Question about Daewoo Washing Machines
I have Daewoo washing machine dwd fd1443, i stopped washing cycle and displayed an error E9, when press power button error E2 appeared and making beeps, I have no idea how to fix this problem!!
Model: dwd fd1443
Master_Tech
  • 770 Answers
SOURCE: Daewoo Washing machine Problem
If it is new then it is under warrty plz call the dealer you bought iy from for service
Posted on Aug 02, 2008
SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
Posted on Jan 11, 2009
  • 44 Answers
SOURCE: Error E2
A model number always helps when you're looking for help. ;)
I looked through about twenty manuals looking for an answer for you; I suggest that you'll have better luck if you have the model #.
Here's the link to the many, many, many Daewoo washer manuals.
WashingMachine&cpage=1">http://www.dwe.co.kr/english/support/download.asp?class1=5&class2=19&class3=0&selorderby=1&searchpath=WashingMachine=>WashingMachine&cpage=1
Good Luck!
Posted on Aug 08, 2009
  • 6277 Answers
SOURCE: i have a daewoo front
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 05, 2011
SOURCE: Daewoo DWD G1243S washing machine
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
Posted on Aug 30, 2011
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
I have a bwm 50 washing machine displaying e2
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
To fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen) (and neither with mine)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing
Hope this helps
Bob
Jan 12, 2015 | Washing Machines
E9 message and machine stops
Jayshree, E9 error, pressure sensor error/water sensor error.
Replace water level sensor. The error display disappears if power button is turned off and on.This is what the service manual states.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Daewoo DWD M103 Service Manual Page 15 of 16
Daewoo CV701PC Service Manual Page 26 of 52
Daewoo Washing Machine Error Fault Codes
Washing Machine pressure switch
Apr 20, 2014 | Daewoo DWD M1031
I believe the EO code means the pump is blocked, and you will have to clear the pump for it to work again.
Oct 12, 2013 | Daewoo Washing Machines
E9 E2 ERROR
Message = E2
Error = OVERFLOW ERROR
Cause & Solution =
The water is supplied continuously due to an defective inlet valve. Change the valve inlet.
The valve inlet is normal, but the water level sensor Change the water level sensor
(sensor pressure) is low. (sensor pressure).
The drain motor does not work - Test and if faulty change the drain pump
Message = E9
Error = SENSOR PRESSURE ERROR
Cause & Solution = The water level sensor is faulty. Change the water level sensor. (remove pressure tube and blow through it to make sure it is clear first)
Mar 10, 2012 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Dwd f1011 washing machine, error codes E2&E9, machine not working
Jan 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Aug 02, 2008 | Daewoo Washing Machines
Washing Machines Logo
29 people viewed this question
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
