Sonim xp5300 software crashes and hangups
Phone crashes and "reboots" every now and then, when i push the buttons. It appearently has severe problems with connecting to the network, thus frequently searching for an available network. upon "reboots" it may have to do so 5 to 10 times before I actually get to type in my pin-code... So, can anyone help, or at least tell me wether this is likely a software, hardware, network or SIM-card related problem?
SOURCE: Phone will not connect to network
hi i was also having the same problem but i installed radio version 1.13 for my mini and the problem is somewhat solved though not completely
Posted on May 21, 2007
VIPer6
  • 29 Answers
SOURCE: isert sim card
Hi nay,
there's simple solution, first, take out the sim card and battery, then put it back again, switch the phone on, the phone will ask you "do you want to stay in offline mode?", click no. then you'll have your network again, if the message don't came out, then there's some probabilities.
1. sim card connector.. see those yellow (look like gold coloured mostly) pins that usually beneath your sim card if you insert it? probably when it's fall, it's bent, so your sim card mght not be well attached to your sim card connector. raise the feet (pins) of the sim card connector, so it became higher. so that you make sure your sim card is touched by all the pins. replace the battery and sim card, switch on again. mostly will help. but if not, try below steps
2. probably There's something cracked or broken from the body of your phone (inside), so your phone become loosened up - mainly at the screws(your sim card become not well-attached), so what you have to do, is take a screwdriver for nokia, and strengthened the screws. If it can't, try borrow 6630 of your friend, try your board (machine board) to your friend's 6630 body. If it doesn't work, then it means something on your machine board (component) is broken, not because it's just loose.
If you doesn't have friend that use 6630 too, or you feel it's hard to open your phone, look closely if there's any major crack on the body of your phone, if it does. go to any mobile phone sparepart or accesories shop, buy a new body and ask them to cahnge it (actually piece of cake, try it..) well if it doesnt work, there's nothing to lose, because anyway if you want your phone fixed, you're not gonna use it with a cracked body. (differ body and casing)
3. If you're sure none of above helpful, then it means , some component is broken. Usually it comes to SIM card connector feet (that is attached to your machine board) or the sim card IC, some small possibility is you UEM IC is broken, but in this case, i suppose not.
your sim card connector feet (attached to machine board) might be not well attached (lifted up) caused by the crash when you fell your phone down. so it just need to be reattached by solder. you need a technician for these. if it doesn't help, your sim card IC need to be replaced by a new one (this IC SIM CARD is make of glass, so it's so fragile), leave it to the technician, this shouldn't cost more than 10-20 usd i promise ^^
Good luck with raising the pin (the one that touch your sim card-don't be confused) of your sim card connector. Mostly will help ^^
Posted on Nov 17, 2008
  • 54 Answers
SOURCE: fone was working fine, all of a sudden i had no network coverage,
Sometimes the memory cards hold viruses
maybe she gave you one that held a virs on it.
You need to take your phone to the store providers and let them trouble shot it.
Posted on Jan 20, 2009
rightpricede
  • 30 Answers
SOURCE: restore &update problem
what sim card are you trying to use after the restore in itunes and also when you finished the restore in itunes did your iphone come up with a message saying iphone activated?
go here click here and tell him what has happend this chap is a god with iphones he actually makes his own software etc for iphones.
Posted on Jan 29, 2009
SOURCE: Iphone Unlocking Problem
hi,try this way.cydia hit MANAGE,go to sources,you will see repo666.ultrasn0w.com,please instal it,if you did try reinstal..it will work.good luck
Posted on Sep 06, 2009
My Sonim XP3 Quest Pro write sometimes fileerror.return when I have an incoming call up and it is not ringing
Hi Riisbjerg, you could try to reset/clear flash the phone. That should take care of the problem, but it also erases ALL settings and phone book entries from the phone, so it is best to make a backup of the phone bookwith the PC tools software.
The software can be downloaded from http://www.sonimtech.com/support/downloads.php
Reset: Please try to reset the handset memory as below:
a. After Powering ON the phone
b. press #20070114# from phone idle screen and press dial key.
c. Message comes up as " Do you really want to clear flash? "
d. Select OK. After reset is finished, you can see the message "Switch off the mobile by any keys".
e. Switch the phone off, then remove and reinsert the battery and Power ON the phone.
Once done, please restore the handset to factory settings:
a. Power the handset on
b. Using the menu buttons, go to Settings (General Tab) -> Default Settings.
c. Press the OK button to confirm
d. Power the handset on again
If this does not help, please send an email to the Sonim support team: support@sonimtech.com
Thanks!
Andreas Sonim Customer Service
Jan 15, 2011 | Cell Phones
Imate, ultimate 8502, when i started to boot, hangup at "align screen" i already tapped the screen at 4 corners, but still hangup at align screen, so pls guide me what i have to do
imate, ultimate 8502, when i started to boot, hangup at "align screen"
Jan 02, 2011 | i-mate Ultimate 8502 Cell Phone
Sonim XP3.20 Quest Blank Screen
I have also encountered this problem. It must be due to overloading of the fones ram resulting in freezing
Feb 22, 2010 | Cell Phones
No sign of phone charging
I finally have spoken to a very nice youn guy from Sonim Tech Support. He fixed my problem of the phone not turning on.
1. Take out the battery, plug in the mains charger and leave for a few minutes (they say 10 but it took my phone a couple of hours).
2. Eventually the charging symbol will come on the screen, either stady or flashing.
3. Immediately put the battery in the carcass (while it is still connected to the charger), and the charging symbol should stay on.
4. Leave the phone for a couple of hours, disconnect the charger, and the phone should turn on as normal.
This was explained to me, the reason for not turning on was that the software had crashed. This solved it.
Sep 01, 2009 | Sendo Sonim XP1 JCB phone extreme...
New Samsung sch-430 won't shut off
try taking out the battery for five minutes
Mar 30, 2009 | Samsung SCH-u430 Cell Phone
Always Hang-up and almost all of my mp3 data was corrupted after playing it in several times.
my sony mp4 mp3 made in chins is hangup not working plaz give me solution
Nov 14, 2007 | Sony NW-E507 MP3 Player
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
