Cd and omni speaker
Hi i have facing problem of my hi fi knewood deck.there is rotate 3 cd tray.its working but cd sound r not coming.and omni speaker no working.pls. help me...
  • Jeffrey Groves
    Jeffrey Groves Feb 13, 2012
    Not a barcode scanner question
  • 27,725 Answers
The speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Posted on Feb 13, 2012
DVD tray not coming out fully and dvd disc tray not rotating and screeching sound is coming
it sounds like the "Tray" loading belt has stretched, You could try cleaning it, this would prove a point but will need replacing. the belt is small (about 20mm diameter) and is located under the disc tray near to the front, removing/replacing it will require the hifi to be dismantled.
Apr 07, 2014 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Hi I have a DEH 1150MPG head deck in my truck and it no longer puts out sound to the speakers yet still puts sound out to the subs through the AV out in the rear of the head unit. I have connected up...
Sounds like a blown output on those two speakers. Should be a quick fix just replacing the integrated circuit if that is the case at any hi fi technician
Dec 18, 2017 | Pioneer DEH-P7600MP CD Player
Does this unit come with speakers
If it has no volume control or terminals for speakers then it is a hi-fi seperate and needs to be connected to an hi-fi amp to work.
Dec 31, 2010 | Pyle PT649D Single Cassette Deck
Jvc deck same problem, powers on and functions but no sound
the car is equiped with an amplifier. there is a black wire that you didn't connect. just connect it to the blue with white wire from your radio and it should work.
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
The word "protect" appears on my screen and shuts my unit off; what should I do.
Sounds like you have either a speaker wire exposed and/or crossed. Or speakers that are capable of too much wattage/ohms resistance for the receiver to match.
Jun 21, 2009 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Motorized flip face won't open
i have had this deck since December 06 when it first came out. Retail was around a grand but with an employee discount price was only three hundred. For whatever reason the motorized face does not work well when the interior gets hot. I do believe it is a defect in the deck. If your deck can be returnded get rid of it. I originally thought the problem was due to low voltage going through the deck, but it has nothing to do with that. People will inform you to replace a ribbon on the unit, but really why bother, more than likely it will fail again.
P.S. if the unit does partially open you can still force it the rest of the way. I did this by pushing the face up while it was trying to rotate. Mind you I only resorted to this due to bring sick of the current cd, and I was on the way to installing another deck. If the deck will continue to work after forcing it open numerous times, i do not know.
Jan 30, 2009 | Pioneer DEH-8600 CD Player
Radio on my sony rx d7 hi fi 3 cd changer
check to maks sure you have an fm antenna connected
Dec 19, 2008 | Audio Players & Recorders
My rca system
Try unplugging unit for 24 hours so that microprocessor can reset. Try again to operate. If still nothing, take in for check and service
Jun 01, 2008 | RCA RS2620 Single Cassette Deck
Same Prolbem as the other guy
Do you get sound when you use the radio? If so, the blue wire from the back of the radio needs to be disconnected and you need to use the blue/white wire instead.
If that doesn't work, try connecting either a test speaker or one speaker at a time. Your problem could be a short in the wiring - if the (+) wire to a speaker is touching the (-) wire, the deck will cut out all sound to keep itself from overheating. Let me know if you need more help.
Oct 12, 2007 | Jensen MP5720 CD Player
No sound through speakers
What type of vehicle is it in? Is there a blue/white wire connected?
Sep 16, 2007 | Jensen MP5720 CD Player
Open Questions:
Official Toshiba Support ' Toshiba Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 19, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
David Payne
David Payne
