Digital tv reception
Tonight I purchased a Sanyo widescreen LCD HDTV, model DP26648. I connected everything as it was on my old TV. I get excellent reception on the analog channels as well as the video 1, but on channel 3, the channel that I always watch my satellite programming there is background snow.
I have a C-Band satellie (big dish). I've tried other channels 4,5,6,7, but get no picture on these. I'm sure this is probably a simple fix, but I don't have the technical skill/mindset to figure this out. I'm 60 and just got my first computer this year.
The other tv's hooked up to the same cable do not have this snow, so I suspect the problem is something I've done or haven't done.
I would appeciate the help of your experts.
Sincerely,
Bob Lash
Farmersburg, Indiana
    Brigadier General:
  • 6,966 Answers
Any developments with the snowy Channel 3?
Good luck and thank you for using FixYa.
Posted on Oct 24, 2008
2008 sanyo lcd tv DP26648 power turns on but no picture or sound
likely a mainboard or power supply capacitor issue.
if you have the soldering skills fix it, otherwise time to replace the TV.
If you can de-solder and solder in new capacitors make sure you are using high quality capacitors be very causious of capacitors purchased from auction sites.
Apr 30, 2014 | Sanyo DP26648-R 26 in. LCD TV
I last the tv remote model dp26648 i want remote
Setup codes to check with Sanyo brands are 004/ 013. If you wish to get more details about four digit and five digit codes, check this link. There is setup code list to many brands of remote controls. Just see and check which brand has setup code to Sanyo. It will make you remote selection easy. There is an other link. Check this too.
Feb 20, 2013 | Sanyo DP26648-R 26 in. LCD TV
Sanyo lcd-32k40 features
  • Model: Sanyo 32K40 Multi System LCD TV
  • World-Wide NTSC/PAL/SECAM Color System - Watch any video signal on this TV!!
  • World-Wide NTSC M, PAL BG, PAL I, Secam BG, DK/ PAL DK TV tuners
  • 32 inch LCD TV with 3 HDMI inputs and PC input
  • USB input for direct media playback
  • 45,000:1 Dynamic Contrast: While viewing either very bright or very dark scenes, it can be difficult to distinguish main images which blend into the background.
  • Dynamic Contrast dramatically mitigates this problem by adjusting the backlight intensity, providing up to a 4X improvement in contrast.
  • 6.5ms Response Time
  • Widescreen 16 X 9 Format
  • World-wide Dual Voltage 110-240 volts 50-60 hertz
  • HDTV monitor (HDTV tuner required for HD reception)
  • This is a multisystem TV. All Multi System TVs in the market do not have a digital TV tuner: What does this mean?
  • To watch digital channels (ATSC Broadcasting in US and DVBT broadcasting overseas) you need a digital source/tuner like a cable box, digital tuner, satellite service, etc.
  • To get the best quality video on this TV you need a source that has a digital connection like HDMI or component.
  • Wide Screen Mode allows you to watch conventional 4:3 aspect ratio broadcasts in wide screen (16:9) mode.
  • Steady Sound® equalizes volume levels so there is consistent output between programs and commercials.
  • Built-in hidden speakers includes 2 (5W x 2) speakers to deliver dynamic sound.
  • Component Video Input offers the best video quality for DVD (480p and 480i), and digital set-top box (1080p, 1080i, 720p, 480p and 480i) connections.
  • PC Input allows you to connect your PC and display the PC screen on your TV.
  • Surround Sound Audio Effect
Mar 04, 2011 | Sanyo 42 in. LCD TV
What are the classification of simple machune
Specifications Display Image Aspect Ratio: 16:9 Widescreen Modes: Conventional 4:3 Comb Filter: 3D digital Additional Features: V-Chip, parental control Diagonal Size: 42" - widescreen Display Format: 1080p (FullHD) Resolution: 1920 x 1080 V-Chip Control: Yes Image Contrast Ratio: 2500:1 Brightness: 500 cd/m2 TV Tuner Stereo Reception System: MTS Secondary Audio Program (SAP): Yes Analog TV Tuner: NTSC Video Features HDTV Ready: Yes Analog Video Input Signals: NTSC Input Video Formats: 1080p Remote Control Type: Remote control Audio System Sound Output Mode: Stereo Sound Effects: Virtual Dolby Digital Speakers Included: 2 speakers Additional Features: Mute button Speaker(s): 2 x right/left channel speaker - built-in Connections Connector Type: 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 pin mini-DIN ) ¦ 3 x audio line-in ( RCA phono x 2 ) ¦ 2 x component video input ( RCA phono x 3 ) ¦ 3 x HDMI input ( 19 pin HDMI Type A ) ¦ 1 x digital audio output (coaxial) ( RCA phono ) ¦ 1 x audio line-out ( RCA phono x 2 ) Power Power Device: Power supply - internal Power Consumption Operational: 240 Watt General Product Type: 42" LCD TV TV Tuner: 1x analog, 1x digital Width: 41.3 in Depth: 10.2 in Height: 29.7 in Weight: 55.1 lbs HDCP Compatible: Yes Digital Television Certification: HDTV Digital TV Tuner Digital TV Tuner: ATSC, QAM Additional Specifications HDMI: Y More Information Model No.: DP42848 Shipping Weight (in pounds): 67.0 Product in Inches (L x W x H): 41.3 x 10.2 x 29.7 Assembled in Country of Origin: USA and/or Imported Origin of Components: USA and/or Imported Walmart No.: 000503420
hope this will be helpfull to you.
GoodLuck
Feb 02, 2011 | Sanyo 42 in. LCD TV
Looking for new or used main motherboard
Required main board for Sanyo DP26648 lcd tv is available in Shop Jimmy.com for $70
Click to view image of board, make sure your tv model is as shown in your question headings.
Thanks.
Oct 23, 2010 | Sanyo DP26648 LCD TV
How do I hook up a dell laptop to a 50" Sanyo Dp26648 LCD TV
You can refer to 2 tutorials :-
http://www.techlore.com/article/10061/How-To-Connect-a-Computer-To-Your-TV/
http://www.online-tech-tips.com/computer-tips/how-to-connect-your-laptoppccomputer-to-your-tv/
Thanks.
Jul 27, 2009 | Sanyo DP26648 LCD TV
I need to hook up to digital cable
Connect the cable to your TV's antenna input jack. Through the TV setup menu, perform a digital cable search. This is a separate operation from the full channel scan. The TV manual says this may take up to 10 minutes, so be patient. The set should find the channels on your system. When you want to watch TV, press the INPUT button on your remote to select Digital RF as the source. Press INPUT again to select any other source (DVD, etc.) you have connected when you want to watch that.
I was wrong about needing a converter. This TV has a tuner that can pick up the cable channels if they use a system called QAM. Verizon says QAM-capable sets don't need a box for non-scrambled or premium channel, so you should be good once you have the TV scan channels.
I couldn't find the DP26648 manual at Sanyo's site, so my solution is based on the DP26647 manual. They should be similar. You can download the manual here if you don't have the manual for your set.
Apr 01, 2009 | Sanyo DP26648-R 26 in. LCD TV
We are getting a picture but no sound.
First go to menu make sure audio is not turned off CK speaker . then audio output IC.
Feb 15, 2009 | Sanyo DS31520 31" TV
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
