Question about Samsung VP-D10 Mini DV Digital Camcorder
There is a tape stuck in my camera.
It starts to eject and then stops halfway through so I can't get the tape out.
  • 2 more comments
  • eshock Oct 24, 2008
    Here is a picture of where it stops ejecting. As you can hopefully see the tape is still in the open position and I can't get the tape out. Hope this makes it clearer.
  • eshock Nov 05, 2008
    I think that the tape is still around the head
    Thanks for your help I will have a go at that or maybe find a repair shop!!!
  • jason May 11, 2010
    have you tried to gently guide it open and see if it stays?
Posted on Oct 23, 2009
  • 905 Answers
There may have been a spring that pulled on a tab in these places that will unlock the the tape , and if is not unlocking it will go back to close position
Posted on Oct 25, 2008
  • 1 more comment
  • jason Oct 25, 2008
    also is the tape still around the head or has it retracted
  • jason Nov 05, 2008
    well then the problem is the sensor that detects the tape in there , when it fails the tape will not come out , vcrs do this also
    the only way to get it fixed is to find the bad sensor and replace it
    the only way the tape will come out then is to disassemble the unit untill you can get the tape deck unscrewed and then it will come out , but there are alot of small parts , so be carefull not to drop anything inside
    otherwise you will need to take it to a repair shop where they can test the sensors to find the bad one and replace it
    please give a good rating for my help , and if you need further assistance , just ask and I'll be glad to help you more
2 Suggested Answers
SOURCE: SOny CCD-TRV52 camera won't eject tape.
Did try disconnecting battery or AC adapter and wait a few minutes then install power and turn on .See if it will eject
Posted on Oct 01, 2009
Sony Handi-Cam TR57. After being stored for a couple of weeks,the tape door, with tape in place has become stuck in the up position, and the tape cannot be either removed or pushed back down. The tape...
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Jul 31, 2009 | Sony Video Cameras
My tape will not eject!!!
u must to open ur camera and eject motor u put 3 dc volt then it eill eject and clean all connect then fixit and try
Jul 02, 2009 | Sony Handycam CCD-TRV107E Camcorder
Tape stuck in recorder.
remove battery start over repeat constantly till tape comes out. very tedius but be patient it will take a few times. once tape is out DONT PUT IT BACK IN !!!! try other tape first
Jun 02, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
Tape won't eject from CCD-TRV608
There is a little plastic piece on the tape and it is getting stuck, you have to maually move this piece, witha paper clip or something else. it might break the piece off, but that is the only way I know to get it out.
Dec 18, 2008 | Sony Handycam CCD-TRV608 Camcorder
Tape will not eject
If you remove the power while the basket is halfway up, you should be able to remove the door. Then look to see if the reels are turning when you try to elect the tape. The error code you are getting indicates the reels are not turning for some reason. You can ssist the reels turning as the tape is ejected if you have a small plastic pick or a toothpick into the reels to assist the reels turning and tehn you may be able to remove the tape.
The tape will not eject, battery is charged, help! Thank you!
Unplug battery and reattach it again, then try to eject the tape.
If problem still exist and camera shows error code "C:..:.." and beeps then it is problem of tape mechanism.
Dec 13, 2008 | Sony Handycam DCR-TRV50 Mini DV Digital...
Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
Jun 15, 2008 | Sony Handycam CCD-TRV308 Camcorder
Canon ZR 45 Won't Eject Tape
That would be the take up or supply reel fault. It may also be a mode position error. Try here for advice but I don't advise tackling this job without full service instruction manual for the deck. No idea of your country so try here first;
Apr 15, 2017 | Video Cameras
Warning indicator C:32:00/C:32:11
I had the same problem (error c:32:00, beeps and tape would not eject. Cassette was halfway ejected) on my Sony CCD-TR416. I found the fix here:
To summarize: remove the battery, unplug from the wall and smack the **** outta the bottom of the camera. It worked for me. It looks like my problem was that the tape had started coming out of the cassette body and caused a jam.
Feb 05, 2008 | Sony Handycam CCD-TRV43 Camcorder
Samsung VP-D10 Mini DV Digital Camcorder Logo
470 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
