Question about Stoves EC500DOA Electric Kitchen Range
How to work the grill in a stoves newhome ec500d0a
When i put the grill on the outer elements heat up but not the inner ones
2 Suggested Answers
SOURCE: i have a stoves newhome GL616 cooker that just
Hi I have a gl616 cooker when turned on and flame on gas mark 9 the flame dies down then it turns off, any reason why this happens have replaced the fan,problem still occurs.
Posted on Feb 21, 2012
Only half of the element is heating up
Are you referring to the oven grill element.? Most have a double element in them, An inner and an outer. Basically for different heat settings. ie. single grill/ double grill
Listing your make and model may help an expert answer your question more accurately.
Do you have your operators manual.?
May 21, 2016 | Ovens
Stoves newhome gg700 grill flame goes out if lid is closed
I had a stove in my camper that did this. The answer was to let the flame burn for a few minutes BEFORE closing the door. I think the original problem is that there is too much gas flowing to the burner and it literally blows itself out, until you get everything heated up and working. The question, I think, is there a way to turn down the gas pressure??
Nov 19, 2013 | Stoves Newhome ECH600MXa Electric Kitchen...
How do i turn the outer ring on for a dacor stove top
Pushing the button for the element will turn on the inner element at level 5. Before adjusting the level (so while the level indicator is still blinking) press the little circle on the right side of the controls for that element. The circle should light up. Now press the UP control for that element, and the level indicator should stop blinking. Now the outer and inner elements are both heating up. Adjust temp level to desired setting.
Jan 30, 2013 | Dacor Millennia ETT304 Electric Cooktop
Grill not working after replacement element - any ideas?
I would say you are right on your wondering. look at your manuel and it will show you a diagram
May 07, 2012 | Zanussi ZHQ575 Electric Double Oven
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
How do i work the grill?
Nov 21, 2010 | Stoves 720EF Electric Double Oven
Please could someone tell me how to use the grill?
First things first, the grill only works with the door down. Directly you shut it, a microswitch operates and shuts the elements off. ( Of course the top oven operates with the door shut).
There are two options for the grill. Turning the control switch to the left operates the inner element only. Turning it to the right operates both the inner and outer elements together.
With either option, setting 5 (the max) has that option on full, whereas settings 1 to 4 switch on and off.
Nov 10, 2010 | Stoves 720EF Electric Double Oven
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Newhome electric cooker = problems with oven
problem is 99% sure is the cvircular element round the fan. easy to replace
Jan 07, 2007 | Stoves Newhome ECH600MXa Electric Kitchen...
Stoves EC500DOA Electric Kitchen Range Logo
123 people viewed this question
Top Stoves Kitchen Ranges Experts
Paul Carew
Oloyede Monsuru
marley mcelhinney
Are you a Stoves Kitchen Range Expert? Answer questions, earn points and help others
