Question about Lexmark Office Equipment & Supplies
Lexmark x7350. My fax is not working although the line/ink/paper is Ok and we have it on fax auto answer.
    Problem Solver:
  • 6 Answers
Make sure fax forwarding is off also check to make sure the phone cables are correct also if you have an answering machine you have to make sure the number of rings is set uo correctly and that you may have to set up the distictive ring tone if this line has an answering system.
Posted on Oct 24, 2008
X7350 lexmark to windows 7
you will have to remove the printer software and then reinstall it again some of the driver flies has gone when you clean the system from virus
Apr 17, 2012 | Lexmark X7350 All-In-One Printer
Can lexmark x4650 be set to recognize fax?
For more details on how to setup your Lexmark X4650 printer for faxing, please refer to the User's Guide found on the Lexmark website.
Additional info:If you have an answering on the same line as your fax:
To make sure the printer picks up incoming faxes, set Auto Answer to On, and then set the printer to pick up after a greater number of rings than the answering machine. For example, if the answering machine picks up calls after four rings, then set the printer to pick up after six rings. This way, the answering machine picks up calls first and your voice calls are received. If the call is a fax, then the printer detects the fax signal on the line and takes over the call.
If you have a voicemail feature associated in the same line as your fax:
Voice mail and fax can share the same telephone line if you subscribe to a distinctive ring service offered by your telephone company. This feature allows you to have multiple telephone numbers on one telephone line. Each telephone number has a designated ring pattern (single ring, double ring, triple ring, or double and triple ring). The different ring patterns let you know which telephone number was dialed, and which device you should use to answer the call.
If you do not have distinctive ring service, then set the printer to receive faxes manually (Auto Answer Off). This setting lets you receive both voice calls and fax calls, but works best if you use voice mail more often. You need to turn off voice mail whenever you are expecting a fax.
Feb 16, 2012 | Lexmark X4650 InkJet Printer
My Lexmark X5650 (Model number: 4437-001) will not auto answer faxes. It can be manually be answered, and the settings are for auto answer. I can also send faxes too with no hassle at all.
bbargains,
Here is the correct procedure to receive a fax automatically;
Make sure the printer is on and is connected to a working phone line.
Make sure that Auto Answer is on.
To check if Auto Answer is on:
From the printer control panel press the wrench sign.
Press the arrow buttons until Fax Setup appears, .
Press the arrow buttons until Ringing and Answering appears, and then press
OK to save the setting.
Press OK again.
Check to see if Auto Answer is set to On.
If Auto Answer is not set to on, press the arrow buttons until On appears, and then
press to save the setting.
Set the number of times the telephone rings before the printer automatically
receives faxes:
Press the arrow buttons until Pick-up On appears, and then press OK .
Press the arrow buttons until the setting that you want appears, and then press to
save the setting.
When the number of rings you set is detected, the printer automatically receives
the incoming fax.
This should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | Lexmark X5650 All-in-One InkJet Printer
HOW DO I GET MY FAXES OUT OF THE MEMORY?
Receiving a fax
Receiving a fax automatically
1 Make sure the printer is on and is connected to a working phone line.
2 Make sure that Auto Answer is on.
a From the printer control panel, press (tool icon).
b Press the arrow buttons until Fax Setup appears, and then press ok.
c Press the arrow buttons until Ringing and Answering appears, and then press ok.
d Press again.
e If Auto Answer is not set to on, press the arrow buttons until On appears, and then press to save the setting.
3 Set the number of times the telephone rings before the printer automatically receives faxes:
a Press the arrow buttons until Pick-up On appears, and then press ok.
b Press the arrow buttons until the setting that you want appears, and then press to save the setting.
When the number of rings you set is detected, the printer automatically receives the incoming fax.
Receiving a fax manually
1 Make sure the printer is on and is connected to a working telephone line.
2 Make sure that Auto Answer is off.
3 To receive the fax, press (green botton) or press * 9 * on the telephone after you answer it and hear fax tones.
4 Hang up the telephone.
The printer receives the fax.
Receiving a fax with an answering machine
1 Make sure that Auto Answer is on.
2 Make sure you have set the number of times the telephone rings before receiving a fax automatically.
When a telephone ring is detected, the answering machine picks up the call.
• If the printer detects a fax, it receives the fax and disconnects the answering machine.
• If the printer does not detect a fax, the answering machine receives the call.
3 Set the answering machine to answer incoming calls before the printer does.
For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls
after five rings.
Forwarding faxes
Use the fax-forwarding feature if you are going to be away, but still want to receive your faxes. There are three
fax-forwarding values or settings:
• Off—(Default)
• Forward—The printer sends the fax to the designated fax number.
• Print & Forward—The printer prints the fax and then sends it to the designated fax number.
2 Press the arrow buttons until Fax Setup appears, and then press ok.
3 Press the arrow buttons until Ringing and Answering appears, and then press ok.
4 Press the arrow buttons until Fax Forward appears, and then press ok.
5 Press the arrow buttons until Forward or Print & Forward appears, and then press ok.
6 Enter the number to which you want to forward the fax, and then press ok.
Aug 12, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
A neighbor just gave me this printer...It says low
If you don't want to spend money on ink the a Lexmark is the last printer you need. It's cheaper to buy a new one!
Dec 28, 2009 | Lexmark X7350 All-In-One Printer
Lost manual
There is no much to hook up, you hook up the RJ11 phone connector at the back of the printer to the phone line.
Install printer software onto the computer.
Then connect printer to computer using USB cable.
See here , there is user guide for all x7300 series:
User's Guide
see also
Lexmark X7350 Top 20 Questions
Here also notes on how to set up fax
Lexmark X7350 - fax problem
Sep 08, 2008 | Lexmark X7350 All-In-One InkJet Printer
Trouble with faxes
get phone line error when trying to send a fax, how can I fix
Aug 20, 2008 | Lexmark X7350 All-In-One InkJet Printer
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
