
Mongoose mozo m30 forks are sponggy
Change the spring to your load.
Adjust Mozo M30 Fork Suspension - Beckman Du-70 Forum
efratoium.xyz/Adjust-Mozo-m30-fork-suspension/
Results 1 - 15 of 15 - Mongoose XR 150 mozo m30 front forks rebuild. A quick ...Mongoose mozo m30 forks are sponggy on my XR150 mongoose mountain bike.
mozo??- Mtbr.com
forums.mtbr.com/shocks-suspension/mozo-167281.html
Feb 20, 2006 - 15 posts - ‎6 authors
... of a mozo m30? is it the junk im assuming came on my mongoose? ... into a halfway decent bike. and all i can get off the fork is mozo m30 ...
Mongoose XR250 Suspension Upgrades ' Bicycling Magazine Forums
forums.bicycling.com/topic/54635607127666779
Sep 30, 2012 | Mongoose Exile 26 Men's Full-Suspension...
How to remove front forks
Repainting via rattle-can is a bad idea - looks poor and will not hold up. As for forks, just google "overhaul threadless headset."
Jul 29, 2017 | GMC Denali 700C Road Bike
Paint flaking off a carbon fibre bike frame. I have recently bought a road bike and when removing the front wheel to place the bike in the back of my car the paint at the bottom of the carbon fork (where...
Perhaps, the dropouts on frames and forks are are usually metal and the serrated surface of the Quick Relase Skewers normally digs through the paint to find a purchase in metal.
This forum discusses Look forks with carbon dropouts.
http://forums.roadbikereview.com/bmc/carbon-dropouts-durability-137519.html
http://www.cyclingcrowd.com/Uwe/Forum.aspx/technical/25794/Tightening-wheels-on-carbon-forks-and-frames
If your unnamed fork's dropouts are indeed carbon does your owner's manual specify and special handling or skewers for them?
Read about 'boutique' skewers.
http://sheldonbrown.com/skewers.html
Aug 21, 2011 | Cycling
Describe how to remove the front tire of a mongoose bmx bike
loosen the bolts on the ends of the axals of the wheels on the forks
Sep 03, 2010 | Freestyle Mongoose Bmx & Owners Manual -...
I have an otero mongoose bike how do i take the front tire off
The front wheel is removed by releasing the quick release located at the bottom of the fork. The tire can be removed by deflating the tire and then levering off the tire itself using a set of special removal tools.
Jun 04, 2010 | Mongoose 2009 Otero Comp Mountain Bike...
Front suspension to soft on mongoose xr-75 mountain bike
The front forks aren't adjustable, as you probably figured out. You can, however, get harder springs if the springs can be accessed at the top of the fork tube. If not, do what I did on my mountain bike. I bought a better pair of adjustable forks that I found on eBay. It will take a bit of investigation on your part regarding the dimensions of the forks, so you get the correct length and width where the forks fit onto the frame (and the overall desired fork length), but you'll be a lot happier with adjustables.
Jun 14, 2009 | Cycling
Cycling Logo
44 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
