Question about Dell Computers & Internet
Battery compartment how do I replace the battery on this laptop. Where is the battery located?
  • TCHEEK5682 Mar 15, 2009
    PP01X
    DON'T KNOW IF THE PROBLEM IS THE BATTERY OR THE HARD DRIVE. IT POWERS UP BUT ONLY DISPLAYS THE WINDOWS 2000 LOGO. THEN A BLUE SQUARE TELLING TO CHECK THE HARD DIRVE. HOW COULD YOU POSSIBLY CHECK THE HARD DRIVE WHEN THE COMPUTER ONLY GOES THAT FAR IN COMING ON?
Dell Inspiron 8100 laptop Model PPO1X .......where is the battery compartment located cause I would like to replace it and can't see where it is on the laptop.
Posted on Oct 24, 2008
    Master:
  • 538 Answers
Well..can you supply us with the model number please?
How reset bios password
  • Power down the computer by clicking the "Start" and "Shut Down" button. Allow the computer to turn off entirely and wait about 30 seconds. Unhook the AC adapter from the computer. Turn the computer over and locate the battery compartment near the display hinges. Push the latches away from each other to unlock the battery. Remove the battery from the laptop.
  • Locate the memory compartment found on the opposite end of the laptop's bottom. Unscrew and remove the single phillips-head screw using a precision screwdriver. Pry the metal door off the laptop using the screwdriver.
  • Locate the memory module. Directly under the module is a blue plastic sleeve connected to the mainboard with a single wire. Disconnect the wire and wait about 30 seconds. Reconnect the wire to the mainboard and replace the metal memory door. Secure the door to the laptop by tightening the phillips screw with the screwdriver.
  • Reinstall the laptop battery, inserting the tabs first and clicking downward. Plug the AC adapter back into the laptop. Flip the computer over and power on the system. Enter the BIOS and change the password if desired, or leave it blank for no password prompt.
Nov 12, 2013 | Computers & Internet
How to change the cooling fan in a toshiba laptop model p200d-139
Instructions
Shut down your Toshiba laptop, and then disconnect all cables. Close the LCD lid, and then place the laptop face down on a flat surface. Position the laptop with front edge facing you.
Locate the battery pack near the top section of the laptop's bottom casing. Press on the battery release button. Remove the battery from the laptop.
Locate the cooling fan compartment cover. Its location varies from laptop to laptop, but it will be the only hardware cover with a vent in it. Remove the Phillips-head screws securing the fan's cover in place. Remove the cover from the laptop.
Disconnect the fan's cable from its connector on the motherboard. Remove the Phillips-head screws securing the fan in place. Lift the old fan out of the fan compartment and set it aside. Removing the old fan will reveal the processor chip. Apply a thin coat of thermal grease to the processor's surface using a clean paper towel. This will prevent your new processor from frying once you power on your laptop.
Place the new cooling fan assembly inside the fan compartment. Align the screw holes on the new fan with the screw holes inside the compartment. Replace the four retaining Phillips-head screws, and then reconnect the fan's power cable to the motherboard. Replace the fan compartment's plastic cover, and its retaining Phillips-head screws.
Replace the battery pack and reconnect all power cables and external devices. Turn on your laptop to test the new cooling fan
Jul 28, 2012 | Toshiba Computers & Internet
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
Dec 12, 2011 | Dell Latitude D505 Notebook
Acer aspire 5515 cmos battery location?
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps!
May 22, 2011 | Acer Computers & Internet
How to replace memory cards on a dell laptop D600
Hello.
There's a great article found online from eHow with the following instructions:
Things you'll need:
  • SO DIMM 200-pin DDR SDRAM memory module
  • Phillips screwdriver
  • Shut down any currently running applications and turn off your laptop. Disconnect the power cord and any other attached cables. Remove any installed PC cards. Turn the laptop over and locate the battery compartment at the front edge of the device. Push the latch in the direction it indicates and remove the battery from the laptop.
  • 2 Examine the memory module cover, located next to the battery compartment. Unscrew the screw securing the memory module cover to the laptop. Remove the cover and set it aside.
  • 3 Push apart the clips located on either side of the currently installed memory module. Slide the module out of the socket and set it aside.
  • 4 Align the notch on the connector end of the memory module with the crossbar in the socket. Insert your replacement module into the socket and apply firm pressure until it is seated properly. Push the module downward until the clips lock it in place.
  • 5 Replace the memory module cover and screw it securely in place. Reinsert the battery into the battery compartment. Reinstall any previously removed PC cards and reconnect the power cable and any other previously disconnected cables. The laptop is now ready for use.
  • Hope this helps.
    Dec 23, 2010 | Computers & Internet
    How do i reset the bios password on a compaq presario756 nr notebook i lost all my info and am havein trouble unlockin my bios password i for got
    remove both batteries, unplug the power leave it for about 60 seconds, put the power back and on then try to enter bios
    Oct 28, 2010 | HP Compaq Presario F756NR Notebook
    Need to replace internal clock battery
    This may have been solved by now however...
    REMOVE MAIN BATTERY... Before Opening any compartments!
    The CMOS battery is located in the modem compartment.
    Place the unit upside cown with the rear connectors facing towards you. It is the compartment on the right rear corner (i-screw to remove). It may be difficult ro open due to the modem labe sticking to the cover. Use care when attempting to pry door open.
    Battery is CR1220 0.5in Diameter (Dime Size) (40mAh Rated).
    Alan
    Feb 22, 2010 | IBM ThinkPad 390X 2626 Notebook
    I have a dell laptop and I'm not sure how to disconect it from the external battery
    To remove the battery, flip the unit over and push the battery release latch to disengage the battery.
    The reserve battery is located in a compartment within the battery bay. To replace a reserve battery, first open the reserve battery door:
    Pull the reserve battery out of its compartment, and disconnect the cable from the connector.
    Oct 03, 2009 | Dell Latitude D600 Notebook
    Need to replace RTC battery in dv7-1240 hp
    Battery is usually located on bottom of laptop usually takes 1-4 screws to get it out.
    There are usually 2 compartments on the bottom, one for RAM memory upgrades and the other compartment is the battery.
    May 25, 2009 | HP Pavilion ze2000 Notebook
    Where is the CMOS battery?
    Yes that was the cmos battery, I'll see if I can find a better solution for this issue for you.
    Feb 13, 2008 | Compaq Armada M700 Notebook
    Computers & Internet Logo
    125 people viewed this question
    Alun Cox
