Question about Whirlpool Refrigerators
Fridge won't switch on yet the light is working so there is power going through
Its not making any noise or humming and definitely aint cooling.Had it switched on for over 6 hours now and still no sign of cooling.Prior to this it had been switched off for almost 24 hours.Everything was working perfectly.could something have been bumped due to it being moved?
  • Whirlpool Master
  • 4,654 Answers
Yes something could have beenbumped around. If while the refrigerator was moved it was laid down the oil from compressor could be trapped in the freezer evaporatorcoil and may require about 12 hours to clear up with refrigerator unplugged.Can you find the model number somewhere inside the fresh food section door Inside refrigerator, on wall ? If you had the model number itwould tell me what other things that may be wrong. If the oil is blocking the capillaryline and it is trying to start the compressor may be getting very hot. If thatis the case please unplug for a few hours. Also the cold control could be turned very low. Look around for any wiring that may have been snagged while moving, I will be here should you need more answers so feel free to ask, Thanks, Sea Breeze
Posted on Feb 13, 2012
Fridge light doesn't work/makes ticking noise
Let the refrigerator cool for awhile without opening the door. 39 minutes should do. Then check to see if the bulb is warm or hot. If it is the door switch is bad and the light is staying on which will make the plastic expand and cracklel or tick. Hope this helps.
Apr 11, 2014 | Magic Chef Refrigerators
Roland Cube 60 Amp
The power relay must be replaced or checked thats where the humming noise come from.
Jul 05, 2013 | Audio Players & Recorders
Fridge light won't turn off..does that mean the fridge has stopped working or only the light needs to be fixed? Can tell it's not cooling as much as it used to.
The light is usually a seperate circuit to the fridge compressor and it staying on is more likely to be a faulty switch than the fridge not working. Open the door and look around the perifery of the door opening, there should be a spring loaded plastic part that pushes in when the door is shut and springs out as you open the door. Try manually pushing it in and see if the light goes off, if it doesn't then the switch behind it may have become dilogded in it's housing or broken. Turn off the power to the fridge, unscrew the housing, re-position the switch or replace it, re-fit the housingturn on the power and test.
Jul 02, 2013 | Frigidaire Refrigerators
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
Infinity modulus won't work
Determine from which speaker is humming,
if all of them , check power supply.
if only one of them , replace the IC.
sample troubleshooting for
Computer Speakers
let me know if you need further assistance!
Sep 26, 2012 | Infinity Modulus System
Maytag GC2225PEKW american fridge freezer stops working if you open fridge or freezer.
it sounds like you have a bad jazz board part 12868513,go here to see it
http://www.repairclinic.com/PartDetail/Main-Control-Board/12868513/1472681?replacedManufacturerPartNumber=67004453%20.
unplug the machine,open the fridge door,remove the plastic cover behind the control panel,then feel behind the control panel,you'll feel a slot,one on each side,you stick a screw driver into the slot and push,one at a time and it releases the cover on the control panel, you have to push hard so don't worry the plastic is strong,you'll see the jazz board and a sensor on the right side,just remove the wires and sensor install the new board and reconnect the wires and sensor,then read the instructions that came with the new board and it will tell you how to program it,hope this helps and good luck
Jul 16, 2012 | Maytag Refrigerators
Garbage disposal won't work. It just makes a humming noise
might be something lodged in it, like a spoon or something. Turn it off and fish around in it with your hands.
May 01, 2012 | KitchenAid KCDB250G 1/2 HP Continuous-Feed...
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
GSs 22 wg refrigerator humming noise from freezer. Tech came and replaced defroster heater element but humming remains. What is the likely cause of this? It comes and goes but is mostly on. Fridge...
most likely it's coming from the evap fan motor or the ice maker,try shutting the ice maker off first to see if that's the problem,if not then i'd go with the fan motor,you can try opening the freezer door,this usually turns the fan on,then push in the door switch button and see if the fan stops blowing and if the noise stops too.hope this helps you out.
Jun 12, 2011 | GE Refrigerators
Refrigerators Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
