No flow through danfoss thermostatic radiator valve
    Scholar:
  • 121 Answers
This valve opens and closes according to room temp. Make sure that valve is set and operating properly. If so that radiator may be air locked and should have a bleeder valve on the top somewhere. When you open it air will come out until water, let it bleed water out for a couple of minutes. I hope this helps you.
Posted on Oct 24, 2008
Programming the danfoss thermostat
You can download the instruction for your thermostat from the Danfoss site.
Dec 08, 2017 | Danfoss Garden
How do I get my radiators to start working?
ch1 indicates wirless thermostats? check the thermostats in the room have fresh batteries. this type can be wired but may be running on batteries you have to use a screw driver from below to open the unit. if you dont have a manual here is a link.
http://www.manualslib.com/products/Danfoss-Randall-Tp5000-Si-Range-2781091.html
i hope this helped
Oct 22, 2014 | Heating & Cooling
What is mean by thermostate valve
The thermostat is a critical part of your coolant system, the system that circulates water and antifreeze (coolant) through the engine to keep it from over-heating. It is called a valve because it can open and close, depending on how hot the coolant is acting upon it.
The reason to put a thermostat in the coolant system is to allow the engine to reach normal operating temperature quicker (and therefore operate at peak efficiency) than without a thermostat.
When the engine is cold, the coolant is at normal outside temperature, so the thermostat is closed. This means when you start the car, the coolant starts circulating through the engine, but can't flow into the radiator. With a closed thermostat, the coolant just keeps circulating around in the engine until the car warms up, the coolant gets hot, and the heat acts upon the thermostat, causing it to open at a certain temperature (about 185-195 degrees F.), With the thermostat now open, the coolant can now enter the upper radiatior hose and flow down the radiator to cool itself down, before going back into the engine through the lower radiator hose.
So the thermostat is always found on a car in the area where the upper radiator hose connects to the engine. Thermostat closed-water can't circulate through the radiator. Thermostat open- coolant is forced through the hose into the radiator.
I hope this helps you understand the thermostat valve and why all manufacturers include them.
May 27, 2012 | 2011 Fiat Punto Evo
Where is the thermostat located
Your engine must be cold before removing the thermostat.
Find the location of your thermostat by following the rubber hose located on bottom of your radiator (passenger side) to the point where it attaches to the engine. Remove the two bolts at that location and you'll find your thermostat nestled in there.
Be sure to place a pail under the car to contain the coolant.
Thermostat Operation:
00047_thermostat.jpgThe automotive thermostat is a temperature controlled on and off valve. When the temperature rises to a predetermined temperature, the thermostat opens up to allow the engine coolant to flow through the cylinder block and the radiator. This flow is crucial to maintain optimum operating temperature for fuel efficiency, enhanced driveability, and engine protection. The coolant flow is reduced when the engine is cold, and the flow is increased when the engine is hot. Contrary to popular opinion, operating the vehicle without the thermostat doesn't make the engine run cooler. It will actually run hotter because there isn't a thermostat to slow the coolant flow. This means the coolant doesn't stay in the radiator long enough to dissipate its heat.
All the best
Ben
May 24, 2011 | 1993 Cadillac DeVille
How do i bleed my thermostat on a 2002 buick century custom
RUN ENGINE FILL WITH ANTIFREEZE AND THERE IS A BLEEDER SCREW ON BYPASS LINE/HOSE ON TOP OF ENGINE NEAR BELT. THERE MAY ALSO BE A BLEEDER ON THE THERMOSTATE HOUSING. CRACK OPEN BLEEDERS UNTIL ALL AIR COMES OUT.
Dec 19, 2010 | 2002 Buick Century
Danfoss TP5 programming manual required
This is the full manual:
http://danfoss-randall.co.uk/PCMPDF/6218.pdf
Very well hidden away on the Danfoss website!
Oct 29, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
225 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
