Question about LG RH266 Recorder
RH266 read-only hdd
Had power cut now hdd will not record
SOURCE: Lg rh266 recorder
When you put your disc in and its ready for copying over through Dubbing - when you see the quality ie xp - just press right or left til the FAST sign comes up. it maynot always come up if the recording time is any longer than an hour or less than 30 mins.
pg 47 of your manual
Regards Chris
chrisbradley80@gmail.com
Posted on Jan 03, 2008
SOURCE: Recording problem with LG RH266 Recorder..
Just bought unit. Had same problem.Tried lots of different types of disks with no luck. Tried to play already written +R disk. Worked OK. Then took out and replaced with blank -R. Came up with new screen asking me if I wanted to initialize disk. Answered yes and it took about 20 seconds. Then tried to DUB from HDD to DVD again. This time it came up with the dubbing menu, I hadn't seen before, and worked.
Hardly ideal, but the trick was to get it to recognise it as a blank and initialize. Currently burning my first disk. Didnt realise about 'FAST' mode, so taking ages.
Posted on Apr 19, 2008
SOURCE: Finalization problem2
After transfering video from HD to DVD, before you press the "Menu" button. please make sure you you press "DVD" button on your remote to tell the machine you want the menu for "DVD" first.
It confused me at first :-)
Hope this helped
Posted on Jul 24, 2008
PABLOCSA
  • 1124 Answers
SOURCE: HDD/DVD Recorder RH265 or 266
Clean the optical lector first. If the problem is with your HDD, try to reset the system.
If still problem remains trying to formatting the HDD, if doesn't work the HDD must be replaced.
Posted on Oct 10, 2008
vortash
  • 431 Answers
SOURCE: I mislaid my operations manual for LG rh266 hdd/dvd recorder
Try the manufactures site for this if not available , I have found most manuels available on Bit torrent hope this helps ..Regards Vortash
Posted on May 12, 2009
Will play discs burned from hdd but not commercial movie type dvd
The solution is simple.I rang LG service (so called - LOL)
Asked for a fix or reset method. (Which can be done but they won't tell novices how)
Got no joy, so now I will bin it,and spend the rest of my days telling people to avoid LG.
After all the posts I have since read about the same problem on various LG models,it is obvious their product sucks,they know it does, but won't accept the responsibility.
If I stop 4 people buying their ****,that's at least $1000 they miss out on.
If the process snowballs,how much then$$ ?
It would cost me $120 just to get it to and pick it up from the repair place.
Plus parts and labour added.
Before buying an LG DVD recorder go online and check out how many dissatisfied customers there are. In short, DO NOT BUY !!
Jul 18, 2009 | LG RH266 Recorder
Mar 18, 2009 | LG RH266 Recorder
Eject dvd doesn'start recording
This sometimes happens when a disk is not formatted prior to recording .. the DVD is telling you it cant record on it at the time you want because it would have to format first and then start recording so missing the times you have set .
Best thing to do is use re- recordable discs only and format prior to use then the dvd should start straight away .
If not then the set has a serious read problem and requires looking at by a qualified engineer ... Regards Vortash
Jan 30, 2009 | LG RH266 Recorder
LG RH266 DVD Recorder no sound
Hi .. It sounds like the problem you have is incompatabilty I assume that you haven tried Phono connections instead of scart , as this sometimes cures this problem .. or when purcahsing a scart look for the Miirrored type this means that the inputs and outputs are reversed this also sometimes cures the problem as some scarts put output to output and input to input ect when actually it should be output from tv to input dvd and so on ie wrong scart and there are a few of the cheaper type that have this problem .. if you have no luck using the phono let me know .. Regards Vortash
Jan 07, 2009 | LG RH266 Recorder
If the DVD is copy right protected then it won't record. By this I mean, you can't simply rent a DVD at Blockbuster and transfer it to the Hard Drive (use a computer to do this instead). Try using a DVD that is not protected, like a home video or a cd with MP3s
Feb 26, 2008 | LG RH266 Recorder
Hope this helped
Feb 11, 2008 | LG RH266 Recorder
Record at once on dvd?
No direct record from TV to DVD on this model, yes it is very annoying...
Jan 16, 2008 | LG RH266 Recorder
Jan 05, 2008 | LG RH266 Recorder
Lg rh266 recorder
Regards Chris
Dec 20, 2007 | LG RH266 Recorder
LG RH266 Recorder Logo
