Question about Ryobi Garden
How do i replace the throttle trigger on my ryobi weed wasp
Ryobi weed wasp
  • Anonymous Mar 24, 2014
    what should be the position of the throttle torsion spring against the trigger.
    Sergeant:
  • 316 Answers
HOW TO REPLACE THROTTLE TRIGGER ON Echo SRM 210 GRASS TRIMMER - YouTube
hello wayne, this is all i could find,hope this helps,,
Posted on Feb 19, 2012
Yazz226
  • 497 Answers
SOURCE: how do i replace the started cord on my ryobi weed wasp
Broken starter ropes or failure to retract are both repairs that are fairly easy. However, the spring can be nasty as it is under tension (or should be when reassembled). This can be risky if you are not familiar with the internal construction as you disassemble the unit.
The cause of a broken cord is obvious. The cause for a failure to retract could be a broken spring, tangled or frayed rope, or some other mechanical failure. A broken spring will require total disassembly of the starter mechanism - fortunately there really isn't that much involved.
With some designs, it is possible to replace the cord without fully disassembling the starter mechanism - by threading the cord in and tying a not in the end - but after rotating it several turns to put the proper tension on the spring. This is relatively safe but may be frustrating as 3 hands are sometimes needed.
Where safe disassembly is not obvious, I would recommend that you refer to a book on lawn mower or small engine repair from the library or the service manual for the mower, if possible. You may be able to find specific step-by-step instructions which will minimize your risk of injury from an encounter with an uncontrolled spring.
When the rope pulls out and retracts normally - but doesn't do anything else - the most likely cause is a problem with the one-way clutch. This may be part of the spring-rope assembly - usually removable as a unit - or attached to the flywheel. The most common problems are gummed up lubrication or a broken spring or other damaged or worn parts.
anyway... there is a torx screw in the middle of the clutch drum(metal part that rotates).you will need to use a piston stop,to stop the engine turning while trying to undo the torx screw. i am assumig the starter is in front of the engine not at the back. once the screw is undone the clutch will come off and so will the starter cover.(source: neil)
Thanks for using Fixya
Have a nice day!
Posted on Mar 19, 2009
SOURCE: how do I replace the pull cord on a ryobi #ss30 weed trimmer
You need a long skinny T25 torque driver (sold in a pack at Lowe's with 3 other sizes.)
Take off the 4 screws in the back to reveal the piston. Get a wooden dowel (or a wooden spoon if your wife isn't around) and stick it in to the piston to block it from spinning.
Now take that T25 and stick it in to the front pulley (cone shaped silver item that is preventing the housing from coming off) turn to the left and it should come off.
That should come off to reveal about a 1"x1.5" piece with a spring wrapped around it. That can also turn to the left and come off with an adjustable wrench or pliers.
Once that is off the housing should come away and you'll be able to get at the pull cord after removing 4 more T25 screws.
Posted on Oct 14, 2009
  • 203 Answers
SOURCE: RYOBI GAS WEED TRIMMER RIPCORD TANGLED
You should be able to take the housing loose with about 4-6 torx head bolts/screws and get in there and untangle the rope. May not even have to take the housing off, just loosen it. Good Luck!
Posted on Nov 18, 2009
rycgl
  • 1545 Answers
SOURCE: replacing fuel lines on ryobi weed eater,need
This is an ongoing issue for users, and rightfully so. Small diameter line out of fuel tank (has filter in-tank on end) connects to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then pushes any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Years ago on 2-stroke trimmers, primers were not even used,...you choked the carb with a slide lever and gravity let fuel enter the carb from above...a few pulls, a "pop"...slide it off of choke and away you went.
If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank.
Posted on Jul 10, 2010
  • 640 Answers
SOURCE: Ryobi Weed Wasp starts but cuts out after 2 to 3
Sounds like it is running on the prime. Check the fuel filter in the tank and if it looks clogged or dark, replace it. If that is not it, now is the time to consider a carburetor clean and rebuild, with a replacement of fuel lines and primer bulb. Today's ethenol in gas is murder on small engine soft components.
Posted on Sep 14, 2011
How to adjust carburetor
no adjustments possible, use fresh gas/oil mix 40:1. Check carb primer bulb for cracks and fuel lines. Excess air can cause high rev and surging.
Dec 29, 2015 | Ryobi Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Can I get a Schematic Diagram for a Ryobi Weed Wasp Model RWT 285 DS
    The following as the images of the parts list. I couldn't anything on the USA site. Being made in the 1990's most of the parts are not going to be available anymore.
    This is an Australian site that I did find with the info. I don't anything about them so use caution.
    Ryobi RWT285DS Spare Parts
    Nov 10, 2014 | Ryobi Garden
    My ryobi weed wasp starts on full choke bu cuts
    Yes, you have a fuel issue. Start with adjusting the low and high setting to one turn out each, then set the idle. Could also be need carb rebuilt, air filter, etc.
    Sep 14, 2014 | Garden
    Ryobi 975R head won't stop turning.
    sounds like the idde is to high
    Aug 06, 2012 | Garden
    My throttle continues to stick. The motor races and it sounds like the engine is about to explode because of its speed. I opened up the handle and the spring seems out of place. When I squeeze the trigger...
    You should see some small wear marks inside the handle where the spring is supposed to rest. Also, check the throttle cable where it exits the plastic engine housing and goes to the throttle plate on the carburetor. Make sure it is connected correctly and not binding on anything on the way to the carburetor. There really aren't any diagrams or pictures available on the net of the insides of a Ryobi weed-trimmer's throttle trigger and spring.
    When you squeeze the trigger the steel cable should move, the cable housing should NOT. If you look closely, you will maybe see how it works and all goes together. It is not that complicated.
    May 21, 2011 | Ryobi Garden
    I need a manual for a ryobi weed wasp line trimmer
    GO TO THE RYOBI WEB SITE HERE! http://ryobitools.com
    Dec 12, 2010 | Garden
    Garden Logo
    664 people viewed this question
    Top Ryobi Garden Experts
    Jim Parker
    Jim Parker
    Nick Olsen
    Rexter1
    Are you a Ryobi Garden Expert? Answer questions, earn points and help others
