Sharp AF-S100FX 10,000 BTU Comfort Touch Air Conditioner
Problem for Sharp AF-S100FX 10,000 BTU Comfort Touch Air Conditioner
Ian - Sharp AH-APO9EVA Plasma Keep Cutting Off why?
By ian3938 on Oct 24, 2008
Sharp AH-APO9EVA plasma split unit air-con 2 years old compressor keep stopping every few minutes and then restart even when thermostat set at 18 C when fan set at low speed. Have checked all setting correct and even the temperature sensor replaced problem persist.
If fan speed set high, compressor will not stop or stop less often.
Any advise on what to do?
Popular Solutions for Sharp AF-S100FX 10,000 BTU
Questions and Unsolved Problems for Sharp AF-S100FX 10,000 BTU
Do you recommend Sharp AF-S100FX 10,000 BTU Comfort Touch Air Conditioner?
Answer
Answer
we need the part number to order one Termostatic Expansion valve for Carrier package unit... (More)
Answer
I live in a manufactured home. When I turn on my heat on my amana it does not start.
Answer
I have an error code of CH 26 on my LG airconditioner 524AHN can you help me diagnose the problem.
Answer
I have a Split Type Room Air Conditioner. When i turn on the unit with my remote control, the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AF-S100FX 10,000 BTU...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
