Question about Philips Televison & Video
How to fix a tv that tirms off by itself - Philips Televison & Video
    Problem Solver:
  • 10 Answers
Check thru menu that there is not some timer running then, depending on how often it occurs, put on a show you will watch for awhile and cover the infared receiver, if your remote does shut off you know you will be getting an aberrant signal from some other source. notice my neighbor had a remote for his ceiling light the was shutting my tv off, just changed the angle an that fixed it.
Posted on Feb 12, 2012
  • adreezy88 Feb 12, 2012
    Its a 40 inch lcd philips, only had since october, this is the second time it has done this in that time, first time it stopped after 24 hrs roughly
02 Suzuki vitara getting an p0340 code on diagnostic tool. replaced the camshaft sensor and engine still just turns over without starting. eng. is a 4cyl gas burner
no country stated?
gas. ok,...
now engine stated.? G16, or j20? radially different they are.
i cant see which CMP you have
the huge puck type,
or the same with extractable small CMP sensor
the latter is easy swap
the former must be timed using the timing freeze jumper clip.
no story here, the full story
one day, it stalled.
then i scanned it and 340 popped
or got 340s after the new sensors.????????
no matter check for spark.
if got spark x4
check timing,? yes, timing light work on dead engines. sure do.
if timed wrong, then you did that.
if G16 engine the cam belt slipped,
j20 is chain drive cam.
j20 has CMP sensor on the left rear DOHC cam.
if sparks ok, test fuel now works, sprayed.
Jan 17, 2017 | 2002 Suzuki Vitara
TV would shut off by itself and then several minutes later be able to be turned back on. A day later it shut off by itself, turned itself back on, shut its self off then a huge pop sound as purple and...
That tv is very old and it just reached its life expectancy. It could be repaired but it will cost you more than a brand new tv. Black Friday coming up and you will find a great deal.
Oct 29, 2013 | RCA HD52W59 HDTV Projection Television
Heater blower
On a 2003 Sierra the blower motor is under the passenger side of the dash. There will be a plastic tirm pannel that will need to be removed to gain access to the blower motor.
For more info on diagnosing a blower motor that does not work click here
Feb 06, 2012 | GMC Cars & Trucks
Where is the heater blower located
Feb 06, 2012 | 2003 GMC Sierra
Fuel pump location needed as fuel pump failing. on 2003 grand am. estimate tirm to re and re and costs.
not sure what your back half of the question is but the flue pump is in the gas tank, you have to pull the tank. a little hint the tank weights a lot less empty then full.
Oct 01, 2010 | 2003 Pontiac Grand Am
Authorization code i need
If you are talking about the Authorization code for Photoshop CS Please buy your own copy from this link and get your own key. Such illegal things are not allowed at FixYa.
Regards, Waqar
Aug 15, 2009 | Adobe Photoshop CS for PC
Vizio L42, wont turn on
Usually when this happens, the TV is in Protection Mode. When the TV detects something has gone wrong inside, the TV will prevent itself from turning ON.
Try leaving the TV unplugged for 30 -45 minutes so the TV can discharge and reset itself. If this doesn't fix the problem, most likely it's a power supply board related issue. At that point, you may want to get a price quote from a local TV repair shop. The cost of fixing the TV may exceed the price of a brand new TV.
Aug 06, 2009 | Vizio L32 32 in. LCD HDTV
Philips Magnavox TV turns itself off and on
I had a problem that has not been fixed that i had put glass cleaner on my tv and every time i turn it off it comes back on sooo i do not have a solution so i need more and cheap ways to fix my tv.
p.s. i am 9
May 19, 2009 | Philips Magnavox 32PS55S 32" TV
Toshiba 27af45 turns off by itself every 15 minutes..how do I fix
I think the timer setting in your TV is broken. Try fixing this.
May 07, 2009 | Toshiba 27AF45 27" TV
Televison & Video Logo
149 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
