Question about Sony VAIO VPCY216FX/L I3-330UM 1.2G PC Notebook
Clean a cooling fan
Hot
Why isMy Acer aspire gettting really hot, would replacing the battery help?
Sometimes, the computer gets really hot because the "ventilation" (cooling) system (fan, etc.) is not working properly. Normally, if it gets too hot, i.e. to an unacceptable level, the system will shut down. Or, it will catch on fire.
Yes, it's known that some battery will get too hot ... and potentially damage the system. So, if you already know that the cooling system is working properly, then try replacing the battery.
May 28, 2014 | Acer Aspire One PC Notebook
Runs very hot at times cannot leave hand on lay below keyboard area, fan is not on. When it does this I start cooling mamually by pushing fan around with paper clip thru air intake grid until it starts...
Hi rdn52...
Sounds like your cooling fan is faulty...
The computer should not get very hot like you describe...the fan should keep it cool...
Replace your cooling fan...
Please take time to rate me
Sep 24, 2011 | Gateway E-475M Notebook
I have a 2003 chevy Imapla 3.4 enegine and i have had overheating problems. i have had the water pump, head gasket, front and back head gaskets,intake manifold. and it still wants to over heat what else...
Is the radiator clean and flowing coolant? is the heater core clean and flowing coolant? are the cooling fans operating? When fans are on, and the engine is hot, the air coming from the fans should be HOT.If its not HOT the radiator could be plugged. Are you sure there is no combustion gases in the cooling system? air has been bled out of cooling system?
Aug 03, 2011 | Chevrolet Impala Cars & Trucks
I have a GE microwave and just ran the self cleaning option on my gas range. During the cleaning process the microwave fan turned on low and now that the range is finished cleaning the fan will not shut...
The fan has a safety thermostat which turns the fan on if the area under the microwave get too hot. It turns off after it has cooled, providing you have not manually switched the fan on.
Jan 01, 2011 | Kitchen Ranges
Cooling Fan problems
clean/replace the fan or get a cooling pad usb
Aug 22, 2009 | Compaq Presario 1626 Cooling Fan Case...
SONY VGNFJ270 LAPTOP BECOMES HOT AND GIVES LOT OF NOISE
If the fan is noisy and the laptop is running hot, then most likely the fan is faulty and spinning slowly. Therefore the fan is not providing sufficent air flow to cool the laptop's CPU. The fan needs to be replaced and possibly the heatsink assembly needs cleaned to remove dust buildup.
Jun 24, 2009 | Sony Computers & Internet
Self cleaning oven the fan will not go off after
Self cleaning ovens usually use very hot temperatures. Therefore if your fan is designed to help your oven cool, it will run until your oven is cool. Leave it running until your oven is cool and it should stop. It it does not let me know.
Jun 09, 2009 | Ovens
My honda v65 magna runs hot in stop and go traffic
V65s are notorious for running hot in stop and go traffic as it has a liquid coolant system and no cooling fins on the heads or cylinders. An easy fix is to wire in a switch to turn on your electric radiator cooling fan and switch the fan on and leave it on when you are riding in town.
May 05, 2009 | 1984 Honda VF 1100 C
Flat tv is hot when used
What do you mean? Excessively hot or hot. The televisions tend to run warm, but if it is too warm usually there will be malfunctioning, check your cooling vents to make sure they are not filled with lint, and listen to the fans run through the cooling ports. If you do not hear a fan and you think your TV is too hot most likley it is the fan, if the fan is on and the vents are clean. The TV is probally at its normal operating temp.
Oct 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony VAIO VPCY216FX/L I3-330UM 1.2G PC Notebook Logo
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
