Question about Microwave Ovens
Emmerson microwave MW9113SS stopped working
This one worked great two times. Now, only the light will come on but won't run or turn turntable. Please help - this was a gift to an elderly parent to replace and old one that was working.
  • agukoe Jan 24, 2009
    I do have the same problem, the counter works but wont warm anything.
  • Anonymous Apr 24, 2009
    It was working fine and then, all of a sudden it stopped. The light comes on but it does not do anything else. I have had this for less than a year & will contact Emerson for warrantee coverage. However, I bought it to replace one that had been in our family (AND WORKING FINE) since 1984! What a pain.
  • Microwave Ovens Master
  • 9,098 Answers
If it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020. Get help locating a servicer or parts at 1-800-695-0098.
The following is advice if it's out of warranty and you or someone you know wants to work on it:
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Oct 24, 2008
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Genius S333 refer to manual error after 3 seconds
If microwave runs only without turn table, I am suggest to check if turntable electric motor has got short circuit. If yes, I have some left.
Nov 13, 2013 | Microwave Ovens
The turntable keeps rotating when the door is opened - Panasonic NN-T994SF
You probably have a shorted main relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 25, 2017 | Panasonic NN-T994SF Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
My JVM1653 stopped cooking, The turntable turns
your magnetron might be out. its what heats
Feb 13, 2010 | GE JVM1653 Microwave Oven
I have bought 2 emerson microwaves MW9113ss and both just stopped
U can take one to the stores which u bought december 2008. Unfortunately there is only 1 year warranty. generally these microwaves should last more than a year... hope u will get warranty and receive a new piece ..
Jul 21, 2009 | Microwave Ovens
Microwave will not heat food. punch in heating time, press start and nothing happens
HI. your control board has failed. you will need to replace the control board asap if possible.
May 30, 2009 | Panasonic Microwave Ovens
Ultrex microwave turntable won't turn
turn table motor may be going bad.. it is almost impossible to diagnose untill it stops working completely.. when it stops working completely you can test for 120v down at the motor if you get 120v you need to replace the motor.
Jan 20, 2009 | Microwave Ovens
Microwave Ovens Logo
1,227 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
