Question about Dishwashers
We have a Westinghouse Alu design dishwasher we inherited with our house. We think it's about 8 years old. Whatever wash cycle you select the machine always reverts to just the rinse cycle. We won
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
Rotu
  • 175 Answers
SOURCE: Asko 1585 Dishwasher
do they flash lik all on one side then the other? Start a cycle, then open the door. Do the lights flash the same way when you open the door as when it stops? if soyou may have a door that needs to be adjusted so it closes better. when the cycle ends, is there any standing water in the bottom? if so you may have a poorly routed drain hose or a partial clog in it. Last, pull the bottom panels off and look inside the bottom of the dishwasher and see if there is standing water down there . If ther is you have aleak somewhere or a bad drain pump. You r only other choice is a bad pressure switch. If youve already adjusted the water fil to the proper level ( just up to the grey plastic housing that the lower wash arm sits on) tehre really aernt any more options. Hope this helps!
Posted on Nov 06, 2007
  • 52 Answers
SOURCE: My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Posted on Jan 29, 2008
Illeagle
  • 525 Answers
SOURCE: Hotpoint BCI450 Programme cycles
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. From this link you can identify your issue and order parts to repair your unit.
http://www.repairclinic.com/0088_9_1.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
PapaSmurerf
  • 3 Answers
SOURCE: Bosch dishwasher cycle doesn't end
Try this link, http://www.applianceaid.com/boschDW.html for procedures for running self-tests on various Bosch models using the front door switches. Find your model and read and follow the procedure.
This remaining at '1' problem invariably relates to a 'heater fault' which has usually been traced to an open solder joint on the control board located behind the switches/indicator lights on front door. See pic here of open solder joint http://www.flickr.com/photos/zenzoidman/145089572/ In most cases, the heating element has not been at fault.
I got mine going again by resoldering the joint and saved ~$300 in parts & labour. If this is beyond your skill set, then replace the control board assembly, 266746, which is used on multiple Bosch models. See this page for more information if you want to try to DIY. http://www.appliancejournal.com/appliance-parts/bosch-appliance-parts/bosch-dishwasher-control-module-266746-37/
If this is still beyond your skill set, then call a tech & supply the Bosch model, serial number, and the results of the self-tests.
Posted on Mar 01, 2009
Can you open the door to begin wash cycle and then close which will allow you to mount flush with cabinets?
Actually, I think it is designed to do that - select your wash cycle and options with the door open, then press Start, and then close the door within 3 seconds and it should run.
Dec 13, 2014 | KitchenAid KDTE204DWH Architect II Superba...
20 year old front load white westinghouse washer goes into spin cycle when knob is pointing to wash cycle
20 years old? And you expect it to still be working?!? You can't even get parts for it anymore.
Oct 19, 2009 | Westinghouse Washing Machines
Dishwasher not emptying
either the pump is not working or the discharge hose is clogged, if you have an air gap on the sink take the hose off and hold it down see if the water comes out by tself if so the pump is bad if not the drain is colgged take out the bottom tray you will need a 1/4 inch nut driver take the plastic screen cover plate off clear it of debris, there is a sharp metal blade in there so be careful, after cleaning it out turn on to rinse and see if it drains if not you will need to either replace the dishwasher or the pump, dollar for dollar new dishwasher time
May 30, 2009 | Westinghouse 24 in. MDB421 RF Built-in...
Dishwasher will not go into wash cycle.
On the LG LDF6810 dishwasher, the best you can do is remove the bottom spray arm and then the 10 phillips screws that hold the filter down.
Pull the filter out and clean it as best you can.
Inspect the sump area beneath where the filter was. Be careful of broken glass and remove all debris. Use a flashlight and look into every little spot down there. Reassemble the dishwasher and operate your DW.
If you still have problems, I recommend a service call. Check your manual to confirm but most LG dishwashers have a 1 year parts & labor plus a 2 year parts only. Have your proof of purchase ready.
Apr 02, 2009 | LG LDF6810ST Stainless Steel Built-in...
Inherited diplomat dishwasher with my house
Today's dishwashers use less water and less electricity so the manufacturers have had to increase wash times to get good results. One hour is about normal for the "eco" cycle since it's always "sensing" the water turbidity (soil in the wash water) and water temperature, and making adjustments as necessary.
Your shortest wash cycle would be "delicate" but it might not give you the best results.
Mar 05, 2009 | Dishwashers
Not hot washing or drying
has it always been connected to cold water??? cant see how that would getanything clean designe dfor how water.
Oct 30, 2008 | Westinghouse Dishwashers
No solution as yet, will most likely replace the dishwasher.
May 31, 2008 | Westinghouse 24 in. MDB421 RF Built-in...
My westinghouse 905 dishwasher starts ok but stops somewhere in the cycle, not having washed the dishes properly.
Hi. I have a Westinghouse 905. At first all ok then we found that it cuts out and short cicuits the whole house. Trips the electricity switch. Restart gets to about half way through then same thing happens. Any help please?
Tks
Apr 22, 2008 | Dishwashers
Dishwashers Logo
55 people viewed this question
Top Dishwashers Experts
Owen Barnes
