Question about Dell Inspiron Computers & Internet
White horizontal lines running across laptop screen
Hi, This problem only started to occur this week, there are thin white lines running across the screen and and they flicker a littlebit. I don't know what the problem is, but when i play a game they sometimes just vanish but then eventually they come back its very annoying when i try to watch a movie or just for normal surfing. And the laptop isnt even a year old. Ive taken a screenshot: http://imageshack.us/photo/my-images/36/laptopwhitelinesacrosss.jpg/ My laptop specs are: Acer Aspire 7750g Intel Core i7-2630QM Amd Radeon HD 6650M 17.3" Hd+ LED LCD 8GB DDR3 Thanks in advance!
  • Dell Master
  • 5,660 Answers
I did not see any white lines, Simon, in the screenshot.
Just sayin'.
(Glad you tried to post it though!)
The problem is caused by a faulty Video Cable, or it's in the Display Assembly.
However, you better start the diagnoses with using an external VGA monitor, and see if the lines show up on the external monitor, also.
This would indicate a bad graphics chipset.
For most people that would mean replacing the motherboard.
A) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA connector, on the Left side of the laptop.
Example of a VGA cable, and VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
You can use a external VGA monitor that is a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
A1) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external monitor.
IF Not,
Press, and hold down on the Fn key, (Bottom left of Keyboard), and at the same time tap on the F5 key. (Top of Keyboard)
{The F5 key is the Display Toggle-Over key }
No?
There are at least 3 display options available.
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY.
Hold the Fn key down again, and tap once more on the F5 key.
Graphics look good on external VGA monitor?
Your graphics chipset is good.
Problem is Video Cable, or in the Display Assembly.
B) Video Cable: (LVDS Cable)
http://www.insidemylaptop.com/disassemble-acer-aspire-7551g-laptop/
The above is for an Acer Aspire 7751G, but it is close enough to the 7750G models, and info should directly crossover.
Scroll down to Step 17.
The Video Cable connection to the motherboard, is shown by the yellow arrow at the Top Left.
Note, although the photo is less than, the routing of the Video Cable.
It goes through the Left Hinge.
(Then into the Display Assembly, and connects to the back of the LCD screen)
With normal opening, and closing of the laptop, the Video Cable could be pinched, or have been pinched. Could have been pulled on.
You close the laptop, the cable is slightly pinched in the Hinge, and it pulls loose from the motherboard connection, AND/OR the LCD screen connection.
Doesn't take much of a loose connection. In fact it's hard to discern with the human eye, sometimes.
Make sure this motherboard connection is tight.
You have to open the Display Assembly, and check the Video Cable connection on the back of the LCD screen.
Doesn't look loose? Try to plug it in tighter anyway.
Check the connection of the wire/s from the Video Cable, TO the screen Inverter.
The small circuit board behind the Display Bezel, (LCD Bezel), and mounted to the bottom of the LCD screen.
When on the motherboard side, the side of the Video Cable that runs through the left Hinge, is there any apparent damage? Damage to the sheath of the Video Cable?
If there is, chances are the tiny wires inside the Video Cable, are damaged also.
Check with a multimeter. Perform a continuity test of Each wire.
C) Display Assembly:
Video Cable checks out then the problem is in the Display Assembly.
1) Screen Inverter:
http://www.sparepartswarehouse.com/Acer,Aspire-7700-thru-9800,Laptop,Inverters.aspx
http://www.insidemylaptop.com/replace-broken-screen-acer-aspire-5745g-laptop/
Not your model, granted. Posted for the Display Assembly dis-assembly pictorial guide.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL, or a series of LED lights.
Your laptop uses a series of LED lights for the Backlight.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A CCFL requires a screen Inverter.
A screen Inverter converts the power from the laptop, for the Backlight, and LCD screen.
NOT all LCD screens that use LED lights as a Backlight, use a screen Inverter. I suspect yours does not, as I can't find a listing for a screen Inverter, for it.
http://www.laptopscreen.com/English/section/FAQ/1245191276/Correct%20backlight%20type%20for%20your%20new%20screen/
This would mean that if the Video Cable proves to be good, the next step is to replace the LCD screen.
Shop around for the best price, AND make sure it is a direct replacement for yours.
Regards,
joecoolvette
Posted on Feb 13, 2012
2 Suggested Answers
  • 2692 Answers
SOURCE: Ram -false speed
By changing the CPU speed in the BIOS? Downoad the manual for directions to go into setup screen and see what you have to change.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=3442833〈=en&cc=us&prodTypeId=321957&prodSeriesId=3442832&taskId=135
Posted on Jan 17, 2009
Thin white line across laptop screen
check lcd display data cable if cable is fine problem in display unit
Apr 27, 2014 | Computers & Internet
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
Band of virtually solid white lines (ca 7cm wide)
check on bios if still there then monitor needs repair.
Sep 15, 2009 | Dell E176FP 17" LCD Monitor
Line across screen
scane for virus and reinstall the operating system
May 30, 2009 | Computers & Internet
Thin white line on screen
this is a screen fault... this should be sent to the maufacturer for repair/replacement if still in warranty
Sep 28, 2008 | Durabrand DVD-1002 DVD Player
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Computers & Internet Logo
315 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
