Question about Zanussi Dishwashers
2 green flashing lights. can hear pump working then nothing
Model de6775 just changed water heater and it was working fine.
    Problem Solver:
  • 10 Answers
If there is no water in the dishwasher you probably sucked a big chunk of calcium into the supply line. shut off valve under sink, disconnect hose turn water on as hard as you can without making a huge mess catching it in a pan or pot. make sure you know where the outside shut off is in case something unforeseen happens. if you get goood flow but some chunks in the water, re connect and try washer. if not then turn off water an remove hose again. take the bottom off of the front of the dw usually only two philips screws. youll see where the water is attached, usually near the front on the left. may need a 7/17, 1/2 or 9/16 open ended wrench. remember "lefty loosy" when you see the nut holding the pipe on from the pipe side, it will probably be aiming away from you toward the back, if it is, it will be the opposite of above. if unsure try one direction a little, then the other, even if it move a little going the wrong way. trust me on this. Blow out the line and get the heater debris out of the line, re connect and water on... should be good. might be nice to know what it says below the two flshing lights.
Posted on Feb 12, 2012
Dolce Gusto KP2100 - Fault
as per your report we understand that there must be something wrong with boiler/hear or with the heating sensor. So that when you try for hot water because of safety reason it gets automatically switched off. Please rush near to your service center as we do not advise you to fix this issue.
Mar 19, 2017 | Coffee Makers & Espresso Machines
Green light flashes, book says that there is a problem with heating circuit. How can I check this
Hi
If green light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
Clean light "green" flashes 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry or high temp wash-heated dry-high temp wash-heated dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 29, 2011 | Dishwashers
Normal light is flahing unit will not go on sometimes time remaining indicator will flash started awhile back by not being able to change any settings but unit would work now nothing have tried...
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Feb 04, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
My "clean" light flashes even
Hi
Jan 30, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Zanussi zwf 1430s,power going to machine but when button pressed green light does not come on just a red light nothing on display panel
Count how many times the red light flashes and how many the green light flashes.If its 1 green and 1 red thats water problems.If 2 flashes of red light check filter is clear and pump is free to turn.
Hope this helped.
May 18, 2010 | Washing Machines
1993 QCA Dream Master spa. Worked fine when drained last fall. Winterized with RV antifreeze. Just filled it and nothing happens. Heater light on solid for 30 seconds then starts flashing. Any ideas?
You probally have an air lock. All you need to do is find the drain valve and open it long enough to get water running full. This will flood the pipes and the spa should start. Good luck.
Mar 10, 2010 | Qca Spas Dream Series Dream Master Hot Tub...
Rheem model #GP40T6PF00 lp hot water heater Will
sounds like one of the saftey relays might be going bad. or the ingniter might be cracked or need cleaning
Mar 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Saeco Italia SUP021 YR green lights and red water light flashing
You can't manually reset. The machine will have to do it. I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Sep 14, 2009 | Starbucks Saeco Italia Digital Barista...
Dishwashers Logo
62 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
