Question about Refrigerators
Kenmore side by side not coming on at times. gets warm on inside. open door and close it, then motor kicks on. sometimes it works ok.
    Problem Solver:
  • 10 Answers
The most common problem that causes these types of problems is the Fan. As long as the compressor comes on underneath the refer it is probably the fan in the interior not blowing the cold air around. the fan is plastic with a metal drive shaft, eventually the two separate, the fan motor dies, or ice builds up in the area around it and as it warms up, ice melts allowing the fan to spin again. easy do it yourself for $80- - $100 bucks. you do have to remove the panel in the back, usually in the freezer section, to access the fan; look around see if ice is blocking it (no frost freezers melt door water and can run into the fan space). if it's not spinning pull it out, take an old power cord and wire it to the fan and plug it in ( dont let the two wires touch ) if it runs then it is something else. watched a guy fix mine a long time ago, it was the ice thing, i was watching him where he couldn't see me. Said it needed a new fan, put it in. I asked for the part when he was done, could see it in the bag, said left it in the truck and cut the wire off really close and said it was broken ( it was a fresh cut). soldered a wire back on and it worked fine. had a fan go out in a rental, same size, put that good old broken fan in. don't think I've replaced it yet.
Posted on Feb 12, 2012
Ice in bottom of side by side Kenmore freezer side
Make sure the doors are closed tight - freezer door may open a crack when frig side closes.
If door is tight, make sure the door gasket makes a tight seal. Often they need to be cleaned (409 is my favorite) or they get twisted. They also sometimes come away from the door in spots. Pay attention to the bottom seal which you usually don't notice in daily use.
Nov 03, 2017 | Kenmore Refrigerators
My Kenmore refrigerator side by side ice will not come out of door
Sounds like where the Ice comes out of the ice maker sometimes gets clogged with ice look inside that little Hopper the goes into the door and see if it has Cube's jammed in it
Jan 08, 2016 | Kenmore Side by Side Refrigerator
Westinghouse two door fride freezer. The two blue lights are whis is between the first and second shelf is never happened before. They were both on but every time you open the door its stopped but when...
Frankly not sure unless something else going on. Some ice makers have a cut off light that when you open it lights up so ice won't kick out at your door while door open. Could also be a feature : https://www.masters.com.au/product/100399477/westinghouse-side-by-side-fridge-700l-wse7000sf
Motor kick on could be the compressor kicking on because the door is open and all that cold air is coming out and it is now turning on to cool again.
Nov 21, 2014 | Refrigerators
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
We have Kenmore side-by-side door refigerator, recently we found a problem with freezer, all the items any type of containers are getting iced in the form of a thin layer.even the sheves and most of the...
1)The door gasket on the freezer door helps keep the cold air in and the warm air out. If the gasket is dirty or damaged, it may prevent the door from closing properly, which can lead to frost buildup on your freezer walls. To make sure the door is sealing, slip a dollar bill or a sheet of paper between the gasket and the freezer and then close the door. If the bill or paper pulls free with little or no resistance, the gasket isn't sealing properly. Wipe the gasket with a damp cloth to remove dirt, grease and other residue. If the gasket is damaged, replace it with a new one. Sometimes frost can accumulate on the back panel of your freezer if the door is open too long or too often. When you open the door, you let warm, humid air inside, and this condenses and freezes. Make sure there are no packages preventing the door from fully closing, and limit how often you open the door by removing what you need all at once.
2)Ventilation is important because it ensures your freezer stays cold. If something inside the freezer blocks the internal vents, the freezer may become warm, causing condensation to form on the walls, and eventually leading to frost buildup. When loading your freezer, make sure there are no items resting against the rear wall of the freezer and space the contents out as much as possible to improve ventilation.
3)Side-by-side refrigerators with a built-in ice maker may accumulate frost if the flap on the ice dispenser doesn't close properly. This allows warm air to enter the freezer side, condense and freeze, causing frost buildup over time. Open the freezer door and examine the flap inside the ice chute. It should be flush against the housing. If it is not, empty the ice bin and make sure there is no ice or debris preventing the flap from closing.
4)If your freezer door closes properly and nothing is keeping it open, frost buildup on the back panel may indicate a problem with the freezer's self-defrost system. The self-defrost system turns off the compressor for a short time every six to 12 hours so it can turn on the defrost heater. This melts any frost buildup on the freezer coils, and the water drains to the pan beneath the freezer. If this component fails, frost continues to build. Move the contents to another freezer and turn your freezer off for 24 to 48 hours to manually defrost the interior. If frost builds up again, contact a qualified appliance repair technician to inspect the defrost timer and repair the problem.
Oct 29, 2017 | Whirlpool GR9FHMXP Top Freezer...
I POSTED A PROBLEM....NOT KNOWING THE MODEL/SIZE OF MY KENMORE FREEZER. TEMP ALERT??? TOO WARM/TOO COLD DON'T KNOW ALARM COMES ON ETC WHERE IS THE MODEL NUMBER DISPLAYED. NOT ON BACK OR KICK PLATE...
on upper left side wall about 4" in when you open the refrigerator door,if its not there it most likely is worn off or fell off, very un-commen though
Dec 08, 2009 | Cars & Trucks
Driver's side back window not working. I checked the window motor and it working fine. What next?
check wiring from drivers door to inside of car, wires sometimes split in half from door opening and closeing so much, if wiring is ok, the master contorl switch on driver door is bad.
Oct 02, 2009 | 2002 Ford Taurus
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Frost inside freezer door
there is a small electric heater along the door gasket where you see the frost building up, this heater has apparently stopped working. this will also cause the door to pop open due to a poor seal. feel around where the door gasket contacts the refrigerator and it should feel a little warm. if not then a service company can replace those heaters. should not be too expensive.
Jun 28, 2008 | Kenmore 73262 / 73264 / 73269 Top Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
