Question about Pioneer Car Audio & Video
Pioneer MOSFET 50wx4 troubleshooting - Pioneer Car Audio & Video
This set is not on
Posted on Jul 22, 2012
    Genius:
  • 1,212 Answers
MOSFETs are not always easily checked with a DVM, their contact resistance is very high between the gate and drain or source leads, b ut you can get reasonable assesment. When testing, use highest resistance range.
Gate to Source ,Gate to Drain resistance is normally more than 1 meg Ohm, 500,000 ohm is marginal but acceptable. The polarity of test leads will yeild the lowest readings for N channel MOSFET when the positive test lead is attached to Gate. When reversed, readings should be higher.
Source to Drain, Drain to Source should be greater than 1 Meg Ohm either polarity or test leads. Lowest acceptable is 1 Meg Ohm.
Otherwise if you have a transistor tester that will test regular Junction Fets or JFETs, that will work most of the time, but you may have to remove them from the circuit to test them accurately, especially if you recieve no indication of condition in circuit.
Normal failure mode of MOSFETs is to burn open.
If the amp went silent, test the caps, replace off the electrolytics and tantalums in the finals/output stage.
If one chanel failed, check the preamp and drivers. If the speaker voice coils burned out- replace the output capacitors.
You may need to power up the amp- do not leave them unloaded, if nothing else use a wirewound cement resistor of 8 to 16 ohms. Then you can start with a pair of headphones, attach test leads to the contacts so you can trace the sound path in the amplifier to listen for distorted signals- conventional Class A, B, AB and C audio amplifier designs have locations where you are hearing part of the sound wave, and they will sound muffled and indistinct, the key is if that distorted wave continues through the amp, and you have the other channel to use as a baseline for compairison.
Posted on Feb 12, 2012
SOURCE: Pioneer eep mosfet 50wx4 super tuner 3d
the clock does not flash by pressing the (src) source button. press (scr) source button until clock appears then press the func function button (it is just under the audio button) then the clock will flash. press the up down buttons to change the hour then press the side to side buttons to switch to the minutes then press the up down button to change the minutes
Posted on Aug 20, 2008
SOURCE: connection to IPOD
There are many ways to do so. Each of which is progressively more expensive.
All of these plug into the Ip bus plug in the rear of the unit.
Most of these can be found on Ebay or Amazon
1: An IP bus to RCA plug then you need a RCA to 3.5mm plug wire. (note this is a lower quality) $10-$30
2: An ip bus to Ipod connect plug. (Better sound quality, charges Ipod, does not allow Ipod control from the Head unit, only from the Ipod) around $15-$30
3: An ip bus to Ipod Connectivity unit (same quality as #2 but allows for Ipod control from Head unit)
$100+
Posted on Mar 24, 2009
SOURCE: How can I hook up an ipod to a EEQ Mosfet 50WX4
How can I hook up an ipod to pioneer mosfet 50wx4? i cant get the aux function to show up
Posted on Jan 05, 2010
  • 31 Answers
SOURCE: how do i connect an ipod to a pioneer mosfet 50wx4
unless you have a headphone jack or rca input in the back
i really dont know the deck but thats the 2 easy ways
Posted on Jan 12, 2010
SOURCE: How do I set the
-turn the radio off -press the "A" buttom (right on top) for a while
Posted on Mar 02, 2011
My pioneer mosfet 50wx4 looks like it is on, but no sound.
Check for short circuit wiring on the speaker leads.
Either touching together or touching the body of the car.
It is designed to shut down to protect the internal amp.
Oct 22, 2015 | Pioneer Car Audio & Video
How do I set the clock on a pioneer mosfet 50wx4 DEH1190MP
here is the manual go through it.
http://caraudio.manualsonline.com/manuals/mfg/pioneer/deh1600_deh16.html
Ifthis solution helpful/useful for you please rate the solution. THANKS FOR USINGFIXYA.
Jun 19, 2011 | Pioneer DEH-1600 CD Player
Pioneer ECQ MOSFET 50wx4 DEH-6500 Need manual
here hopes this helps ya click on the onwers manual half way down.
DEH-6500
Mar 24, 2010 | Pioneer DEH-2800MP CD Player
How do i connect an ipod to a pioneer mosfet 50wx4 car stereo, do I need a certain part?
Jan 08, 2010 | Pioneer XM CD REMOTE MOSFET50 EEQ
How can I hook up an ipod to a EEQ Mosfet 50WX4 pioneer super tuner 111 D stereo?
Dec 12, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Setting clock radio
Press and hold down the "clock" button. You should see your time start flashing. Normally you set the time with the volume or channel control. Check which control lets the selector jump from "hou" to "minute and set the minutes. To exit setting menu, depress "clock" button again
Apr 28, 2009 | Car Audio & Video
Car Audio & Video Logo
230 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
