Wont load motor has a clicking sound then no sound
  • 27,725 Answers
The clicking sound might be power not getting to hard drive
Test the leads that attach to your ((hard drive from the motherboard)) make sure they have dust free secure connections or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive)) if its a 40 pin IDE this will be the first to fail
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs continue its cycle power and data to travel through every working device and have an end point so any faulty leads will end up with a computer error
hope this helps you
Posted on Feb 13, 2012
1998 slk 230 wont turnover
have a load test done on the battery as if is probably failing from the cold.
Jan 06, 2015 | Cars & Trucks
WASHER WILL FILL UP BUT WONT DO ANY THING ELSE IT CLICKS THEN MAKES A BUZZING SOUND AFTER IT FILLLS
Sounds you you have a wire off the capacitor or capaciter is bad by the motor..... or the motor is bad
Mar 22, 2011 | Roper RAX7244KQ Top Load Washer
Model 110 wont spin, just click click click.
sounds like the motor coupling....................YouTube - Washing Machine Drive Motor Coupler Replacement (part #285753A)
Mar 05, 2011 | Kenmore 22642 Top Load Washer
I have a top loading whirlpool washer. For some reason it stopped spinning. The water is coming in and draining I can hear the motor running but it wont spin. Any suggestions of how I can fix it without...
it sounds like the drive cupler or also known as motor cupler,,,tilt unit back and look underneath washer,,recomendid to have someone hold it so it wont fall forward on you,,then look for a plastic and rubber oreo cookie that is the cupler,,located between motor and transmission,,,second issue and a bit easyer door lid switch or safty switch,,lift cover and slowly close if you hear a click it is ok no click means no good,,,it shold click at the closed point,,if not unit beleaves door lid is always open and will not spin,,,also if unit aditates but no spin it is normally the door swich as well www.myabcspace.com/washerwizzards
May 17, 2010 | Washing Machines
Washer was working made a clicking/humming sound now the aggitator doesent work and wont spin. Still fills and drains.
your motor coupler is broke,tip the washer back and look between the motor and trans that is where the coupler is located-mike
Feb 19, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
My washer wont spin out
I believe these are made by whirlpool and use a rubber coupling to connect the drive motor . they are five dollars and change in half an hour if your half way mechanical.
Oct 29, 2009 | Kenmore 24032\24036 Top Load Washer
Repalced the coupling and now wont drain
sounds like the motor is locking up and tripping the overload....does it take a while before it will start again.then do the same thing and do you hear a faint click right when it stops? i would remove motor and see if the shaft spins freely.it should not be tight.
Jun 06, 2009 | Roper RAS8445KQ Top Load Washer
Maytag dryer problem
sounds like the motor. if the motor gets too hot then the overload on the motor wont let it come back on until it cools off
Nov 25, 2007 | Dryers
Computers & Internet Logo
David Payne
David Payne
